Nissan Pathfinder Club-FAQ
I may get sued, but in my opinion it appears to be caused by the infamous Bridgestone/Firestone tires. I haven't heard anyone with Dunlop Grandtreks complain.
The temp. sensor is in front of the radiator (along with the compass sensor) right under the hood latch. Radiant heat from the rad. will warm it up if you are not moving. If this bothers you a simple fix is to put an aluminum "shield" around it (tube with top and bottom open - use a soda can for example). Do not use a steel shield, as it will mess up the compass.
Steve
I guess my point is: you've probably given a pretty good explaination as to how it works, but we still don't have an answer (and maybe there isn't a single answer) as to why so many of us feel that it is inaccurate.
BTW, thanks for your efforts on putting an FAQ together. To bad you can't get a little more cooperation from Edmunds.
http://www.gsp9700.com/
By the way, I have nothing to do with the Hunter company or Bridgestone...I'm just a fan of their products because they've worked well for me.
Please don't take this the wrong way, gdicefresho1. I just want to hear if other people have had the same experience. You're the first person I've heard from that the Hunter machine didn't fix the problem.
-jc
If you still want to try, I heard early on in this shimmy business some other things to try:
1) replace the front bearings
2) disconnect the drive shaft and rotate it 180 degrees (if the vibration stops or lessens, you've found your culprit...if it gets worse, that ain't it) Of course, if your shimmy is completely in the steering wheel, then this isn't it.
THANKS
juanjose
With 265 ft-lbs of torque (automatic trans), the Pathfinder should pull your boat quite well. You'll need a Class III towing receiver. Check out http://www.drawtite-hitches.com/mf_3_86.html for a nice towing setup which, for receiver, ball mount, and wiring, will cost you about half of what Nissan wants for their towing receiver.
If my 3.3 can handle it pretty well, I'm sure the new motor can handle it just fine.
Thanks in advance
thanks.
JL
thanks.
2. Lock all the doors with the switch on the driver's door.
3. Insert the key into the ignition and pull it out six times within ten seconds. This must be done steadily at a rate of one insertion/removal per second. Don't rush it. The emergency flashers will blink if you did it right.
4. On the 7th insertion, turn the key to the ACC position.
5. Press any button on the remote. The emergency flashers will blink again to indicate that it worked.
Your remote should be programmed now.
I've had the door panel off but frankly can't figure how to remove the motor, (I'd be happy with being able to push the window up, but it won't budge.
Anyone done this before? any hints/tips?
thanks!
I appreciate any help!
Thank you so much!
kristi
I've become an instant daddy and need to add shoulder belts to my 88 Nissan Path SE to support child seats.
I can buy aftermarket devices, but how and where should i mount them?
Thaks.
I currently use a 97 F-150, but it has 120K miles on it and I need to go from three vehicles to two. I don't want to have to buy another big pickup. The only real alternative to a Pathfinder is an Explorer, and the quality is poor.
Thanks, Dennis
I am trying to locate a company that provides driver/passenger side chrome mirrors for a 05 Pathfinder. The Nissan dealer states that its only available on the Armada, Titan, and Frontier.
I have seen pictures online of the chrome mirrors on a 05 Pathfinder, but they dont have information on where they were purchased. Any suggestions?
C4L
