Mazda Protege5
50 mph: 2300 rpm
60 mph: 2800 rpm
70 mph: 3250 rpm
While the tach gauge does not permit precision readings, it appears that in 5th gear there's about a 500 rpm change for each 10 mph change.
Are these readings different on your automatic-equipped P5?
- I saw a P5 with 205/55R-16 tires in the lot at Wal-Mart last summer, and it looked good. I'll bet it rides nicer, but the speedo and odo must be off several percent. I might go with that size when I replace the Dunlops, because I'm more interested in a less-jittery ride on bad roads than I am in cornering at breakneck speeds.
- My snows are Pirelli Snowsport 210, 205/50R-16, and they are considerably wider than the stock Dunlops. I know you're supposed to have narrower snow tires, but they look great and still perform amazingly well, even on ice. I suppose most any true snow and ice tire would be better than the Dunlops in winter!
60 mph @ 2650 rpm
70 mph @ 3150 rpm
Interesting that the auto 4-speed would turn fewer rpm than the 5-speed manual.
Same thing with the 2000 Proteges with the 1.8-liter engine. I have a 2000 ES 5-speed; a good friend has a 2000 ES auto. My engine's turning about 200K faster at 70 in fifth than his is in overdrive. We did a side-by-side on the interstate one day after we bought the cars.
Meade
Pretty good, IMO, considering her typical commute.
Of course, my '99 LX gets 32mpg in mostly local traffic (but her 2.0 trumps my 1.6L in oomph).
Both are AT-equipped.
There are 2 large pin/bolts that are on each caliper. They have allen heads on them, I forget the size. They need to be lubed with special brake grease when you change the pads. Not a big job. They are on the top and bottom of each caliper. Can't miss them. They hold the caliper in place.
Jack
Here are my numbers for my P5 2002 AUTOMATIC.
The table shows the speed in kilometres (KM/HR)
followed by the tach reading (RPM). The mph
is for conversion from KM/HR.
Example: 50 km/hr @ 1450 rpm
KM/HR @ RPM
31 mph 50 1450 rpm
37 mph 60 1600 rpm
43 mph 70 1800 rpm
49 mph 80 2200 rpm
56 mph 90 2400 rpm
62 mph 100 2700 rpm
68 mph 110 3000 rpm
74 mph 120 3200 rpm
80 mph 130 3500 rpm
86 mph 140 3800 rpm
Comparable to kauai215's 2002 P5 with MANUAL:
50 mph: 2300 rpm
60 mph: 2800 rpm
70 mph: 3250 rpm
My recollection of past posts is this:
Pins are inadequately lubed from the factory and/or are especially vulnerable to corrosion, particularly from winter salt on roads. In consequence the brake calipers do not slide freely and "stick” closed after applying the brakes, failing to release properly, thus causing the pads to drag against the brake disk as though the driver were continuing to lightly apply the brakes. Naturally, it doesn't take long to erase the pads in this situation. I expect the heat build-up might damage the rotors as well, maybe even boil the brake fluid.
This is a good reason to maintain a gas book and compute fuel mileage at each refueling. I have to believe that if one's brakes are dragging in a perpetually applied state, be it ever so lightly, that the fuel economy would be noticeably poorer alerting one to a problem.
It seems the rear brakes, as I recall, are the ones suffering with this malady. But the rear brakes carry very little load and can easily last 60,000 miles and more between pad changes. I can make my front pads last 60,000 miles; I’ve never replaced rear pads, but I usually sell my cars around 60K anyway.
The caliper pins need to be lubed now, not later, in order that you might preserve the pads natural long life, not to mention the disks, etc.
That’s most of what I recall. If I’m mistaken, hopefully someone will correct me here.
If I’ve made sense explaining the nature of the problem, you can see that regardless of how well your brakes are currently performing, you need to lube those pins anyway. Otherwise, you won’t “discover” the problem until it’s too late, which may require an expensive repair.
Can someone point us to a P5-specific website that details the procedure for lubing the pins and perhaps the pad backing plates as well? For those who have ABS, does that alter the procedure in any way? (I don’t have ABS on my P5.) I seem to recall that there was some “trick” to doing this job on the Mazdas, but I may be confusing this with another car.
32K on the Dunlops is much more than what many have gotten; 20K seems common for these.
I’m hoping to get 30-40K on mine, but it depends on when winter arrives in the wear history.
You wrote:
"...I would leave it alone."
For how long? 60,000 miles? More?
Or until the brakes break?
“I would check them now. I had the pins stick on my P5 and had to have the whole rear brakes replaced (rotors, pads and calipers) from this.”
Exactly.
THAT’S how you find out whether you’ve got problems. My guess is that there are few, if any, overt symptoms to alert the owners to this problem. You find out when it’s well and truly broken. This problem is analogous to some medical problems: You don’t find out until it’s too late.
cdnp5 wrote:
“ so I imagine I should get over 200,000 out of the rears. [pads]”
Exactly my point. If one waits until it’s time to change the rear pads before lubing the caliper pins, the wait will be a very long one.
I think this is a poor strategy. Rear brakes suffer very little wear in ordinary use; it’s the fronts that do the brunt of the work because of weight transfer under braking. For many of us the original rear pads will still be good long after we sell the car.
While I’d never heard of this before, my Honda dealer was pushing this very service when we had our ’02 Si in for warranty work in recent weeks. We needed the “reluctant” handbrake adjusted on the car. (Si’s have a bad reputation for rolling off on their own even with the handbrake applied.) The dealer tried to push their new routine brake service on us: They disassemble and lube the caliper assemblies, including the pins, irrespective of whether you need new pads. I think they want to do this every 7500 miles. It can’t hurt, obviously, but in my experience it has not been necessary heretofore.
Given Mazda's history of “sticking” calipers on these cars, and other models, too, apparently, prudence would seem to dictate attending to this proactively as a preventive maintenance task rather than waiting for symptoms to appear.
Remember the old commercial? “You can pay me now ... or pay me later!”
It’s possible that your Mazda dealer will perform this service under warranty. I’d like to tackle the job myself, though, since it looks like something that should be done periodically.
Thanks, cdnp5, for alerting me to this potential problem on my P5. Yours was one of the original posts on this problem, as I recall. You may well have saved me much grief and a good bit of money, too. It is helpful tips like these from helpful folks like you that make it worth my while to read in this forum. :-)
Now, I just need to get out there and lube mine, even if it doesn’t see much salt driving.
My dealer fixed everything under warranty which was great. But I have talked to others that could not get their's fixed under warranty so press your dealer if there is a problem. Mazda does know about these problems.
Now that I'm way over my warranty (130,000kms) I will make sure I get mine done once per year.
I was wondering if you'd gone to a larger size with a taller sidewall and, if so, how it affected both ride and handling.
If you have the time, perhaps you could post a review of these tires comparing them to the OEM Dunlops.
"That is the great thing about this board, sharing information."
Yessir. If it hadn't been for you sharing, I'd never have known about this problem. The Internet is one of the greatest developments on this planet, I think. It brings people together in a way that wasn't possible before. We can reach out and talk to one another and help one another.
Thanks again my Canadian friend. :-)
The dry handling is very good with these tires. It rained very slightly only one day so far and turning and braking was very good. These tires are much cheaper than the Dunlops. I got them for $89 before mounting and balancing at our local Firestone dealer. Going up this one size should only affect the speedometer by about 1 mile an hour at 60mph. So far I am very happy with these tires.
“Well let's not go off the deep end here.”
I disagree with your approach, advocate an inexpensive alternative approach to yours, and you characterize my disagreement as “going off the deep end?” How very gracious of you.
We have opposing philosophies here, that’s all.
You advocate “leave it alone,” absent clear evidence that one’s P5 is experiencing this brake problem. Or more generally speaking, you appear to be espousing: “Don’t fix it if it isn’t broken,” or “Don’t meddle with a going concern.”
There are occasions when I adopt that approach, too, but not often, and certainly not for this sticking brake caliper problem.
I advocate a proactive, preventive maintenance approach to this particular brake problem.
Jimmcknight declares that he "would like to be sure there won't be any problems." He alludes to putting many miles on his car on salt-ridden roads -- the very conditions that promote this brake problem. His concern is valid.
How on earth can he have any assurance at all if he “leaves it alone?”
I cannot think how to _rationally_ assure myself that I will avoid this problem on my own P5 except to perform a basic, inexpensive, maintenance procedure and lubricate the caliper pins. This is not even a “repair,” nothing is broken, it’s just appropriate (I contend) maintenance given the Mazda HISTORY of this problem.
By lubing these pins, I WILL REASONABLY ENSURE that I will NOT be a victim of this problem. I can rest easy. The cost to me? Minimal. (What “deep end?” If this is the “deep end,” I like it out here. ;-)
If I elect to follow your advice, I’ll “leave it alone,” and wait and see. I’ll gamble in other words. Maybe my car will never suffer from sticking calipers, in which case the time and money I would have spent on lubing them will have been wasted. I might consider that path if the cost was very high to lube the pins. But the cost is very low.
On the other hand, if I “leave it alone,” as you advocate, and my calipers stick, it could prove to be very expensive indeed to repair. The cost of “losing this bet” is high.
The cost/benefit ratio is heavily weighted on the cost side if one chooses to gamble on this issue. My experience tells me that RISKING AN EXPENSIVE REPAIR simply to avoid an inexpensive maintenance procedure is a poor strategy. I’m unprepared to assume that risk, to take that “bet.”
At best one saves a little, while risking a lot. Age and experience have taught me to avoid bets like that.
You’re entitled to do as you choose with your car. It’s your car, your risk, your money. You’re even entitled in this free country to encourage others, as you did, to follow your advice and take this “bet” themselves. I notice, however, that you have not offered to reimburse anyone who follows your advice should they lose this bet at considerable expense to themselves.
I’m unprepared to encourage others to take such a poor bet, especially those who drive in the salt belt.
-Kauai
“Experience keeps a dear school, but fools will
learn in no other.” -Benjamin Franklin, 1706-1790.
I’d be willing to sacrifice a bit of performance for a less harsh ride on rough pavement. My P5 rides even harder than many, because I run higher tire pressures for predominantly highway driving as well as often being loaded up with kayaks and gear. I’m running 37/35 psi F/R. (The extra 2 psi on the front is to help reduce understeer.) Fortunately, I don’t encounter too much rough pavement, else I might want to change tire pressures daily depending on my trip route. ;-)
You wrote:
“Going up this one size should only affect the speedometer by about 1 mile an hour at 60mph.”
Yes, I believe that’s correct. I’ve timed my P5 over measured miles on the USA Interstates (running OEM 195/50-16 tires) and found that my speedometer appears to be off by a bit over 1 mph at 70 mph; at an indicated 70 mph on the speedometer, the timed speed is about 68.5 mph. If my timing measurements are correct, then I predict that a 205/50-16 replacement for the OEM 195/50-16 would be just about perfect for correcting the speedometer calibration error, and a 70 mph speedometer reading would be very close to an actual 70 mph road speed.
If anyone wants to check this, just look for those slim, green, vertical signs along the right side of the Interstates. They’re small and unobtrusive, and many folks are unaware of their presence. They’re mileage markers that are supposedly fairly accurately placed. I take a number of split times and average them.
You wrote:
“The ride is better, almost as good as my wife's Mazda 3 hatchback.”
Ah, so you have both the old and the new? How do the two compare in your view?
Thanks for your feedback. :-)
My wife's 3 hatchback rides and feels more like a larger car. On a recent trip, we were amazed at the substantial feel to the car. My Protege5's interior is nice, but the 3's is better. I've noticed that some 3 owners are having trouble with their a/c unit. Ours is a very early build date of 11/03 and have not had any problems. We live in Louisiana and the temp gets very hot and humid. Overall I am very pleased with both cars.
-- Autonomous
"My wife's 3 hatchback rides and feels more like a larger car. On a recent trip, we were amazed at the substantial feel to the car. My Protege5's interior is nice, but the 3's is better. I've noticed that some 3 owners are having trouble with their a/c unit. Ours is a very early build date of 11/03 and have not had any problems."
I'd appreciate any additional comparative comments, such as:
a) Driver's seating : is it only me or do you feel higher in the 3 than the P5?
b) Performance: is the additional hp evident in the city or only on the highway? The P5 has a
wonderful kick, do you find the 3 similar or has this been tamed?
c) Weight: is the additional 150+ lbs. offset by the 30 horses; I find the P5 feels faster than it should considering it's only 130 hp; by comparison my brother's 1999 CamryV6 (195 hp) gives me the opposite impression
d) Handling & Braking: do you find either one superior in handling or braking? I am impressed by the P5's demeanour in general
e) Cargo: have you ever wished the 3's luggage capacity was larger? Strangely enough, this is one of the shortcomings I find about the P5 - fortunately we do not travel weekly with tons of luggage but when the need arises, there have been remarks made by my better half about the need for more, more, more room
Cheers!
I have seen too many people get ripped off by garages on brake jobs they don't need.
The other gentleman said he heard squealing, not jimmy, so I would assume he would take it in or have it looked, and not leave it alone.
In the end if you are not sure then take it in and have someone qualified to take a look at it if you cannot make the determination on your own.
b) The 3's bigger engine does give it more kick both in town and on the road. When I want my P5 to go, you have to give it a good bit of gas. The 3's engine is much smoother and quieter with better takeoff capabilities. If you floor the 3 for passing, it only seems marginally faster than my P5, but if you take it easy in passing you can get to 80 or 90 very quickly.
c) I can't tell that the 3 weighs more than my P5. It feels more substantial, like it is a large car, while my P5 feels more like a go cart, which I like.
d) I think that the handling and braking on my P5 is better than the 3. The 3 is close, but not quite.
e) The cargo space for both vehicles is indeed lacking. We put one large and one small suit case along with some smaller items in the cargo space and it filled it up. All other items had to go in the back seat. Thank goodness it is only my wife and I. It would be a problem with children and their luggage.
f) You didn't have an f, so this is some more additional comments. Every one that sees my P5 and my wife's 3, love the way they look. I like my P5 and plan on keeping it a long time. It is the perfect car for me.
a) Seating: 3 is "higher than P5". This higher stance is more characteristic of SUVs/trucks; I prefer the lower stance of sporty cars. One reason the P5 is preferable to the Matrix and Vibe in my opinion.
b) "The 3's bigger engine does give it more kick both in town and on the road." Great. I think one of the frequent comments about the P5 has been the need for more oomph. Mazda listened.
c) "3 ... feels more substantial, like it is a large car, while my P5 feels more like a go cart, which I like." Go cart is right!
d) "handling and braking on my P5 is better than the 3. The 3 is close, but not quite." Could you elaborate?
e) "cargo space for both vehicles is indeed lacking." Isn't that curious! I'm certain that many of us bought our hatchbacks with the idea that cargo space would be plentiful. Fortunately, this is not a major demand of mine, but it does prove the rule: identify your needs and try it before you buy it.
f) "Every one that sees my P5 and my wife's 3, love the way they look. I like my P5 and plan on keeping it a long time. It is the perfect car for me." Agreed! What kind of time frame do you expect to keep your P5? My 2002 will be 5 before I consider parting with it. I suspect that the Mazda 3 by then will have been improved to deliver even more hp and enticing features.
-- Autonomous
The brakes on my P5 feel stronger than on the 3. You have to put more effort into the peddle to slow the same as the P5. This could just be a difference in the power assist unit.
I always plan to keep my car 10 years or so. I haven't done this with the last 4 vehicle purchased. We traded more expensive cars and SUVs to get to these cars we have now. I think we will keep these Mazdas at least 5 years, unless something new that would be better and about the same price (fat chance) comes along.
Tires:
"put 205/50/16s on (P5) and ... I have to make a little bit of a correction in steering" (for) 3 ... have to make a bit more of a correction."
As a result was the purchase of the 205 tires worth it? Why not continue with the Dunlops? Do you use winter tires?
Brakes:
"P5 feel stronger"; 3 requires "more effort".
Curious: I thought the 3 had larger brakes. Have you noticed more brake dust on either one? P5 has outstanding brakes; they have saved my wallet and skin on several occasions.
Depreciation:
Planning to keep a car for 10 years is wise as one wins out in the depreciation game. The only problem is all that new candy that is launched every year. I understand that the P5 is holding up well. My inexpert rule of thumb of 10% per year leads me to hope that my P5 (assuming mint condition) will be worth approximately half of what I paid originally. Many domestic models would not pass this test, I have my fingers crossed for the P5.
Wow!. I think my P5 is pretty good off the line, so the M3 must REALLY haul!! Wish I could put the M3 engine in my P5. (I think the P5 looks better than the M3 Hatch)
http://ca.geocities.com/dclintc516@rogers.com/2004_mazda_3_sport.- htm
I will be replacing my tires on Tuesday after 130,000kms of driving on the original Dunlops (I did use winter tires though), also going to 205/50/16's so it should be interesting to see how they feel.
I was in my dealership last week (looking at a Miata) and I took a quick look at the Mazda 3. Wow. What a value. The interior was superb for a car in that price range. (If we were to get a Miata, the Honda would go, not the P5. ;-)
I think Mazdas are the best hidden value out there. (A close out, price leader Miata was selling for $18,500! An even $18K if you’re a recent college grad. Amazing value.) I’ve never been able to understand why Mazda does so poorly in the market place. Poor marketing, I suppose. It sure isn’t because the cars aren’t good -- they’re outstanding values, and always have been.
I agree completely with others about the cargo space. As big as it is, I need more! Of course that means a bigger car, more mass, probably not such spirited handling, etc. Everything is a trade-off. I was just reading a recent review of the Mazda 6 sportwagon. That looks very nice.
Anyone else notice that the new Audi 3(?) small 5-door sportwagon looks, from the side, very much like our P5? The as-tested price, though, looks to be around $30,000.
I have less than 14K miles on my 5-door go cart, but I am increasingly pleased with this car and what it gives me. While I’d like more power, this gets the job done quite nicely, thank you. My only gripe is that the seats are not so good. They seem like what the Japanese imagined Americans would like -- something real cushy (read sagging). I keep thinking I’d like to put in at least an aftermarket driver’s seat. I keep finding other things to spend that kind of money on, though. ;-)
I did see the best seats on a production car ever, though, when I was at the dealer. They had one of the new VW Golf R32 beasts. Super seats. Even better than the great seats in our Honda Si (Recaros). While nobody wants the new Si, they steal the seats, apparently. The Golf seats had even bigger side and thigh bolsters.
I do wish Mazda would install Recaro seat copies in their cars. I think they’re confused about what the buyers want when they look at sporting sedans, etc.
I know that some folks like the Mazda seats, but I wonder if they’ve ever lived with Recaros before? They might change their views of seats if they did.
Apart from the seats issue, the P5 is outstanding, and I expect it will cost a great deal more to get a better car in the future. I may actually keep this baby longer than the typical 3-4 years we keep cars.
We have to stop buying new cars all the time; it’s nuts. But, oh they are tempting, aren’t they? ;-) We suffer depreciation losses, but we don’t have repair bills, just routine maintenance, which I do, such as oil and filter changes. There’s not much else to do on today’s cars. I think we’ve had one repair we had to pay for ($90) in the last 21 years. That’s it. No one believes that! But it’s true! ;-)
The biggest expense is tires, but even there we’ve managed on a couple of cars to go 60K miles on the OEM tires. In fact (you may get a giggle out of this), sometimes we get new tires by going to the dealership and getting a new car bolted to them! And that takes care of the new tires we needed, typically around 40K miles, or so! ;-)
"I will be replacing my tires on Tuesday..."
What did you buy?
"Wow that is quite a rant."
Wow, that is quite rude.
kirstie_h
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
I don't know why more peddle effort is required for the 3. It stops very well, just have to push a little harder on the peddle. I guess I know my P5's brakes better and know exactly how it will react. My P5 has little to no brake dust. The 3 had a lot of brake dust on the rear wheels in the beginning. The dust has decreased somewhat now that we have about 7,500 miles on it.
I too wish I had the 3's engine in my P5. However I am very satisfied with it just as it is. We should all keep our cars for a long period of time. After 5 years, the depreciation is very small. If we would save our payments after our cars are paid off, we would be so much better off. Its just that we keep finding new, better or just more interesting cars or things to spend our money on. I keep telling myself that when I get around $50,000 that I could just put on the floor and burn, then I might buy a loaded BMW 5. More than likely I would probably and buy the current generation of the Mazda 3 hatchback and take a long vacation with the rest of the money.
Original equipment: Dunlop SP Sport 500M V rated (149 mph / 240 km) U$110 + road hazard
redpr5
OEM : lasted 27000 miles (about 45000 km)
New : Fusion ZR1 205/50/16 U$89 + mount + bal
isseyvoo:
OEM : lasted 32000 miles (about 55000 km)
New : Toyo Proxes TPT (size?) U$125 + install
jimmcknight:
OEM : unknown mileage
Snows: Pirelli 205/50/16
cdnp5:
OEM: unknown mileage
New: Yokohama Avid ES 100 ; gift
autonomous:
OEM : 16000 miles (26000 km) and in great shape
Snows: BF Goodrich Slalom 14" ; C$700 all inclusive for tires + rims; 8500 miles (14000 km); reliable but ugly
New: Due in 2007
As many Canadians know, snow tires defer the replacement of OEMs. Handling is improved but performance (read speed) is affected; personally I do not like racing into a snow bank.
Anyone else want to share their tire history?
-- Autonomous
Anyone else want to share their tire history? It would also be worth knowing how the replacements are faring.
OEM shows mileage reached by original tires before they were replaced; the original tires are Dunlop SP Sport 5000M 195/50/16 V rated (149 mph / 240 km) U$110 + road hazard
ginto
OEM : 22,400 miles (36,000 km)
New : Toyo Proxes TPT 195/50/16/ V-rated
redpr5
OEM : 27,000 miles (about 45,000 km)
New : Fusion ZR1 205/50/16 U$356 + mount + bal
Sporin
OEM: between 25,000 – 30,000 miles (40,000- 48,000 km)
New : Kumho Ecsta Supra 711 195/50/16 U$360 complete
Snows: unknown
isseyvoo:
OEM : 32,000 miles (about 55,000 km)
New : Toyo Proxes TPT 195/50/16/ V-rated; U$500 + install
iam2
OEM: 35,000 miles (56,400 km) as of May 2004
New : planned to replace summer 2004
Dagpotter
OEM : 36,000 miles (58,000 km)
New : OEM (Dunlop Sport 5000M 195/50/16); Jan. 2004
122856
OEM : 38,000 miles (61,200 km)
New : planned to replace; considered Toyo Proxes TPT
cdnp5:
OEM: unknown mileage;
Snows: unknown
Notes: current total over 70,000 miles (113,000 km)
reitrof
New : Kumho Ecsta Supra 712 205/45/17 + upgrade to 17” wheels
jimmcknight:
OEM : 6,000 miles (10,000 km)
autonomous:
OEM : 16,000 miles (26,000 km), in great shape, plan to replace in 2007
Snows: BF Goodrich Slalom 14"; C$700 all inclusive for tires + rims; 8500 miles (14000 km); reliable but ugly
Cheers!
-- Autonomous
Cost to replace rear pads: C$215 = C$100 (parts) + C$115 (labour).
This is a followup to post 7165 and earlier.
I found this site for everyone who might be affected by sticking rear calipers on their Proteges.
Go to: http://web2.airmail.net/theman/protegefaq/tsb/
See: “REAR BRAKE NOISE / DRAG, PADS SEIZED IN CALIPER”
Evidently, Mazda does indeed have a TSB (Technical Service Bulletin (to dealers only)) addressing this problem. It’s my understanding that problems need to occur with some frequency before a TSB is issued.
Autonomous, if you were to approach your dealer with this information, he might be cooperative and perform the service under warranty. Alternatively, he might agree to split the cost with you since it’s a TSB, not a recall, and you, apparently, aren’t suffering this problem just now. Then again, maybe you are and just don’t know it yet. Measuring the rear pads should reveal whether they’ve been dragging.
Note that there is not only a TSB, but Mazda has also designed _modified_ replacement parts. Clearly, Mazda takes the problem seriously.
Hope this is helpful.
