Chevy Silverado/GMC Sierra - Owners hangout
I have never paid that fee so I would shop around and try to negotiate it out. 500 Is too much even if you had to pay it.
Is your 94 fuel injected??
this is just another reason to negotiate an out the door (OTD) price. Because many dealers will play the game of agreeing to a "price" and then piling on "dealer" costs after you think you are done.
Her EGR gets plugged up with carbon and it runs poorly, SES light on, eats gas bad.
Mechanic pulls off EGR and cleans out the carbon
Runs like new ! It has happened a few times.
WE bust on her cause she drives like grandma and tell her she need to BEAT on it once in a while.
She only has 50K on it !
To solve carbon buildup problem I found a mfr. of EGR gaskets with a screen in them to keep carbon chunks out of the EGR. Tamco Co. makes them 10 bucks!
Our local indy repair shop sees a lot of this in GMs and Fords of those years and keeps them IN STOCK ! 10 bucks is cheaper than $200 that the dealer wants to replace the EGR instead of cleaning it...........................geo
I have the old 350. I do not have the vortec. It is fuel injected. I am told it only has around 200 horses. I am going to check the muffler out. I will also check on the gauge as well for the compression test. Where is the egr located?
They did check the converter for a clog.
I really appreciate everyones suggestions.
After you do that start the vehicle then let it run till it dies, then crank the engine over 4-5 times for about 3-5 seconds. This should relieve the fuel pressure to allow you to change the filter.
I know the Dmax is awesome, but it is not worth the health of my family. Besides, the 8.1L costs about $4000 less and gives very close to the same performance. I know the gas mileage sucks esp. when towing, but $4000 will buy a LOT of gas.
1) Under light load while driving or even with the auto trans in neutral with truck stopped, have a light vibration in the 1000 - 1500 RPM engine speed range. Can feel in the steering wheel and dashboard. Engine is otherwise pretty smooth - idles OK and quite smooth above 1500 RPM.
2) Under moderate acceleration there is a slight "rattling" type noise from engine. It's not pinging, nor sounds quite like detonation. At steady speeds engine is quiet and under heavier acceleration the "rattling" seems to be barely noticeable. I have read some auto mag road tests that commented on the GM pickups having somewhat noisy engines.
So I'm wondering if these two traits are inherent in the 4.3 engine or whether I should take to dealer service dept? Anyone else have any experience with such things? Thank you.
So far the new truck is great, many improvements over my 00.
Spotted a 65 Chevy c-10 old guy driving...Mint, (faded)original paint wow ! (exactly like the one my dad had and I learned how to drive in...6 banger, 3 on the tree!) Older cars too 70s-80s all over !
Man, you don't see iron like this in northern NY rust belt and salt land except at a car show!
BOWtie: Yea 303 is like armorall etc. Some guys swear by it ! But pricey $$$$. Heck I have used both....They all run off my tonneau cover when it rains..making streaks down the side of my truck!.................geo
thanks for your feedback. Is there anymore insight that you can give me on the locker, as I am convinced that it may still be broken?
It just does not seem to work as well as it used to. It used to lock up when one tire was in mud and the other one was on pavement; now it'll just sit there and spin.
thanks again.
I have a V-6 too and can hear a rattle when the torque converter is locked at low speed in overdrive (from 36 mph to about 45 mph); it is the driveshaft rattling. There is a TSB on it, but I am OK with the noise. I like the trans locked. I have driven a Dodge diesel that made the same noise.
That website: http://www.aam.com/
http://www.torquecontrol.eaton.com/
I also have the hard shifting problem [noticed it when test driving it} from 1st to 2nd gear. It is only getting worse. If anyone has found a solution to this problem PLEASE let me know because the BtoB warranty runs out Jan. 1 of 2004.
My 01 2500 pulled to the left when new. Dealer said they realigned it twice before I signed on the dotted line........Still pulled.....
2 weeks later the right front wheel FOLDED IN !
YUP, No nut or cotter pin on upper ball joint !
Lucky me....It happened when I was pulling out of McDs SLOWLY with the kiddies after they won their softball game...
Man..If it happened at speed.............
Aside from that NO problems in 2 1/2 yrs. And I work that puppy towing, hauling, and snowplowing!
Good luck !.............geo
Mine does...But I love that FIRM 1-2 shift !
My Caddy shifts ya can't even feel..Unless it at WOT....But we are comparing apples to oranges on the 2...........
It happened again after that and when I rotate the tires the problem goes away. Dont know if it will work in your case but it may be worth the 20 minutes to try it.
The update is that the dealer determined that the tire is the problem with the left pull. So they have ordered (under warranty) a new one and will call when it is in. I’ll let you know how that goes. The hard shift for the transmission was solved via a computer update. It DID solve the problem. It did it hot or cold so now I need to test it and see how long the fix lasts. Nice and smooth now.
On another note; I have the Z71 w/towing package. What size trailer in tonnage is to much for this truck. The wife wants me to get us a camper but am a little dumb on just how to figure the GVW and stuff like that. I pull a small U-Haul box trailer once in a while but she is talking about a BIG boy now.
Any feedback would be welcomed.
Anyway, does anybody have experience with this, or a diagram of how to get this back together/adjusted properly?
Just took it apart today, 'cause I am off work due to the electric outage
Is this a normal junk part?
Steve
If you really like the truck, and want to keep, you may want to look into a complete motor swap with a rebuilt unit. If you have the means to pull the engine and necessary components from the engine, you can probably find a replacement motor for $1000 to $1500.
matthew
yeah guys I been "lurkin"
I have a chilton book but it doesn't say. I need to do a dynamic compression test tomorrow. I will give the results of it and the static, that i did today, tommorrow. My reading ranged from 175 to 190 before they topped out. That usually took around 8 turns. I figure the 190 is about 10 high because those 2 plugs also had excessive black carbon build up so I figure their is also carbon build up in the cylinder which will cause compression to increase. Most were around 180 but I wonder if that is what I should have expected. Every cylinder was about 10 less if I went 4 cranks. Here is the static. Why wait.
4... 8 ... wet ... ..... ... 4 ... 8
176/187 .... ....... .... 171/180
170/175 .... ....... .... 180/190
174/181 .... ....... .... 170/180
138/145/180 .......... .174/181
Front
4turns/8turns/wet(oil) These are what the abreviations stand for.Their was very heavy carbon on the 190 and 187 cylinder.
One additional thought, Camshaft, it may be time to take a valve cover(s) off, start the truck and watch rocker arm movement. If the cam lobes are worn and 1-2 intake or exhaust valves are not opening all the way tis could seriously impact performance and fuel usage. Also ask someone how to measure voltage to each cylinder.
This has taken me back to the days of street racing where we couldnt afford to pay someone to fix it or change it, we did it ourselves.. Thanks!
So the conclusion-- upgrading to $30 dollar plugs (for 8) cost me alot of time and gas and money to figure out not only do they not improve my performance but they made it worse. I should have stuck with the $12 plugs.
Thanks guys for all of your help. This problem would have cost me much more if I would have had someone else do the work.
Congrats on finding your problem. That one would have been a stumper for me also. Sure is a relief to find you can fix a prob for $12 and 30 minutes, instead of $1200 and a day or 2.
In my years as a GM fanatic..I have learned to use only AC plugs in my GM vehicles.
The armrest that comes on the 2000,etc. Sierra Ext Cab with the split seat has a design that is not that comfortable as a armrest. It is hard to find a comfortable position for the arm with that depressed hard center section of the folding armrest. Just curious if others have found this to be true and if a fix has been found. Thanks.
