Chevy Silverado Problems
the last couple of times when I rapidly pump/kick/thrash the fuel peddle and turn the ignition it restarts. However in the past when this has happened it would not start. At the time it was under warranty (100Kmiles) and the dealer put in a new pump, control module etc. Not really sure if this was the issue as i have had intermittent problems now for 40,000 miles.
On thought is that it might be the fuel peddle sending unit. Does anyone have any ideas
GMC Sierra/Chevy Silverado 2500 & 3500 - II
You obviously own a Chevy Diesel, I don't think you'll get the answer here.
3 dealers had looked at this guys 2500 w/6.0 that had what sounded like spark knock when pulling a heavy 5th wheel camper. The faster he went, the louder it got. A dealer in Carson City, Nevada finally diagnosed it, and his home dealer in Georgia fixed it by putting a restriction in the heater hose just before the firewall.
Seems too much water was going through the heater and making noises that sounded just like spark knock on the passenger side. 7000 miles later his noise is still gone.
Mike L
Check this ABC affiliate news article out...very interesting, this is a first in what I'm sure are more to come, then GM is gonna bite the bullet for sure. How does it go.....pay me now or pay me later! ROFLMAO
http://abclocal.go.com/ktrk/health/11502_a13_chevy.html
Ray T.
2001-2002 Passenger Cars and Light Duty Trucks
with 4L60-E or 4L65-E Automatic Transmission
Recently, a product improvement analysis study was undertaken to determine the causes of harsh 1-2 shift concerns in 2001 model year 4L60-E automatic transmissions.
The product improvement analysis study was completed on transmissions which met the following criteria:
Transmissions with a consistent harsh 1-2 shift were obtained from vehicles in service.
These transmissions had a consistent harsh 1-2 shift, not an intermittent condition.
The transmissions had 19,000 km (12,000 mi) or less.
The consistent harsh 1-2 shift condition was verified during a test drive by dealership personnel, before the transmission was removed.
The transmissions were disassembled and carefully inspected to identify causes of the harsh 1-2 shift.
The study pointed out that the following four conditions were found to cause the majority of harsh 1-2 shift comments.
Chips/Sediment/Debris/Contamination found in the valve body, 1-2 accumulator valve (371) bore, may cause the 1-2 accumulator valve to stick or hang-up.
Chips/Sediment/Debris/Contamination found in the valve body, 4-3 sequence valve (383) bore, may cause the 4-3 sequence valve to stick or hang-up.
A cracked 1-2 accumulator piston (56) that is allowing fluid to leak by.
Mislocated/Missing valve body-to-spacer plate check balls (61).
When attempting to correct a consistent harsh 1-2 shift, the four conditions listed above should be inspected as possible causes. It is important to also refer to the appropriate Service Manual for further possible causes of this condition.
Slipping or Rough 1-2 Shift Checks
Causes
Valve Body Assembly
Mislocated valve body to spacer plate checkball or checkballs.
1-2 Shift valve train stuck due to sediment
Gaskets or spacer plate incorrect, mispositioned or damaged
1-2 Accumulator valve stuck or damaged
Face not flat
4-3 sequence valve stuck or damaged
#1 or #8 checkball missing or mis-located
1-2 accumulator valve bushing rotated 180°
2-4 Servo Assembly
Apply pin too long or too short
2nd servo apply piston seal missing, cut or damaged
Restricted or missing oil passages
Servo bore in case damaged
2nd Accumulator
A cracked 1-2 accumulator piston - allowing fluid to leak by
Porosity in 1-2 accumulator cover or piston
Piston seal or groove damaged
Nicks or burrs in 1-2 accumulator housing
Missing or restricted oil passage
1-2 accumulator piston spring not seated
Rough finish in 1-2 accumulator bore in case
2-4 Band
Worn or mispositioned
Oil Pump Assembly or Case
Faces not flat
anybody have any thoughts?
Again, this is for folks who might want to learn more about the issue for whatever reasons. It is also a site where people who have the problem can join in to try to make GM do the right thing by their loyal customers. The site is not intended to take folks who are completely happy with their vehicle (slapping or not) and try to convince them to be unhappy. If you are happy with your vehicle, we are happy for you!...Good luck everybody!
Does ANYONE know what is causing this noise?? How to fix it??
Any help would be greatly appreciated....I'm a bit embarassed to have spent this kind of money and have people hear this noise while riding with me.
Thanks for the help.
If you would like the tsb (with pics) email me at ryanb0928@yahoo.com
I have it in word format
Ray T.
Thats a dealership problem not a problem with gm.
They have given me the blue oil, updated the PCM for the trans at least three times, and the nickel plated slip joke.. sorry I meant yoke.
NONE of this has corrected the problem. I am working with GM customer assistance currently with this problem as well as the piston slap.
That' a GM problem any way you look at it.
My suggestion talk with the owner. Explain to him why you go there for service and didnt buy from them. My reason is because their sales staff were a bunch of idiots (seriously one guy didnt know the difference between a bench and a bucket seat).
Anyone else agree with me that its a dealership problem (yes i know gm is to blame for the original problem BUT he is trying to get it fixed and the dealership wont do it)
Ray T.
Ray T.
Ray T.
If this behaviour is normal - why don't they all do it?
I would like to hear more about this, today I put my 99 z-71 in 4WD and it was having difficulty, light would go on for a second (going into 4H)then it would go out, finally got it to stay (then back to 2WD) and now the "Service 4WD" is appearing in message center and it will not go in at all, will not go in the Auto 4WD either.
Truck only has 40K, and has spent very litte time in 4WD.
Any info on the above TSB or info on similar problems and resolution is greatly appreciated.
Thanks in advance,
Jody
GM is now saying now that knocking engines are "normal". This means that any new new truck buyer stands a good chance of buying a truck that sounds like a paint shaker. When the new truck buyer brings their paint shaker in for repair - GM will tell them that it is "normal" for new truck engines to knock, and that they should buy earplugs.
If it is "normal" for new GM engines to knock - Why don't they all do it?
It is too bad that GM evidently cannot consistently manufacture "full size" pickups that don't knock. Many truck buyers shun diesels because they have too much engine noise. GM says engine noise (up to paint shaker status) is normal!!!!
Ford had a manufacturing defect a few years ago that caused knocking. They hid their heads in the sand for two years claiming that it was "normal". Eventually, they relented and honored their warranty. Why won't GM do the same?(without waiting two years) and pissing off all of their current loyal truck buyers.
I-force toyota engine has knocking
problems too.....
What about the sludge issue toy denied !
Been reading about the toyota dealers
attitude is in denial like GM......
#1136 of 1136 Get it back on track guys... by pf_flyer HOST May 13, 2002 (04:22 am)
A point well taken. The point of the topic is to have a place for Tundra owners to discuss and share information on problems that they may be having with their vehicles. Hopefully the information will be helpful. Flaming each other and each other's choice of trucks is NOT.
This nonsense of trying to prove that one brand is better than the other by taking shots at each other is WAY past old and needs to stop.
PF Flyer
Host.........
Shouldn't you be telling Bamatundra and the other Tundra owners who come in here posting the same redundant post 10 or 15 times that this topic is for Chevy/GM owners to post and discuss their problems??????
I think you should be consistent don't you?
Bamatundra has posted the same garbage in this topic and other GM related sites at least 15 times.
Might as well shut this topic down, as there is nothing but Tundra trolls posting to flame GM.
Tom
Are you feeling just a little insecure about your knocker?
http://www.lemonlaw.com/lemonlist.html
Call now! 1-800-LEMON-LAW
The services are free. You have nothing to lose except your LEMON!
I'm not the one posting misinformation. I just feel sorry for you disgruntled import buyers who settled for less than full sized trucks.
Tom
I admit that I am surprised to see Quad post to a Chev topic - he is usually lurking in Tundra topics posting how HUGE his truck is. That's funny - Tom is also bragging about how HUGE his truck is. Oh well.
Now - back on the subject. Do you think that Chev will ever repair the knockers or will they just cut their loyal customers loose? Do you think that someone who bought a knocker will ever buy another GM vehicle?
GM's short term money saving decision could cost them in the long run.
"You might check your misinformation. This is the first time I posted about GM engine knock to this topic."
Well, what do you have to say about this little statement you made?????..........
"1569 of 2145 abottorff by bamatundra Nov 22, 2001 (12:03 pm)
"I noticed while trying to track down my pinging problem (#1533) that my throtle seems to stick if you hold it at fast idle 1500rpm then realease or quickly press the throtle down and release it seems to take a few seconds to come back down to normal idle (500 or so) is this normal?"
Unfortunately, you will find that GM says that ANY problem they can't fix cheaply is "NORMAL" . This includes excessive oil consumption and engine knocking.
My advice: Trade it in on a Tundra soon."
......Can your credibility get any LOWER?????
LOL
Tom
You said your post 2139 was the first time you had posted about the GM engine knock in this topic.
BUT......
We have proof you posted about this in post# 1569, post #2136, AND post #2139. How embarrassing this must be to you!!! Would you like to apologize for saying I provided misinformation???
Tom
Have no idea what it was, and haven't had a chance to look at it yet.
Anyone else ever deal with this?
Quad - 20
Truthteller(sic)- 3
Sonja - 20
KG11 - 7
Oby - 6
Tom - 7
63 posts in the last 13 days - and Tom is whining about three of my posts in the last 6 months!!! LMFAO!
You are calling me a hypocrite??? When you can't refute the facts, attack the the one who posts them???
I apologize to all the Chevy owners who came to this topic to discuss their problems, for ruining so much good "white space" with proving what we already knew.....Your posts are tripe, and are not to be believed.
I'll not respond to any more of your worthless drivel.
Tom
How many posts have Quad and Sonja posted to the Silverado problems topic in the same time period? See what I mean - there are a few misguided Chev owners that inhabit any Tundra topic. They seem to prefer posting to Tundra topics rather than GM topics. I cannot understand this.
Could it be Tundra envy?
