It does seem odd that it would just happen suddenly, although to your point the weather has been colder for sure and the car was out at the motel for a couple of nights as well.
I Googled the info below....
Many Honda Civics, Accords and Acuras have a "Maintenance Required" warning light on the dash that comes on at 7,000 mile intervals to remind the owner of recommended factory maintenance.
To turn this light off:
1. Push in and hold the odometer reset button.
2. While holding in the odometer reset button, insert the key into the ignition and hold for 20 seconds.
3. Turn key to "on" while still holding in the odometer reset button.
4. Hold in the odometer reset button until all of the warning lights have lit - after about 10 seconds the "Maintenance Required" light will go off.
If anyone know about regular services such as 15k, 20k, 25k, 30k, and every 5k miles services after that must be perforned so the manufacture and extended warranty stay intact? I didn't realize that the 15k service mostly just checking the engine and oil change ,and toyota dealer wanted like $350. I am afraid that if I don't let them do the service, my warranties will be voided! Is this possible? Is there any way that I can get around this problem?
Should I say, is it neccessary to have the car service as its schedule?
PT
You need only have serviced the items called for in your owners' manual at 15K. Read it. An informed customer will be able to know when to say no. Simply get a price for the items required . . . and nothing more.
Based on the manual service schedule, at 15k miles, basically there are a lot of checking services beside the oil change and the cabin air filter change. I was thinking of bring it to my friend who also has an auto shop to have the services done. What about this idea?
PT
There's nothing about a 15k service that can't be done by auto service center. All those inspections are visual, just checks for leaks or obvious problems. Anyone could do them in a few minutes.
Btw, I'd probably change, rather than clean, the cabin air filter. Good luck.
You got a new engine when your car already had 20,000 miles on it !!
I say have a Par-TAY !!!! You get 36K more miles of warranty coverage on the new engine, I'm sure.
P.S. Never have heard of this issue happening to a 2007 TCH before.
Have my 08TCH for a little over 2 months and I have always wondered why, after using the EV mode for a long stretch, it kept trying to force the ICE on. What you say makes perfect sense.
Was getting frustrated because I thought everytime I let off the gas below 40mph it should go to EV, but sometimes it did not. Now, when I think how long it has been between the ICE running, it makes more sense. The catalytic converter would cool down after a while. Wish the car would tell you when it was the culprit for turning on the ICE rather than your lead foot.
BTW I am averaging 43mpg (5.5 l/100km for canadians) with my car doing 80% city / 20% highway. Very satisfied with the efficency for such a large car.
Is there an adjustment to the car to allow more give to the throttle. Would prefer that if I feather the throttle, it stays in EV, if I press harder on the throttle, it brings ICE on. Seems to be hard to figure out how much throttle you have to work with before ICE gets involved. I think different modes give you different sensativities.
Drop it at the dealer on a Saturday morning and say " Fix it."
Problem solved, no cost to you.
I took it to the dealer and they turned off the CE light, tightened the gas cap and promised to order me a new gas cap. It hasn't arrived yet but I have had no more problems with the old one.
First, I had the strong gas smell (and this was outside in the driveway!) and a small amount of gas on the driveway behind the left rear tire. Brought it in to the dealer, and they could not find anything wrong. The check engine light did not come on this time.
Then several weeks later the check engine light came on. The gas cap seemed loose, so we were sure that was the problem. We drove the car quite a bit and had several fill-ups before having the light reset during the next regular service. They confirmed it was a loose gas cap that caused the light to come on.
Yesterday the light came on again, and again the gas cap seemed like it was not tightened properly. We have been hyper vigilant about paying attention to the clicking sound when filling up ever since the first incident with the gas that leaked out, and we never top off the tank. Not to mention we have both been successfully tightening gas caps on various cars for quite a few years now!
I am annoyed at having to go into the dealer again to have them reset the light and tell me they don't find any problems. I hope Toyota will acknowledge that there is an issue here and figure out how to fix it. I'd be interested in hearing whether a new gas cap fixes this problem for anyone.
A lot more info is required before anyone can make a knowledgeable reply.
Please keep us posted.
They told my wife the fuel injectors were "gummed up". When I called back they said the fuel injection cleaning would help since they got a throttle body error code. the engine has never had a problem, no acceleration or running issues. ran great after restarting the car.
what do you think?
they cleared the codes , car runs fine , no error codes after test drive.
I asked them to flash the computer but they did not understand how to do this
p2103 and p2111
p2111 throttle activator control system stuck open
look up"electronic throttle control" on wikipedia for a detailed explaination on how this part works
I found out this weekend they did not open the throttle body as they should have to inspect it. they did check the electronics of it and working fine.
car is running fine, never did have idle issues etc.
they did say it could have carbon build up in throttle body.
is that possible?
Thoughts ?
I got a preliminary recall notice telling me to remove my floor mats until further notice. I do not believe floor mats are the problem.
Talk to a dealer and have them bring in an area rep to talk with you.
And I doubt the dealer has check *all* the connections. They have check the ones that are easy to get to. To really check all, they would have to strip the car down to get at everything.
