Example of body mounted guards
Example of no drill frame mounted guards
Second example of no drill frame mounted guards
review of second example rocker guards
Last week I made several trips into downtown L.A. with the manual. By the second day of driving in stop and go traffic, with lots of traffic lights, I was VERY glad that I don't have to do that very often - if your commute has lots of traffic lights or stop and go traffic, I'd think hard about getting a manual. Also, I've been having back problems and the auto is much more back-friendly. So I think the Sport is probably my last manual - I'll stick to autos.
I have body mounted rockers from Toys by Troy and I've come down on them HARD a few times, including this past weekend. Frame mounted ones can be nice, but if you go with a body lift down the road, it may look kinda goofy. Also, at some point, part of the rockers will hang down below the frame and provide a catch point if you drag over a tree root, rock, whatever.
Body mounted ones can be had with internal supports (A to Z Fabrications comes to mind, as does Shrockworks). My TbT's cover quite a bit and I'm VERY happy with them. They have a tube on the outside to provide a pivot point against rocks, protect the sides against gully walls (Turkey Bay has a few of those) and act as a step for my wife.
This model is similar to those available from a number of sources. Places like Q-tec are okay, but you can get em cheaper usually directly from the manufacturer. A to Z, Toys by Troy, Shrockworks, Rokmen, Kilby, AEV, all put out variations on these things.
Jeeperman does make some frame mounted versions, but I like the black armor up the side of the tub as well...
-Paul
And the photos show a might fine looking rig, too!
Art...
-John
Just curious how folks feel about the Jeep Mopar rock rails in the Jeep Accessories Catalog...I assume for the money you get better protection and quality from other manufacturers?
Under "Heater Control Replacement" (section 24-32) it says:
1. "Remove instrument cluster bezel attaching screws. (6 screws attach the bezel to the face of the instrument cluster.)
2. Remove instrument cluster bezel.
3. Remove screws attaching heater control panel to instrument panel.
4. Slide control panel outward..." (toward you, I guess.)
At this point, you should have the back of the heater control panel exposed, and the wire to the heater control light should be apparent. Presumably you can access the light bulb itself from the back of the heater control.
Bob
Generally, that would not be a correct assumption. Most of the time DC will source this type of product from a reputable aftermarket supplier and just stick a Mopar label on. Alternately, a slight variation may be made on the basic original design. Comparing pictures in the various catalogs can provide a mild form of entertainment.
these are the mirrors I have, I like the fact that they are big, its a trade off for the wind they catch and move while on the highway.
jts
Any input appreciated. Thanks. Also, if there is a better alternative, please bring it to my attention.
Are you running Truxs tires? What size? Did you have any problems getting them balanced?
How do you like them off-road and on?
Thanks, Scott
At best, you can move the horspower curve to provide maybe another 20 bhp at the very top end, but you'll lose it lower down, along with that nice torque that kicks in at just over idle.
If you really want to add noticable power, and have it available throughout the whole rev range, then fit a supercharger, preferably the vane rather than centrifugal type.
Finally, whichever route you choose, you open yourself up to possible warranty problems if you have an engine or powertrain problem down the line.
-unzip/remove the side windows
--pop the rear bar out of the receivers on either side of the tailgate, and unzip & roll up the back window and fasten with the straps
-pop the tongue out of the channel above the windshield. there are two tabs that slide over "buttons" on each side to lock the door frames in place, so slide those back and release.
--from here it should be pretty obvious, just slide the top back behind the rear seat. YOu may have to undo some of the snaps on the door frames to get it to fold.
--half doors are obvious, undo the snap and pop the tongue out of the groove, then lift up
Balancing? Up to about 55 they are smooth. I have a vibe on the highway that I need to have addressed, but wanted to wash my Jeep before taking it to a place to balance (too much mud on the wheels! ) Once I have them balanced, they will be golden.
On road, they are fine (except the vibes over 55). Offroad, they are incredible. I only got stuck once on my first trip with them as I got high centered a bit and just not enough traction to get me unlodged from a rock hugging just in front of my rear bumper. Nice scratches tho.
I was in some mud - got through no problems. Climbing - great grip. No complaints at all here.
Balancing is probably the only issue you have to worry about. Make sure they balance it up to about 70-75. With my gearing and engine, if I ever made it to 80, I'd be surprised (2.5L and 4.88 gearing). I did get to 75 tho.
Here's the Jeep after done wheeling and gassing up to go home...
Seriously - wet sand + heavy vehicle = bad times
If water got into the bay, it may be okay, but I bet the electrical is goofy from here on out. The engine itself may be fine, as long as it wasn't running and no water got into the engine.
-Paul
I sit in Touraregs at the auto shows, and would love to have one as my "nice" sedan vehicle. They are REALLY pricey. I can't imagine taking one that close to the ocean...
You should send that in to 4wd or Jp for their worst stucks section.
While in school we were in the Virginia Beach area attending a concrete canoe race hosted by Old Dominion University at Mt. Trashmore Park, we decided to camp at one of the waterfront campgrounds. One of our campers, after imbibing some liquid bravery decides to take out his 4wd Ford Ranger for a drive with a buddy. Who knows how much later they both come walking back, jeans wet to the belt and very, very cold. I think it was March. Long story short, Nimrod got his truck stuck on the beach and the tide was coming in. We didn't have anything to pull him out with so he had already called a tow truck. Tow truck number one wasn't capable of pulling him out so they had to call tow truck number two. (It appeared to be a carefully orchestrated procedure, sending the whimpy tow truck first.) Luckily water did not get into the cab of the truck before it was yanked out. Good thing he got out or we wouldn't have had anything to tow the concrete canoe home.
Oh well, made for some good stories and chuckles on the way home.
I've been really considering the electric Wrangler fan conversion (takes off the clutch fan and replaces it with an electric and thermostatic on/off switch). Mostly, I was going to do it for the mileage gain it supposedly gets. What do you think of this? Supposed to really reduce rotating parasitic drag (according to the manufacturer). Quadratec carries them.
The standard fan only comes into play when the cooling system temperature rises above a certain point, usually at a slow forward speed or when under a heavy load. When it does kick in, it has the potential to cool things down very quickly as the blades are at a relatively coarse pitch, and they have all the power of a gas engine to drive them.
An electric fan has a much shallower pitch due to the high current draw of an appropriately sized 12v electric motor. To even come close to matching the performance of the factory unit, an electric fan will have to run much longer and it will cut in earlier. Power for the motor will have to generated by the alternator (which costs gas). This will cool ok in the majority of short use situations, but for more continous operation it won't match the OE unit, either in efficiency or economy.
In terms of gas consumption, I doubt you could measure any difference, plus or minus, but there's probably a 'feelgood' factor. If you do get one it makes sense to wait until the standard clutch fan fails, and make sure to get a 'puller' rather than a 'pusher', as it's more efficient.
I have often thought about replacing my belt driven fan. I am convinced mine is "engaged" most of the time. I can hear it wind up shortly after I crank up. Also the air it stirs up blows the paper towels and light stuff I have hanging on the walls of my garage. Even cold, It is very stiff to turn the blades with the engine off (same warm). My local dealer won't even consider if it is bad. I think it is costing me mpg.
If you do it, I want to know the results.
Terry
Bestop, I believe are the makers for the OEM top. There are others out there, but the Bestop quality is really hard to beat. I have a 97. I replaced the original, single-ply top with a sailcloth (3 layer) replace-a-top. It is fairly quiet, looks great, and fits like a custom glove.
-Paul
P.S. Please turn off your caps lock..........it's usually a way of indicating that you're SHOUTING! :mad:
When you put on the 3 ply sailcloth top did you notice much increase in the bulk when it is folded down?
I have a boot cover I like to use, however it fits pretty tight over folded down single ply top that came on my 2000 TJ.
Terry
Take a look at - it's a good place to make albums and post pics of your new Wrangler.
It is a bit bulkier, but I've never tried to cover it with anything, not even the tonneau cover that I THINK is the model to cover the top when down, but I'm not sure.
However, when I drop the top and it stays attached to the Jeep, it is usually like that for a day or less, so I don't worry about covering it. It will sit entirely behind the top of the rear seat or just a bit above. Definitely below my 30" spare I had when I was running 30's.
Once it gets warm enough here, the top will come off entirely (including frame) and my safari top will be the cover for most of the summer (along with a RainGear cover).
-Paul
Welcome and congrats on that new Wrangler. It's a purchase that you will never regret!
Glad you have joined us here. Just make yourself at home, and let us know when you get some pictures posted somewhere. As Steve suggested, there's a great place right here in Edmunds for posting your vehicle-related pics.
Tom
Have you hugged your Jeep today?
Rock Gear Inc.
1515 West Apache.
Farmington, NM 87401
1-888-765-4327
Price was about $350 which is pretty reasonable considering it works as both a soft top and a bikini/safari. Very easy to take on and off. It's the same fabric as a non-sailcloth soft top from Bestop or Jeep, they use the Haartz fabric and you can get it in factory colors or lots of other colors too. To turn it into a bikini, you loosen up the rear straps, roll up the windows, and zip them into the top. Pull it back from the windshield and it collapses very tightly behind the rear seat.
Not sure what you mean by secure. It's a soft top. Anyone who wants in can get in. Does it keep the elements out? Yeah. You can get it with or without the door surrounds. I got it without because I take the doors off alot. So instead there are these elastic door surrounds that keep the water out, but if it's really coming down you need to pop them on the outside of the doors which takes 4 or 5 seconds.
The fastback look is pretty hot though, and you'll never be without your windows. I picked up a pair of soft doors too so I can go anywhere now in the summer and not get stuck somewhere without doors/top.
I'm ready to put some bigger tires on my 01 Sport and possibly replace the carpeting with some kind of rubber liner (not sure what's out there, but I seem to remember hearing about this concept at some point). Anyway, I'm wondering if anyone knows a good place to go for such things in the DC/Northern Virginia area. If not, I'll just shop around.
Thanks a lot.
-J
