Matrix Transmission Problems
I have a new 2006 Matrix (automatic) and 4 times the car has shifted from drive to 2nd gear on its own. Has anyone ever experienced this. The dealer thinks I'm nuts!
They are a wear and tear item. Check your warranty book that came with the owner's manual. It will state which components are covered, and what is not. With the clutch, it won't cover the disk or the pressure plate, and probably not the release bearing. No manufacturer covers clutches.
Please do not take this the wrong way, I am not necessarily saying you caused the problem, but in most cases, it is the driver.
A bearing needed replacing that cost me about $Cdn 1800 to repair, which was about $1500 labour. I failed to change the manual transmission fluid at 100K, which Toyota Canada said meant that the repair costs were all mine. They offered $300 to cover the parts as a Goodwill gesture. I told them to keep it. The fact is the US site and GM Canada site (Vibe; said powertrain) both say that the trans fluid only needs to be replaced if the vehicle is used to tow. I had the bearings subsequently dissected by a Materials lab and a report written identifying the problem as a defective bearing assembly (Japanese bearing parts out of tolerance) that did not fail due to any poor lubrication condition. Toyota Canada again denied any responsibility, and said that any future communications on this issue would not be addressed. The only joy I have had to date, is driving daily (work commute) by the plant where the car was made (Cambridge, Ont.) with a neon placard on the back window for all to see that tells my story:
2003 Toyota Matrix
Failed Manual Transmission 108K
Me: $1800
Toyota: $0
Made in Cambridge
I recently received a 2003 Matrix owner's customer satisfaction survey, which I sent back uncompleted to the president of Toyota Canada with a covering letter saying that he could fill it out on my behalf based on the enclosed copies of all of the correspondence.
I would be interested in hearing about you experience.
SH.
By the way the clutch wnet out at about 30K, but Toyota id fix that.
A bearing went in my 2003 Toyota Matrix XR 5-speed transmission about a week ago at 108K (km) !!
(I was in the middle of nowhwere 250km from the nearest dealer, 40km from the nearest town at 1am BTW)
When I read your post, I could think only one thing, defective batch?!
Anyway my Matrix was made in Cambridge, April 2003 and bought June 2003 in Calgary.
Transmission fluid was changed by Toyota last year.
I am trying to find more people that this has happened to
If the bearings in that transmission were faulty,
then I am guessing that sooner or later they will all go
and since the average driver may not have hit 108K km yet
more of this will probably crop up.
RT
I believe this is happening to more people than we know of and am prepared to do whatever it takes to find them!! I am a frequent visitor to Japan and just returned at the end of February. I can tell you the Japanese take GREAT pride in everything they do and everything they make and probably have no idea of the problems of the Matrix - in fact the Matrix is not made in Japan, it is made in Canada....AND.....I don't believe that Toyota Japan even sells the Matrix....so....I am willing to pursue this at whatever level is needed. I feel Toyota Canada needs to acknowledge the problem and do a recall...let me know if you are interested....ds
I have been waiting for Toyota Canada to stand up and help me out here , but I should have not been suprised when they have offered next to nothing . If any or all of you can send in your serial # , kms , and a detailed description on how this happened and what there response was , I would be very interested .If you find any other people with the same problem , ask them to do the same. It sounds to me like this is a concern that needs to be moved to a different level. I have driven a lot of toyotas and this has put a real sour taste in my mouth....
I honestly believe that Toyota is one of the few companies with values and if this can be sent in the right direction action will be taken to rectify our concerns.
Although, it happened over a year and half ago now it still makes me so mad. I have the culprit 'Made in Japan' bearing handy as a reminder. I battled with Toyota Canada and lost.
If any one wants to continue with the battle, I will gladly join in. The following was my contact who I would encourage all of you to send a letter to detailing your experiences:
Donna Gervais
Consultant, Customer Interaction Center
One Toyota Place,
Scarborough, Ontario
M1H-1H9
1-888-Toyota-8
Please refer to my file:
Stephen Harding
Case #773648
Just to be thorough, you may also want to send a copy to this guy:
Mr. Kazunori Harada
General Manager
Overseas Operations Department
Customer Relations Division
Toyota Motor Corporation
DAI-NI Toyota Building
10-27 MEIEKI 4-CHOME, NAKAMURA-KU
NAGOYA 450-0002, JAPAN
NCR-0031125-01-N
I also can give you further information through standard email, including my correspondence with Toyota and the lab report on the defective bearing.
I recently replaced our family van. I had a choice. It's a Honda.
I hope so because I just bought an 03 Matrix AWD automatic with over 100,000 miles. Need to get the transmission serviced but at this point, it seems to be fine.
Certainly is disappointing to hear that Toyota is dodging the problem this way!
Here are the common transmission problems with the Matrix :sick:
2003-2006 XRS 6-speed manual clutch failures at around 50,000km
2003 5-speed manual - bearing failure at around 105,000km
Like I posted earlier, My 2003 XR 5-speed failed at 108k km (about 68k miles)
The output shaft bearing blew up killing some other parts in the tranny costing $2400 to fix.
Summary of reported bearing failures right after the warranty ran out:
1) mjustice - 2003 tranmission replaced at 62K miles
2) crimson_steve - Exact same failure as mine at the exact same mileage (>1k km apart)
3) jim19a - Not sure if 2003, but failed within 5k miles of mine, also bearings
4) tuxristo - Mine, 2003 XR bearings failed at 68K miles
5) ron99 - Not sure if bearings were the problem, but 2003 and failed within 5k miles of mine
6) frustrated13 - 102,000 kms on a 2003 matrix 5sp and the tranny bearing exploded taking out the works. I.E. exactly the same failure as mine.
7) pattih - Also bad bearings, but from the sounds of it it failed at 108k miles not km?
She also had it checked just before warranty expired like I did. If the bearing was making a subtle whine like it was on mine, then why did the mechanic not notice it!? :mad: I noticed the whine after letting go of the clutch pedal and slowing down "with the gears", but thought it was coming from the engine or something
8) madatmatrix - 2003 transmission trashed at 85K (miles or km? - guessing miles)
9) canonlaw - Exact same symptoms as mine, at roughly the same mileage.
WOW,
You can't help but wonder how many more people are out there that don't use this forum!
:lemon:
Will this happen to us again at another 60K miles?
Since the new bearings are presumably not bad, it might not happen again at another 60K miles, but as pattih noted, the transmission design was changed for 2004, so maybe the transmission was flawed in the 2003 and it WILL keep happening! i.e. maybe there is some design flaw in the tranny that is CAUSING the bearings to fail. Then again, maybe it was a bad batch of bearings. Toyota really needs to stand up and own up to this problem and at the very least give us all some answers!
- Will we be compensated for this design flaw/batch of defective parts?
- How will this affect Toyota's Reliability reputation?
- What can Toyota do to make sure we don't go around telling everyone to avoid Toyota based on our experience?
It is interesting to see that people are starting to ask about 6-speeds, automatics and even the Corolla in this thread. To me these questions show that the 2003 Matrix 5-speed manual transmission problem is already starting to cast a shadow on Toyota's reliability reputation, and I think it would be in Toyota Motor Corporation's best interests to reassure people that the problem is isolated to a certain batch of 2003 Matrix 5-speeds, if in fact that is the case!
I don't like posting my email address, so can you contact me through my website? Just fill out the contact form. Thanks.
www.zebwainwright.com
2003 Matrix XR 5sp. 102,600 miles. Bought May 2003. Well maintained and serviced at regularly scheduled intervals by the Toyota dealer. Not a single mechanical problem until a slight grinding sound (coming from either the clutch and/or transmission, when in gears 1-5) popped up 2000 miles after my extended warranty expired at 100K. It sounds like this was in fact the bearing. Last night the tranny blew as I was driving it to get a second opinion after the local Toyota dealer offered only an entire transaxle replacement for $3500.
I'm planning to do a dealer trade-in with them and work a deal on the price of a new Prius. I'd prefer to never buy Toyota again because of this, but it is my best option for salvaging the most value from the car.
Toyota has not lived up to its reputation, and hasn't done anything to help me. Needless to say, I to am extremely dissapointed and would love to join the fight.
All the tramission need to be replaced. This job cost 4300$ at a Toyota Dealer.
A failed to change transmission fluid which Toyota Canada said meant the warranty is over. They offered $2000 as a Goodwill gesture. So I still have to pay 2300$.
I look to repair by independant transmission garage and the cost for a used one is 1500$.
What do you think I should do : accept their offer (cost 2300$) or buy a used one (1500$)?
thank
Judging by the posts in this forum, it's pretty likely that a 5-speed manual transmission from a 2003 Matrix, will fail at about 107,000km (+/- 5000km)
So, if the used transmission is less than 102,000 km old,
you'll put it in and it will probably fail.
As sad as it is, I'd just get it fixed, if I was you. :sick:
I would also print out all the posts in this thread and talk to a manager and get them to cover the entire cost of the repairs based on the fact that these transmissions are bad. :lemon:
The car was making an abnormal noise when in all gears, with the noise level increasing with the RPMs. I wouldn't describe the noise as grinding, however. The noise was similar to the normal idling noise, but sounded like the rotations were off-balance - the noise had a cyclical/oscillating quality.
I took it into the dealer, and they've indicated the transmission needs to be replaced. I haven't been told exactly what the problem is/was, but faulty/failing bearings seems plausible.
Thankfully I purchased the extended warranty and the repair will be covered (~$3k US).
'03 Matrix, purchased brand new December of 2002.
85,000 miles
Just started showing all the symptoms described throughout the the various posts, grinding at low rpms, progressively getting worse (louder) Grinding started exhibiting itself halfway through my drive from Chicago to Denver. Stopped in Nebraska at a Toyota dealer, 3 certified Toyota mechanics scratched their heads, couldnt figure out the problem was (other than "we think it's either your transmission or clutch...). Said to just push on through to Colorado, and deal with it when I got there. Well I made it, and I'm taking the car to couple shops tomorrow, to get it checked out again (I suspect it's the blown transimission issue), dont know what I'll do at this point. Gotta figure out how to get it back to Chicago, as cheaply as possible... never expected this from a Toyota w/ such low mileage.
I believe Toyota knows there is a problem but feel it would be cheaper to ignore us ( who have problem cars ) than to issue a recall so keep calling them at 1-888-869-6828 and let them know that this issue is not going away until they address it properly. When we called them at this number they said they were unaware of any problem with the Matrix and that they had received no calls from customers complaining about it. So PLEASE CALL!!! Maybe a call to an investigative news show is in order?!
shoudl i get a fit instead? or a nisson verssa?
chadnyc1@earthlin.net
