Grand Marquis slipping into gear
I have a 2005 Grand Marquis that has trouble getting into gear. When I shift into reverse, it takes a couple seconds to get into gear. Also when I'm moving forward it sometimes seems to slip when shifting gears.
I usually wouldn't rec additives, but many have had success with these Ford trannys using Lucas Transmission Fix. If I had this problem and my fluid was good and properly full I'd try the Lucas.
I can try to change the filter and transmission fluid, and the Lucas as well-
