I have a Balzer S10 1994 with a broken speedometer cluster. It seems like it is the power supply that fails for some reason. There is power on the incoming cords but the instrument is all black.
Any ideas of where to find repair information since nobody here in Sweden seems to know how to repair this.
One post points to the speed sensor:
ultragb, "Chevy Blazer GMC Jimmy Maintenance and Repair" #1663, 24 Oct 2005 9:34 am
You can use the Search This Discussion box in that discussion to read the rest of the speedometer posts.
Just a thought.
http://i8.tinypic.com/6btnfbd.jpg
thanks!
This post suggests it could just be a bad connection or fuse:
repairdog, "Chevrolet Blazer GMC Jimmy Transmission Problems" #32, 24 Jan 2007 3:32 pm
I have had a problem with this system for the last 5-6 months. I have taken it to a couple of mechanics and they seem to be more concerned with diagnostic costs rather than fixing my vehicle. I saw your post on the part #'s and the how tos of fixing this particular problem. I got into it and realized that the 30 amp fuse was blown and replaced it. The first start up after the fuse replacement it blew again. Is this something you might be able to help me with? Anyone? I need to also know if this is something that I need to fix before I drive across the country. Anyone with any advice it is greatly appreciated. I am moving on military orders at the end of the month so time is crucial. The trouble code was P0410.
Got out looked turn signal works front and back. Looked in the book an no mention of the light signal flashing this fast.
HELP
Kris
Somehow now, im not sure why, when I open the passenger side door It will blow the fuse for my push button 4wd-domelight. So for a quick fix I just disconnected the wire going to the plunger at the door.
I was able to get my guages working but im not sure how, That lasted about a month now there out again!!!!!!!!!
This may be going in the complete opposite direction but after looking around online im kinda leaning towards a bad igintion switch.
Please let me know if you find anything
Please HELP!!
I am curious to here if anyone has any ideas on what would cause this.
How many miles are on the Blazer?
The gauges may be getting a low voltage to the cluster, and that will cause all sorts of problems, all of which generally correct themselves when the proper power conditions are restored.
With today's more complicated systems, you really have to look close at a failure to determine if it is a cause or affect!
Jim
If that battery is more than 3 years old, time for a new one.
