I'd guess that around 16 mpg would be a realistic average if you do a fair amount of highway driving. Depends a lot on how and where you drive.
1. How do you open the fuel door on a 1979 450 SL?
2. How do you open the hood after unlatching the inside lever?
Many thanks to all.
After unlatching the hood, lift up lightly from the grille, and a little tab should pop out - pull on this and the hood is unlocked. At least the closed cars I have owned operate like this.
I put a lot of WD-40 to the spring. Now its working fine.
The lever is inside the top right space of the Mercedes Benz Star ornament on the grill. Use the left hand to pull lever.
79 was towards the end of the 450SL run, I think those ones are less troublesome than 1975-77 models.
I am back with another question. I attempted to remove the hard top, unlocking the 4 locks, 2 on the windshield and the other 2 near the door. But the top seems to be attached in the rear at midpoint. But I couldn't find any other release lever to unsecure the rear one. Any ideas?
Thanks again for all your help.
Anyone knows where is the fuse box?
Thanks for the info.
I found this image online
It was where you said it was.
Many thanks for your help.
Check it over real good for rust.
Make sure the climate control works acceptably.
I'm not sure if the 4.5L had double row timing chain in 1980 or not, but if it doesn't see if it was ever replaced or if it was changed over to a double row.
I agree with Shifty on the offer price. Don't expect it to be a reliable daily driver.
They have a great group of people and lots of infor.
thanks.
I'm afraid I don't have any miracle source for you but have you tried your Mercedes guy or even your local dealer? Mercedes US can sometimes surprise you with how reasonable a price they'll come up with. Of course they can give you a pretty severe reality check too, but they're always worth a try
Here is a list of repairs done just three months ago:
1)Replaced Subframe motor mounts
2) Remove and reseal intake manifold- replacing all
rubber seals and hoses on manifold. Replaced coolant
and radiator cap.
3) Replaced worn rear brake pads and rotors (installed
performance rotors.
4) Replaced front and rear driveshaft flex disc couplings.
5) Replaced worn timing chain, all upper guide rails and timing
chain tensioner plus VC gaskets. Replaced oil and filter and
replaced spark plugs.
6) Replaced Front and Rear Shocks
7) Replaced window seals on hardtop and seals on "A pillars"
Thank you for any advice you all can give me.
The miles are not low for one of those...unless it is exceptional cosmetically, I'd try to get it down around 10K.
Also you need to have the car inspected in CA before you buy it---there are a lot of 560SL rats out there, and remember, a bad engine totals this car.
Ideally, this is the type of car you want to buy with very low miles, perhaps one owner, full service records, and for which you will no doubt pay a premium price well over $10K and perhaps as much as $15K--$18K
WELL WORTH IT.
thanks again!
Is there anyone out there that might have a solution for any one of or all three of these problems?
The high revs sound like a fuel injection issue related to idle control---I'm guessing some device that is leaking vacuum or has a sticking actuator. I'd need to get the workshop manual out to pinpoint but a good MB man should know pretty quick what causes this exactly.
This car was my fathers in 1985. I stood with him on the showroom floor when he bought it so it has a lot of emotion in it ... especially now that I am losin g him to cancer. Everytime I take it to someone they all say they have fixed it and I still get the same problem ... so I guess for me, I just have to try to find someone around that can really do the work properly. From what you are sayin, it doesn't sound like it could be THAT difficult to fix.
I'm in West Vancouver, BC Canada. I have taken it to MB North Shore, MB, Vancouver as well and still no help so ... I'm open to just about anyone ... I am mobile so distance isn't a big problem.
I'm actually considering having the whole car restored "frame off" over this coming winter. It is in very good shape as it is but it is 25 years old ... I will keep this in the family and it will at some point be given to another appreciative family member ... not to soon though I hope!
