Chevy S10/GMC S15-Sonoma: Problems & Solutions
13435373940
    leighhleighh Member Posts: 5
    Hello, we have a 94 auto Sonoma and we cant get it to move in reverse, it we put it in drive it will go if u put in N it acts like if it was in Drive. my son has auto class at school and they changed the transmission fluid and filter, he made it home just fine shut it off went to leave and to back out and wont move... :sick: any ideas what we need to look for or check? anyone else have this kinda of problem?? if so please share what we need to do...
    thanks much
    Leigh H
    hubby said he thinks the linkage is bolted down not sure :confuse: he said they added 4 and half quarts. this dont mean the transmission is going out does it? he is a teen we are trying to get by with this truck til he gets himself a good job:0) the truck is in really good shape for 94 just hope this dont sound like the trans going out? what are the signs of transmission going out??
    thanks for posting and sharing tips with me we are lookin for anything we can do to fix it :shades:
    thanks again
    Leigh
    jeffro07jeffro07 Member Posts: 3
    i JUST BOUGHT A 2002 S-10 ZR2 4X4 EXT CAB WITH THE 4.3 VORTEC AND ONLY 51,000 MILES ON IT. mY BIGGEST PROBLEM IS THE ENGINE FEELS SLUGISH ON BOTH TAKE OFF AND AT HIGHWAY SPEEDS. With the a/c on is really bad, i bought an after market air filtering system that didnt seam to help. It still has a 3000 3 month warranty but you know how dealerships are on problems ... they never find anything wrong. Any sugestions? really would like to get more out of this and alittle better gas milage too.
    Thanks alot,
    Jeff
    gonogogonogo Member Posts: 879
    If reverse was OK before the filter and fluid change they may have knocked off a solenoid connector, if so back track.
    :P i JUST BOUGHT A 2002 S-10 ZR2 4X4 EXT CAB WITH THE 4.3 VORTEC AND ONLY 51,000 MILES ON IT. mY BIGGEST PROBLEM IS THE ENGINE FEELS SLUGISH ON BOTH TAKE OFF AND AT HIGHWAY SPEEDS. With the a/c on is really bad, i bought an after market air filtering system that didnt seam to help. It still has a 3000 3 month warranty but you know how dealerships are on problems ... they never find anything wrong. Any sugestions? really would like to get more out of this and alittle better gas milage too.
    Thanks alot,
    Jeff
    flipper3flipper3 Member Posts: 10
    by bogging is it more of the truck sounds like it is winding out and should shift but it doesnt for a while and u arent haredly moving at all?
    thanks for responding to my post, can u please share how to check for this? also do u think it could be this even tho the reverse worked once after changin the filter and fluid, cause he did have reverse but only one thim 2 time it wouldnt move..hope the transmisson is not going out does it sound like it could be?? or maybe something simple? how does one act when the transmission is going out?? would u still have drive?? whats weird it its like when u put it in "N" it takes off like its in drive, drive works but when u put it in reverse it wont move at all...any tips??
    thanks much
    Leigh
    Was the pan clean when the pan drop was done and the fluid not burned? Usually when the vehicle will drive in N there is a welded clutch, won’t disengage. Will the transmission be locked when in park, that would be a good linkage check, just rock it in park. That transmission also had an issue with the sun shell breaking, no reverse and also no 2nd or 4 th.
    Yes kinda, its like if i take off it seams like i need to really press the gas to get it to move i would never try to pull out quickly cause it would never do it. Now at times it seams alright with plenty of power i dont know if its starving for fuel or a electrical problem. Thanks alot for the reply im just not sure and thought maybe this is an on going problem with the 4.3.
    Jeff
    hi me again, we tried to rock it it seems to be locked in park, when he had it at school when he very first took the pan-filter off to change it and the fluid he said it smelt burnt. but it was drivin fine with all gears, so im not sure whats going on, its weird thos it will run just fine in (D) and and (N it goes as if its in drive. and (R it dont wanna budge at all :confuse: its a 94 Automatic its getting some yrs on it but was running real good, wish he would of never made any changes :cry: so any other things we can do or try?? im having him take it back to school tomorrow and hope his teacher might be able to help in some way
    hoodlatchhoodlatch Member Posts: 255
    Hi Jeff,
    You might check the underneath. Has it been off-road alot? One time I hit a chunk of metal in the road that put a big dent in the cat converter (among other goodies) that caused internal damage to the converter. The result was poor performance due to restricted exhaust.
    i see, okay im a chick here HAHAHA dont know much about cars or trucks as u can prob see :) so in your case what do u have to do to fix your prob? i hope its something simple on our part and not the big T word..hahaha that would really stink :sick: having son take it back into school tomorrow to see if maybe his auto teacher can help us out, what gets me it ran fine before this....boy i wish he would of left it alone now cause at least it was running all gears okay..no its just good in drive...thanks for postin tho anything else we can try??
    canufixitcanufixit Member Posts: 165
    Hi oldoawdad (and thebigal).
    Tailgate cables; Mine broke when I was standing on the tailgate (Thankfully I was not handling a heavy object or I could have been seriously hurt.) The Factiory cables are not sealed at the crimp ends - so when the tailgate is shut - water can run down the cable (iniside) and sit inside the cable covering and just rust the cable and you don't even know it .. Dangerous if you ask me ...
    You should at least "Feel" your cables over its full length and try to fee for rust buldges ...
    On this site someone posted a link for NAPA (I think) for replacement cables - I bought a set and kept them - and then had to use them !! The cost - I think - was about 15 Each (maybe less) ?? But the b!tch is changing them. You have to remove the latches from the ends of the tailgate (Get inside the tailgae to disassemble the rod linkages), remove the latches and then mill off a pressed in stud to remove the old cables (new pins and E clips are in the NAPA kits.)
    I got lucky on the install and had not real issues (but you could drop the rods and internal parts in the tailgate if you are not lucky !) and I also have a small milling machine - so it took me only about an hour+ to change these ... But I expect two or more hours for others who have to fudge with the studs and have less tools - and have worse luck.
    To all - Please at least CHECK your cables !!
    Canufixit
    Hi leighh,
    My inputs.... And I agree with previouos comments ...
    "Usually" the Auto transmisison fluid is changed once well before 100K and then left alone - unless there is a real need to change it (i.e. burned or othe issues ..).
    In fact many of the std repair and fluid shops I know just will not change the oil once it gets well over 100K - because of the issue you are having - "it "was" Ok and now there is an issue " - and the shops just do not want to get caught up in that. (Regardless if the fluid change itself had any connection to the issue - as a transmission with lots of miles could have a many issues happen at any time - and the oil change facility does not want ANY issues being pointed back at them for the little thay make on the fluid changes ....)
    With that said ...
    As it "Was" OK - and it started so suddenly - I would suspect the oil change. I'd immedately check the fluid level (On a flat parking area, Engine and Trans Warm - and the dipstick level correclty seated and read - multiple times.)
    FYI - The amount of the fluid to change depends on the type of fluid change process done (just by draining is different than also changing the fluid in the Torque Converter, etc.) - Regardless - if you check the level properly, nnow that it's been driven a few miles - proper oil level can then be confirmed and possibly excluded as an issue. (If it was driven on very low fluid level - that maybe a cause of your issues as well... The Transmission uses the oil for Pressue, lubrication AND cooling) - Also - does the new oil look and smell OK ?)
    Secondly - as thebigal and others eluded to - when you change/ do something and then immedately have a problem - I ALWAYS go back to the last thing that was done/changed/fixed, etc and re-check everything again.
    When you remove the Transmission's oilpan - they are working very close to shifter linkages and vacuum solenoids, etc. as well. Bumping these, cutting/cracking/bending these - or disconnecting these - are all real possibilites and easy to repair. You need to have someone look under the vehicle and around the transmission (top, bottom, sides, etc.) for any loose or broken slit/cracked hoses, Shifter linkage not bent/broken disconnected, etc ... and chack the Engine compartment as well !!! (near the oil fill hole - and check all vacuum hoses !!)
    Also, I did not like the comment that the old transmission oil smelled burned when changed - it may mean you had a problem already with the transmission - but not necessarilly. Oil old that may have been over worked and possible overheated due to an engine overheat may cause the oil to breakdown smell burned anyway - and if so - it really needs a well deserved change anyway.
    And Finally - If the above is not the soultion - before I drove it too far (and maybe make it worse) - I'd take it to a reputable shop that will re-change the oil and screen and have them look around the underside as well. They may find an easy fix (i.e. oil pan gasket / screen is incorrect one - or incorreclty installed, foreign matter in the screen (The did not take off all the cellophane wrapper) , etc.) - and they may see a slice in a vacuum hose, etc - and hopefully they basically just charge you for the transmission service (What's that cost now - $100 to $200 at the dealer ??) This would be money well spent if it fixes the problem - and if not - it's not a whole lot of money in todays repair dollars - and you can then decide if it's really the tranny and decide to replace it, trade it in (if possible) or scrap and by another vehicle ...
    Hope this helps !!
    (people always call me and say ... Canufixit!!)
    Oh Yeah - your operators manual for your vehicle may say to check the fluid level when the truck is running ...
    Any time I ran into a trans that went in N, it was always a burnt clutch, welded, sorry.
    oldpawdadoldpawdad Member Posts: 14
    You're right about the hassle of changing them. I don't remember having to do any milling, but can't be sure. I would have used a grinder. Did drop them several times, but with a coathanger and hooks at the end, it's not too bad. Save the old hardware and make up a set of your own!
    Re: Tailgate cable - Here's what I used - Posted for ref for others.
    Each Came with new hardware. Just remove the Latch, grind off the rivet - change cable w/ new hardware (Sholder bolt + e Clip).
    10.99 ea for a 2002
    http://www.napaonline.com/masterpages/NOLMaster.aspx?PageId=470&LineCode=BK&Part- Number=8195739&Description=Tailgate+Support+Cable
    i think that it might be because mine does the same thing. mine only does it sometimes finda like the truck governs itself down into 2lo
    Hi Jeffro07 , flipper3,
    Mine does something similar - but only when cold at startup. It did this since it was new. The "Dealer said" this was a "start up sequence" when cold. It turns the fan on for a minute or so - to exercise the fan clutch / circuit - and then the computer (knowing the engine is cold) keeps it in lower gears a little longer to, I believe, give you the power at low RPM until it warms up a tad. Usually after a cold start and a very short drive (a few hundred yards or so ) this goes away. I have no issues later at any other time (i.e., high way)speeds). I do not even notice if / when my air compressor kicks in when the engine is warm - but my fan minght kick in when ever I have the AC (or defroster) on - I'd have to confirm..
    I'm kinda wondering if your temp sensor /circuit is OK - the computer might think it is in start up Mode all the time and keeping the fan on, keeping you in gear a little longer and of course probably give you some extra fuel (that's normally just gioven at cold engine start) - this might expain the bog, the shifting and the low gas mileage ... By the way - I get 15- 18 MPG in rual driving and about 19 MPG onthe highway (with out A/C or Defroster on). This seemed to be normal for others I polled (I have a 2K2 4.3 ext cab).
    Just my thought ...
    Canufixit
    no surprise, you know almost all of the S-10s were made in shreveport louisiana, thats what i get for buying a car made in my home state.
    You had overheating problems - I think you were all set - but wanted to ask ....
    Canufixit
    braindeadbraindead Member Posts: 1
    I have a 93 Chevy S-10 P/U, extra cab 2.8 5-speed 2wd, my tail lights are pretty bad, if you hit the blinker, they all blink, including the license plate lights, brake lights work, but when night time comes, i turn on the headlights and parking lights and the tail lights shut off and my blinkers do not work in the front or in the back. I NEED HELP!! ive been getting too many headaches. I put new fuses, relays, flashers and bulbs in. I cleaned up the tail light ground and put a new eye-loop on it. All of the bulbs are in the right places too. Can somebody please help me. It would be greatly appreciated. Thank you.
    I'm "Not"the expert on Auto Trans - and therfore leave all the actual work to the pros ... Although I've been lucky enough not to have had auto trany issues).
    My Suggestions on the post you reference are my best advice "in General". What I recommend is that you take to the Dealer (or perhaps ask a couple) and ask their recommendation. They may back up my earlier advise - or - they may suggest another oil change. Providing that they look it over first, decide it has no issues and guarantee the change of oil and filter will not cause an issue - I'd spend the extra dollars they charge (vs a quick lube shop) and have it done at the dealer.
    I just don't like changing the oil at over 100K unless there is a reason to do so... I belive my manual list the initial change at 60K and then nothing after that is mentioned...
    The Auto Trans, in my opinion is a fickle part. Providing you do do not cause an issue (overheating the engine/transmision cooling) and don't beat on it - it's still a dice roll - you either have a good one for life - or a bad one. I've run my last few vehicles up to around 160K with only the fist oil change as specificed by the factory ...
    So go to the Dealer - and let us know what they say - and what you actually do ...
    Canufixit
    dkurrledkurrle Member Posts: 20
    Does anyone know why my idle would be pretty rough? It idles at about 500k, or a tad higher. Doesnt sound or feel right when just sitting at a stop light. Only has 30000 miles. Any ideas?
    Well.... Could be a lot of things. How About some more info ... Been like this since new?? Only recently? ANy work done recently, etc ....
    One quick thought - At nightime in a dark area when it's runnning rough - Open the hood and check to see if you see any sparks jumpoing off the wires (and if you do DO NOT touch these until the engine is down ...). 3-4 years old now - possible a wire is cross shorting or loose on a plug ..??? We need more info ...
    royboy732royboy732 Member Posts: 1
    Hi, I have a 1990 chevy s10 and whenever it is put into four wheel drive the tires toe in to the point where it cant be driven (BAD). The truck is lifted by means of torsion keys and new control arms. Does anyone know what could be the problem. Could there be something wrong with the steering components or possibly the balljoints? Thanks alot!
    Your front end and linkage (Tie rods, Connecting link, Control Arms, etc.) must hold the tires in the specified position. If the tires can toe in and out so it "can't be driven" you have major worn part here. I'd be reluctant to even drive it to a repair shop if it's that bad. So, Push/pull it to a decent alignment shop and have them check out the fron end and give you an estimate - although for it's age the repain my be more thant the truck ...
    Canufixit
    shakey_joeshakey_joe Member Posts: 1
    hey on my blazer i had the same thing happen. so i changed the fluid & filter and it fixed it. but be very, very careful that you do not unplug anything in you x-msn pan. the plugs in the pan are for your gears. it lets them know then to change and what gear to change to so be careful.
    if you do it yourself there is going to be a big mess, so get a box and line it with trash bags. this should do the job for the fluid.
    friendzfriendz Member Posts: 1
    did you ever find out what was wrong with it, im having the same problem, if you did could you throw me a ling at friendzhahnhonda@yahoo.com
    herronthreeherronthree Member Posts: 1
    Hey all, I have a 2000 Chevy s-10 4x4 with a 4.3. I love this truck and all seems well except for a whining sound when the transmission is engaged and then while moving. It sounds unnatural and want to know if this is normal or if I should get it checked out before anything worse happens.
    Any input is welcome!
    curious_gearscurious_gears Member Posts: 60
    i would definately get that checked out, as my dad's s-10 transmission began to whine and soon spun the gears or something. it happened when we were on our way out of town to head up to the hills for a day. he noticed the whine a few days earleir and thought nothing of it, as did i. bad, bad mistake. while going up a hill all of a sudden we heard this wretching screetch and a clunk and the engine raced extremely high, prob. well into the danger zone before he let off the gas. lets jsut say it hasnt moved since. of course, this was right after we got the front end fixed because of shaking, jsut our luck
    sorry, just saw the new reply. I have only owned this truck for about a month now, give or take. No work done that i know of. i will check the plugs for sparks and see.
    Also why would the cigarette lighter blow a fuse everytime its pushed in? i can put my phone charger in it and it will work. crossed wire somewhere? how can i find out where.
    Your "shorted wire" is your cigarette lighter.
    how can i fix that? Also i didnt see any sparks in the dark.
    rickneal128rickneal128 Member Posts: 1
    I had that problem too. Seams that an oil leak on the O2 wiring caused the problem. Something about it effecting the current. Replacing the O2 wireing by splicing was what fixed it.
    Rick
    thazardthazard Member Posts: 2
    This is a distributorless ignition system, with MPI fuel system. Sometimes runs for a a minute or so, sometimes just a few seconds. Dies abruptly with no sputtering. Scanner reads no error codes. Have visually inspected everything I can think of. Fuel pressure is within specs. Fuel regulator is working. Battery cables and connections at battery clean. When engine dies, dash lights come on. I'm at the end of my rope. Any suggestions would be GREATLY appreciated.
    022415022415 Member Posts: 2
    I have a 1991 chevy s-10 w about 120k miles. The truck has always run very smoothly. After seeing a noticeable leak of coolant I flushed out the radiator. After refilling and waiting to observe the leak I noticed that there wasn't a leak anymore.However, now the car was idling very roughly. When driving there was now a hesitation and stuttering in the acceleration. Additionally there is a knocking sound from the (air)filter area and the engine shakes a little. The car idles very shakily but doesn't conk out.
    Hey, I don't have answers, but I have had the same sort of problem, along with a green (acidic?) buildup on the bulbs and in the taillight sockets.
    Check to see if you knocked of a plug wire ...
    alvinlalvinl Member Posts: 5
    I have a 2001 S-10, Crew Cab. You can have the radio on and the display says it is on and receiving a signal. You can not hear it. You turn up and down the volume and still nothing coming out of speakers. Sometimes you can turn the truck a certain way the speakers may come on, sometime it is opening or closing one of the doors, a person may just sit on a seat, hit a bump in the road. It may blast you out of the truck when it comes on. Sometimes when it comes on the speakers appear to increase in volume right after you can hear them. It has gone as long as two months and not play then comes on for several seconds or may play normally for a week. Any suggestions on how to try and chase down the problem. It is very annoying. The radio has a CD Player and a remote cassette player with it. All was factory installed.
    Did some more checking today. Seems to be an ignition problem. Holding an inductive spark indicator on a plug wire when it quits, the spark stops abruptly. Does not spark as the engine winds down to a halt. Would think that if it was the injection system that quits, ignition would spark until engine stopped rotating.
    Checked voltage to ICM and coils, never looses voltage. Had ICM checked out at auto parts store. Tested four times in a row to make sure unit was warm. Tested good all four times.
    Checked coils as per manual with an ohm meter, both checked good.
    Checked crank sensor as per manual, checked good.
    Plug wire resistance checked within specifications but varied a lot. Plugs looked ok. I will replace them both for good measure.
    HELP! Please!
    boyceboyce Member Posts: 48
    Today windows were fogged up so I switched to defrost setting. After windows cleared I switched back to AC. Noticed I was not feeling cool air. All the air was coming out of defrost vent. Fan was running and the air was cold. Just not coming out of the main vents. The truck has 82000 miles and still runs good. Anyone have any ideas for what might be wrong? Everything had been working fine prior to this. Thanks Bud
    2015 Mazda 3 Skyactive 6spd. auto 2008 Mazda Tribute S 4spd auto.
    OK - It sounds like you have power to the Unit (all the time) and you have an intermittant speaker (all speakers) issue. I assume the ALL speakers are doing the same thing. ...(if you have 4 speaker system)
    Using these as clues (and assuming you are not shorting out on multiple speaker wires. ...) I'd say the issue is not in the speakers/doors - but at the Radio (Common Speaker connector is loose or dirty/bad connection - Especially and common return wire for the speakers (depending on series/parallel speaker hook up)).
    Power and Ground seems ok as it's always on ... Therfore, I'd check the connectors on the back of the unit - possibly unplug and re-plug the connectors. You may be able to get at these from under the dash - but you may have to go through the front (remove the radio/Dash bezel, etc.). Also check to see if you can get there through the Glove box - you may be able to remove the box liner and get in fromthe side. (Be careful ! /you do not want to launch the Air bag !!)
    Another thought may not apply to your vehile - but the later models also have "SCV" or speed control volume (the faster you go the greater the volume to compensate for road noise.). This may be "Muting" volume if disconnected ?? (Just a thought!)
    good Luck and tell us wht you find !!!
    So there are a number of cables for the Radio (Lights (dim at night when the head lights are on), Speed sensor wire, Power, Ground and of couse the speaker outputs.
    You've checked a lot - and all looks good (I feel for you ..). You comment on the no spark gave me a thought. If it was going to stop for a problem - it should give an error code - so maybe there is none (to the computer)??. Can you check the "On" wire circuit from the key switch to the computer and the IGN on signal from the computer to the ICM ??? Perhaps it thinks you shut off the key and is just shutting down ??? (i.e. intermittant contact/wire, etc.)
    THEBIGAL had a similar problem - perhaps the diverters are just "Stuck".
    Just continue to drive it for a while (do a few rough roads as well) and occasionlly during your drives cycle the selector switch through each setting (letting it stay at each stop for a few minutes.) It might loosen up.
    alternatively - you can check for vaccum at the vaccum motors - but you''d have to get under the dash for that - also check the vaccum lines for cracks and splits - especially at the ends.... Get a Chassis manual from GM (or Try alldata.com on the net) and you can see where the vaccum motors are and how to get to them ....
    Howdy,
    If you get the chance - ask them what about persons like me - I replaced mine, after they did rust out, with after markets (as their's broke and I did not trust their replacements as they did not acknowledeg a problem). Will they swap out/ check ones that were replaced by actual failures and if not replaced by spending big buck at a dealer for their "Not a problem" original parts?
    Canufixit
    Lighters occasionally go bad - throw it out and get a new one ...
    Check for some past posts of mine on this suject ... In Summary - if it is your rear end;
    Most all Rear ends whine, the preload (shims) in the pinion grar to the ring gear cause a lot of this issue. If they are not properly "pre loaded" at the factory the whine will get worse as the mileage goes up. This can be fixed by a tech (re set / add/remove shims). Also - per the GM S10 manual - this truck has a sweet spot at about 35 to 45 mph - that's when it's the worse ..
    You will not hear this when it coasts ... Also as there is little insulation (Noise insulation) in these trucks - the road noise, tranny and rear end noise are a lot more noticable in the cab. If it's real bad, and getting worse - I'd get it checked ...
    Thank you for the information. This is a very low usage vehicle (less than 40 miles per month). Its only used if something won't fit into the car or if the car is in for service. The switch position most likely has not been changed since last winter so there is a good chance the diverter is stuck. If that doesn't work, I'll try Alldata. Thanks again, Bud
