what other parts should I change for a tune up other than the plugs?
thanks so much.
In interference designs incorrect timing (or timing belt failure) may result in the pistons and valves colliding and causing extensive engine damage. The piston will likely bend the valves. For that reason, in such an engines regular replacement of timing belts is especially important. Thanks, AB
miles on it. There still may be time left on the belt and may only require an adjustment of the tensioner. My 99 wagon has 106,000 on the motor( tho my 5 spd trans has committed suicide), and the timing belt STILL looks real good. It also has not needed any adjustment of the tensioner. I have heard that SUZUKI has recommended to extend the mileage replacement to 105,000, though i have yet to see it in writing. and to be TOTALY honest..... If you don't know how to change a timing belt, I STRONGLY recommend that you have a reputable local shop handle it as it is very easy to screw it up and cause irreversible engine damage. You can always contact local AAA clubs, car service orginizations, and your local better business bureau for a list of recommended shops. if you persist on doing it yourself, try a 'HAYNES' manual if you can find one. or goto your local SUZUKI dealer and purchase a real shop manual for your specific model car(can be quite expensive $50-$125). alot of shops have specials that can cost you a littleas $85 -$175 for this kind of job.
Denny
Another possibility could also be that your actual "key" ignition switch in your steering column. Suzuki's in the past (SAMURAI'S, etc.) have had some trouble with the key switch wearing out and not energizing the starter side of the switch. The "key" tumbler itself works fine, just the electrical switch located on the backside gets loose and begins to burn the contact points of the switch and thus makes it difficult to engage that part of the switch. :sick:
Both of these problems will act intermittently with no rhyme or reason as when it happens. The other possibility could lie in the starter itself or the solenoid of the starter but that should have been eliminated when you replaced the starter.
PS.. what "engine" light came on? :confuse:
Also, why can't I find a Chilton's or Haynes manual for this car or engine? Is there a twin model that I can use the manual for?
Any help would be greatly appreciated!
These have occasionally also turned up on Ebay.
At random times through the year, my Esteem will not start at all (4 times in the last 7 months to be exact). Nothing happens when I try to turn the ignition. My battery lights will be on for a bit, but after a few attempts at starting the car, the battery goes completly dead! I mean completely dead-the battery will no longer even hold a charge!
After checking under the hood "thoroughly", Four different mechanics have all come to the conclusion that nothing is wrong with the car and its just the battery. (Alternator's fine, starter's fine, they can't find anything wrong) But after 4 differet batteries (actually it will be 5 tomorrow, when I get the car towed in for the 2nd time in 2 weeks) there is clearly somethings up????
After reading about the Neutral sfety switch (from the last person to reply to this post), I've been given some hope, I'm gonna have them try checking for that. But could there be anything electrical? I've also had to replace a blown fuse this year...the black one which goes directly to the battery. I don't know, its certainly out of the ordinary but I want to kick this problem to the curb. Does anyone have any suggestions on what else I should have my mechanic check???
Happy Car Karma
I have a 2000 Esteem Wagon. 144,400 miles! I just replaced the Axles. The mechanic says In need front struts and or link pins since its rattling like crazy.
The trunk wont lock. It closes but the key wont turn
The door handles on the passagner front is broken. I comes off in your hand, you have to open the door from the inside. The door handle on the back passenger works but get stuck when pulled up. The dome light doesnt turn off after you open the door. So we have to have it always off and put it on manually.
Ive replaced the brakes a bunch of times, the air conditioner is getting suspicious.
Even with all the that my mechanic says the engine and trasmission could go another 100,000!!
So do I keep putting money into this car or unload it now>
thanks for reading
When I have touch actuator module it was very hot. Cost of module about $1200
I have disconnected electrical cable.Have anybody idea what to do, except to spend
about $1500 ?. Thanks
