I've noticed Subaru tends to resolve their issues by meeting the customer half way...like splitting the cost of just out-of-warranty repairs, etc. Something I rarely hear of from less reliable (or more pretentious) car companies.
My 2001 LLBean H6 has been flawless for 56K miles...knock on plastic wood. I wish they made a larger AWD - I would not be looking at the FX if they did. Subaru is a diamond in the rough as far as car comapnies go.
Ralph
I think that you may have this backwards since the front can only get 50% max. I think that the ratio is 25 front and 75 rear and that should be good. I think the 2004 model behavior is this way now, but I do not know about the 2003. I really seem to recall a 50:50 split from a standstill.
Still makes sense that locked mode (50:50) helps under those conditions.
Yes, I agree that it's better to lock AWD in icy and snowy conditions since it only really enforces the lock until 19 mph.
Good discussion...
My lips are sealed! :-%
crikey- yes, I think I did misinterpret that description where it says it adds up to 25% additional torque to the front wheels. I was assuming a baseline of 50/50 at startout which is not the case when unlocked.
Infiniti Consumer Affairs
Wife and daughter liked it, too. Now, how close to invoice can I get...
Ralph
i sold an '03 acura MDX to get into an '03 FX45.
i have driven both in the snow and ice.
the MDX was surprisingly not as good in the snow as we are led to believe. acura designed the MDX to "defeat winter" but i believe that the michelin crossterrain tires were the MDXs weak point.
these tires are designed specifically for suvs. so i was disappointed in their performance.
my FX45 with the 20" goodyear rsas was fine in the snow/ice but not great. i did consider putting snow tires on my FX45 but as the philadelphia area does always get alot of snow, i did not want to give up performance.
if you get alot of snow/ice and want the best possible traction then dedicated snow tires are the way to go.
the acura salesman is uninformed or is misleading you...you can get either a set of 20' snows or 18" wheel and tire set for as little as 1100-1200.although this is an additional expense, their use will extend the life of the stock tires so the overall expense is not that great.
also, in my experience, the rear visibility is "reasonable" and the fact that the rear window corresponds to the rear bumper it is not too difficult to i.e. parallel park.
good luck
After a couple of weeks and several 100 mile + drives, the seat is definitely better, and doesn't produce actual pain after sitting in it for an hour. It's still not what I'd call "comfortable," but it is at least tolerable. I don't feel like I'm going to be risking nerve damage by driving it for the next 6-8 years, which was what really concerned me.
Hope this helps.
On startup, torque is evenly distributed 50/50 front to rear until you reach a speed of 18 MPH -- then it reverts to Rwd. If the computer detects wheel-slippage, all four wheels are engaged. The computer will brake and cut power to a slipping wheel to prevent loss of control. If there is just one wheel with traction, that wheel gets 25% of the available power. This is done with the assistance of the drive-by-wire system.
With 'snow-mode' engaged, the system reduces power to the wheels. This will need to be turned off when you get on a highway, or the road clears, as your speed will be greatly reduced.
Traction with the 18" wheels is best, there really is no need for the Sport Package if you will be driving in snow (the 17" wheels would make a really impressive difference because the fat tires give you awesome grip)
I'd be happy to answer any more questions.
Do you happen to know if Infiniti intends to produce a manual at some point?
How is this different from engaging the AWD lock button? Is it just the reduction of power?
Obviously, the FX45 ruffled a few Bavarian feathers, and now it's BMW's turn to up the ante.
Hmmm - wonder what effect (or "FX", ;-}) this will have over at the R&D / Engineering Departments at Infiniti? Think the new 5.6L DOHC V8 (used in the QX56 / Armada / Titan) can shoehorn its way into the FX engine bay?
This could get interesting...
The FX45's have been slow to move - because most people see the 35 as a better value.
The FX is beating projections and is the second best seller in the Infiniti lineup.
I just wanted to clear up that misconception.
otis123- I find that the FX45 is rare in the DC/Balt also. Almost all of the FXs I've seen have been 35's. But that makes sense given that Infiniti made 44,000 FXs in 03 and only 11,000 were 45's. And the number of X5's on the market, for example, is significantly higher (I forget the number). I like that...more exclusive.
At $72,000, we will probably see these as often as the Cayenne TT.
So I'm not too worried that I'll be doing a stop light match race with my 45 every day.
The people I see driving X5's are mostly ladies over 40, especially the 4.4 and 4.6's.
BMW says 5.9 0-60, but I'll wait until R@T tests one on California's 91 octane that yields less energy (we get lower mpg's from our special gas).
While the 5.6 has the same HP rating, it does have alot more torque, and I bet it would make the FX fly. We only need to go .4 seconds faster and that's not a huge difference.
I bet the 4.8 can't match the Fx's cornering power.
The Automobile article was great. Peak acceleration was .50g. Peak braking was 1.14g.
Cornering was .88g left and .85 right.
Quote: "Work of Art;Thrilling Performance".
Of course, they slammed the cramped rear seat, the ride and the adaptive cruise control, but what's new?
Played around on the Internet, and found several companies that offered 12 to 21 piece wood kits that ranged from $150 to $460 (some real wood, others simulated). Has anyone had much luck with the installation and durability of these aftermarket kits?
One vendor in particular had a few disclaimers associated with their kits, such as not being responsible for any damage to the OEM dash parts if one decides to attempt removal of the wood applique(s). This particular vendor also warned about exposing the dash pieces to direct sunlight.
Any positive or negatives experiences would be greatly appreciated...
For wood its many FX'ers have installed Joshoua Tree (sp?) wood kits. he participates and sells them on another well known forum. lots of threads and pics there.
The new 4.8 is a beast but I was very disappointed by the the new 4.4i it is still no quicker really than an FX35 at a substantial hit and the skidpad is pretty low at .77g The big do 4.8 will beat a 45 in a straight line but I will be interested in skidpad numbers for it. I really hope Infinti releases a "R" or Nismo version of the FX's with factory installed SC's I would pay 5-7k more for that then there wouldn't be much with awd that could touch our FX's
possibly not even the Cay TT - would be close.
"How is this different from engaging the AWD lock button? Is it just the reduction of power?"
- crikey
"Pretty much, yeah" - Infinitimaven
hmmm..... for those of you that missed this conversation - I emailed Infiniti customer relations (at tidester's suggestion) & asked them to participate on this board to clear up some technical questions that the available literature is lacking in. Specifically, how intelligent awd works. Infiniti returned the email with an auto msg that I would have a response in 24 hrs. I got no response but Infinitimaven, an infiniti sales mgr., showed up within 24 hrs and provided an excellent description of intelligent awd.. Anyway, to make a long story short. Infinitimaven - it sounds like from your response to crikey that "snow mode" in the 04's is nothing more than "AWD Lock" in the 03's renamed - is that correct????
The Snow Mode on the '04s does the same as the AWD lock on the '03s but also remaps the throttle sensitivity to enable finer throttle control in snow and ice.
The snow mode also reduces power, so, you do have to remember to turn it off when conditions improve.
I would definitely suggest going for the sports pkg with 20" tire, alum. pedals and rack - totally changed the look!
Again, thanks for all of your inputs to help me make that decision!!
http://www.nissan-techinfo.com/infiniti/
If you order one please let us know if you think it's worth the investment...I will if I order it - would be nice to get a look at it to see if it addresses the kind of questions the enthusiast might want answers to as opposed to just those the mechanic that services the FX might need answers to. Either way, it's probably interesting reading for those of us that are curious about all this cool tech on the FX & can't find answers.
jccssc
As I said stated before I tested the limits of the FX45tech 03 in a lot for a few hours to determine how I would recommend to my wife when to engage AWD lock. I found it was best to engage AWD lock when driving in deep snow or on ice.
Thanks for additional information. I stated 20mph, but it is actually 18mph, small detail, but clearing it up helps the rest of the owners understand the operations of the FX.
I understand and can live within FX boundaries of operation. It is so thrilling to drive. When I get that chance from my wife .
Hoping some has some insight before I take the plunge...
I thought the FX came with an optional DVD entertainment feature with flip down screens.
If so, why spend the extra cash for screens to be in the headrest.
Not that I care- its your dough.
