Mazda Protege5
I am interested in the Pr5 so I started reading this board. A lot of you are talking about some sort of S-plan. Can you guys tell me what it is, where to sign up and basically how it works? How do I qualify and how do I find out the set price that dealer will charge if i am on the s-plan. Don't want them to screw me on that either. Everybody's quoting 17,500 for auto for yellow here is south florida. Please help.
BTW, if anybody aware of a south florida mazda dealer that accepts this plan let me know.
Thanks, Dima
after the 8 weeks past, they had no VIN number, but said the car would arrive the 1st week in August.
now, 3 months later they have no idea where my car is.. they have a VIN number but no expected arrival date..
So I've been without a car since the first week in August. I really REALLY want to buy this car but I have no choice and will most likely take my deposit back and buy a civic from the dark side this Friday..
needless to say I would not recommend buying from Schwartz mazda in shrewsberry NJ.. in my 3 months they haven't called me once with any new information on my car.. I've always had to call them about every 3 weeks and I get the "oh I was just about call you!" song and dance..
PS:
just wondering, what the options were in your order.. the p5 I ordered was a manual transmission with ABS/moonroof/alarm.. I've read something on here about a shortage of ABS parts.. I'm wondering if your p5 had ABS as well..
good luck!
Tried the Honda Civic. Doesn't even compare (ES vs. EX). The Civic is decent, but with all the recalls (even if they're not substantial as pointed out before they generate a lack of confidence in build quality and hassle for having to take it in to the dealer) and the dealer network (negative), the Mazda is far superior.
Alas, I am saddened in that the back seat just doesn't handle 3 car seats (width - legroom is great). Just not big enough for my needs. But as great as this little car is (and the ones I've had before have been tremendous), I'll always be a Pro supporter (until they get a little too much blue oval on them). Zoom, zoom.
I am having the same problem in the morning too. When I first warm up the car it seems to make a rattling noise around 3000rpm. I'm thinking about taking it in to have it looked at. The problem seems to go away once the car is warmed up. Anyone else out there with the same experience?
melonhead1 Jul 28, 2001 12:36pm
Bruno
How many miles do you have on your P5?
I only have around 500 km on my P5. Does anyone know if the rattling noise is normal or does it go away after the break in period?
By the way, does your steering become lighter when taking corners? Mine does. Is that normal?
Also, I'm thinking of replacing the front speakers.The stock ones are not that great.
Other than that, my P5 is great, zoom zoom......
When you take a corner, the TTL design of the rear suspension kicks in, may be that's why you think the steering becomes lighter. Otherwise remember that the steering power assist on P5 is engine RPM sensitive. Do you take a corner with high or low RPM?
Bruno
As for the steering getting lighter in a corner... you may be pushing the vehicle too hard and the front end is losing traction (understeer). It is quite common for a front wheel drive car. When the TTL (Twin Trapezoidal Link) begins to steer the rear wheels, it feels as if the rear-end is coming around on you (oversteer).
jstandefer: Did the rattling affect the reliability of your engine? Does it make rumbling noise when the AC is on when the engine is cold? Mine does that, sounding as if the engine is under heavy labor. So I turn off the AC until the engine is warm. I hope it's not a defect with my engine, since my car is only 3 weeks old! This is my first Mazda car (after having owned a few Toyotas & a Honda) & I sure hope it's not a lemon.
^_^
As far as your power assist steering, it is engine rpm sensitive, meaning power assist DECREASES with rpm. Lower rpm will give you more assist (i.e., lower effort). However, the difference should not be that noticeable. The TTL only comes into play in an extremely hard corner. It is activated by body roll, so let's say you would have to take a regular 90 degree corner at 25mph to activate it!
Just checked it again, the guy talks about starting a car, and putting it into drive before the engine warms up. He gets a rattle sound when he does so.
Rickroz, scroll up a few hundred messages...There's a lot of talk about the s-plan. I think the way it works is that you join some organization for $40 and that will get you a price of 1% below invoice (somebody correct me if I'm wrong). We don't have it up here in Canada, so you'll have to verify w/ the others.
Pro_fan
Dave
Bruno
You guys sure know a lot about the P5/Protege.
I'll get my dealer to check my car when I bring it in for oil change in a couple of months.
Does anyone know if it's possible to fit a 6 X 9 speaker in the front doors? I'm thinking of getting Polk EX693A speakers for my front doors.
It has a 3 11/16 inches bottom mount depth,according to Crutchfield.com. I'm not sure if there's enough depth and width in the doors.Has anyone done that before and did it work well?
Does anyone know if there's a Mazda owners club in Toronto? thanks.
Stock, the fronts take 5x7/6x8 speakers. A 6x9 will probably involve removal of some sheet metal, which I wouldn't do. Does Polk make a version of this speaker in a 6x8 format?
The car I ordered back in May still hasn't arrived..
The roofrack blades are definately making wind noise.. I looked at em and they almost certainly seem to be backwards as others pointed out on here.. the more aerodynamic part seems to be in the back, and the blocky side is facing the front of the car.. I'll try reversing them and let you know if it makes any difference.
1 other quick question for you p5 owners out there .. I see a little square on the back of the center console (facing the back seats) is that a cup holder or something?.. I can't seem to open it.. does it open from the top?..
I had a lot of fun driving this car home from the dealer yesterday! turning circle seems so small..
Regards, and thanks all for the informative postings.. New audio system is next on the list for the p5! will let you know how it turns out.
-Mark
Love my p5 after a month of ownership, but somehow I have lost a clip (a small plastic cover)for the holes of my (optional)roof rack. Does anyone know how someone can get these?
captcanuck
It's a pop-out cover for what USED TO BE a small ashtray for the rear-seat occupants. You'll notice that since smoking is not P.C. anymore, there are no accommodations for smokers in the back seats. I used to like the little ashtray, though, because it offered a place to put gum wrappers and wayward french fries until my next vacuuming!
What are the two things I miss the most from my 1992 Protege that my 2000 Protege doesn't have? I miss the lighted ring around the ignition switch and the low washer fluid warning light. I hear the 2001 model brought these back, dang it ...
And Paul, what are you doing lurking over here? Get your butt back to the Mazda Protege topic where you belong, you four-door imposter!
As long as I'm here, let me re-state my invitation -- we'll be holding the second-annual Mid-Atlantic Protege Picnic in Northern Virginia on Saturday, October 6! Reservations are required! If you're interested, come over to the Mazda Protege topic or e-mail me at:
mdaffron@the-rma.org
Happy zoom-zooming!
Meade
2000 ES 5-speed with spoiler
Ex-1992 LX 5-speed
Ex-1992 LX automatic
Meade
Congrats on your new car. Just wanted to note that only the front rack can be reversed. The rear only fits with the groves to the front of the vehicle. However, by reversing the front bar, you'll most certainly eliminate the highly undesirable wind noise.
-Larry
Protege_fan
I picked up a Vivid Yellow Protege5 from Marlin Mazda in Miami on sunday. Automatic, tape player and floor mats were included as options. Love the car. Attracts A LOT of attention, drives great, comfortable and handles like on rails. A little low on power but thats allright.
Jason
Ps. Krotine, do you drive 279 from the north into the city, my wife said a red P5 went by her on her way in Wednesday morning, she called me to say she finally saw one on the road. Thought it might have been you.
As for delivery were originally told that it was in port and that we should have it within 10 to 14 days, but when I called the dealer yesterday he said that yes it was in port, but it will not be shipped until the 28th. Then add 5-6 days for rail time to Oakville, ON. Based upon what I've seen here we may have it in the middle of September. I called today and asked for the VIN to see if we really have a car assigned to us, but the salesman was busy.
Wish us luck.
Steve
BTW, when I serviced my Millenia at Browning Mazda in Cerritos, I saw about ten P5 all colors, except yellow. So if anyone's looking for one, I heard they are the biggest Mazda dealership in SoCal. Also, I saw a Protege MP3 for the first time last weekend at Anaheim Mazda; I know this car's been hard to find, but the one I saw is for sale. I don't know how much markup they're putting on the car though.
zoom-zoom
