Honda Odyssey Droning/Humming Noise
2006 EX-L
Its been now 2 weeks since I have had my Odyssey. I keep getting a loud droning noise at around 40mph (somtimes) and between 59-64 mph (always). This goes away at speeds higher than that. Given that at an average we drive around that speed, it is painful. Is this a known issue as I don't want to take the car to the dealer for nothing.
Yeppo
Yeppo
It seems lots of others do to,I don,t know if anyone
knows the fix,
Many people have complained about this same booming sound problem on EX-L and Touring models since 05 Model Year. So it is a carried over problem. If you also look at the Tach , you should also notice the sound typically happens between 2200- 2500 RPM. At high speed (above 70 MPH), the problem goes away. My 05 has it from the first day we got the vehicle. It sounds like air induction resonant noise and it spoils the overall very nice and quiet powertrain. No one has reported any word from Honda yet. They probably deny the problem at first.
jt
I told him Honda is suppose to be working on a fix for it.
I hope they can fix it,I had a 2000 and 2003 and this
will be my last Honda if they can't fix it.
The Odyssey EX-L and Touring have special active engine mounts and active noise cancellation through the stereo to help negate the out of balance condition which is present when the VCM system is operating. This is a characteristic of this engine and is not going to change. I was aware of this prior to purchasing the vehicle and am actually surprised how well the system works considering that half of the cylinders, all on one side are not firing when the VCM operates.
Humming/droning and vibration.
This is my third Odyssey with the ABS noise and no
brake problems.
brake problems.
It is informative to know this humming noise is also present to non-VCM vehicles. I suspect it is related to the air induction system resonant frequency. Hopefully it is not misprogramming of the transmission (shift to wrong gear that bog down the engine).
jt
1. turn of the headlight and AC, drive to a normal speed, say 45 mph, and stop the car slowly. you should hear noise when the car is close to a complete stop. When the car is in complete stop, you can feel very high freq engine vibration from the steering wheel and break pedal. You can make the vibration go away by simply pulling the power window switch (open or close, it doesn't matter)
2. get you engine rpm to ~2500 in driving, the engine vibration is so bad that i can feel it from the steering wheel, gas pedal, and even the turn signal switch. rpm higher or lower than 2500 don't produce the same intensity of vibration
The vibration and noise really bother me a lot, especially driving long distance. The vibration at high speed (~75mph) makes my palm numb sometimes. I actually wish i have tire noise problem instead of vibration since i can always buy better tires to fix it. However, i can't do anything with the vibration and humming noise. By the way, i visited 3 different dealers in my area, and none of them can fix or diagnoise the problem. Honda American customer services is also helpless. I actually suggest 2 of my friends not to buy ody because of this problem (+ a whinning PS pump when the outside temp is low)
Wondering if it would help if everyone complained to Honda USA. There has to be a fix for this problem....
I am very disgruntled!!!
But first, I would like to describe the problem I had in my 2006 EX-L Odyssey with less than 2K miles.
Under acceleration, at any speed, if the rpm is between 2100 and 2300, the front of the car started to vibrate more than usual. If the rpm is maintained in the range, the vibration caused a humming noise that filtered into the cabin. The noise resembles the noise you make when you hum. It is a low frequency noise and could get really loud and was very annoying.
I took it the my dealer twice. I had a mechanic sit with me for a test drive and he could hear the noise. He did a throughout checkout of the car, from engine mounts, to transmission, to exhaust system but did not find anything obvious. The plan was to call Honda hotline to see whether there was a resolution to a similar problem. Two weeks later, I took it back and left it at the dealer for 3 days. They finally figured out what the problem was.
The problem came from the A-pipe. I am no mechanic I have to admit. The A-pipe is a pipe somewhere between the exhaust manifold and muffler. The mesh of the A-pipe was loose according to the description of the resolution. It was replaced and the humming noise and vibration are now history.
Hopefully, those who have a similar problem can have it fixed as easily as mine.
Cheers,
Thanks for the info. That will help many of us who have experienced this problem for quite a while.
jt
and being the nicest of them all.
But the vibration/droning spoils it,In the mountains its horrible.
I've been on this forum 6 years and it bothers me that
the Honda sales people want us to think were nuts.
I think you might have the same problem. The noise in my car was particularly worse under acceleration and especially uphill. In that case, it became almost unbearable. The entire cabin resonated so much that even kids noticed it.
You need to be persistent and bug your dealer. After all, it is theirs obligations to fix it. If many of us report the same problem, Honda will eventually issue a recall. This seems to be a design issue with the exhaust system. I drove 2 more Odysseys, a friend's and a coworker's. One of them, a 06 model, bought a month earlier than mine has a much less noticeable noise while the other, a 05 model, was fine.
Thank you for a most infomative reply. I can take this information to my Dealer and be persistant on a fix....
Again thank you !!!!!!
is it possible for you to scan and post your service record so that we can take it to our dealers? I have tried 3+ times to fix the vibration problem but all i am getting is "there is nothing wrong. it's a characteristic of my van"..thanks
I don't have a scanner but I will provide all the details that are in my service record, including part numbers and descriptions of the problem and resolution as reported by the technician who fixed the problem.
If the noise you hear is mild, the dealer might not do anything. But if you feel the vibrations under acceleration and they turn into the loud humming noise, you definitely need to bug you dealer. I my case, it happened at any speed regardless of the VCM state and especially bad uphill because the engine and transmission seemed to be working harder.
I'll give the details this evening as I don't have the record with me now.
Thanks for all reply.
Does your Ody have the humming noise? If so, you should be able to hear it easily. After you notice the noise, glance at the tachmeter. Next time try to keep the rpm around that range.
Not all Ody have the problem.
Here is the information you requested.
The description of the resolution:
A Pipe has loose internel mesh piping.
Replace A-Pipe Assembly and seals. Road test to verify repair.
The list of parts are:
QTY Number Description
1 18210-SHJ-A01 Pipe A, E
1 18393-SDB-A00 Gasket, P
2 18212-SA7-003 Gasket, E
6 90212-671-005 Nut 10mm
I hope this will help.
Anyhow, if you haven't notice a loud humming noise, chances are that your car is just fine.
Thanks for your response. The question is what speed you drive to get rpm between 2100 and 2300? I tried this with speed up to 65mph and my rpm is still or at 2100.-B
Almost at any gear and speed, when you accelerate the rpm usually crosses this range. The trick is to keep it in the range as soon as you notice a humming noise. If you are not light on your right foot, the rpm tends to move out of the range fairly quickly, in which case you would not easily detect it. I could hear the noise in city driving as well as on highways. Mine was most noticeable under acceleration and uphill when the engine works harder than when cruising. The noise went away as soon as I eased myy foot off the accelerator.
Did you ever notice a humming noise. Mine was terrible.
I will give it shot tonight as you mention. I have never heard or notice humming noise of course my car has only 640 miles. The question is do you have this noise form day one? I will post my results tonight after the test.-B
Mine had it since day one. I took it to the dealer when it had less than 1K miles. If you haven't heard the noise, your car is fine. You would not have missed. After I had it fixed, it is now pretty pleasant to drive.
S.
I was unable to hear any humming or noise so my car seems fine for now. I will keep watching and report back. I am glad your car is fixed now.
BTW, my milage also not so good- 17 mpg driving in city. Seems to be good then other people are posting but less then what Honda claims.-B
See message #106 where I described the problem I had.
Good luck to you.
This is not a NORMAL SOUND! How to make HONDA admit it.
I called HONDA AMERICA as noted, and they show nothing on their records. HOWEVER, it seems that the number of customer complaints are not accounted for. The gentleman said that it is the dealer that needs to report the error to Honday serveral times on the same vehicle to invoke a Service Bulletin. So, the dealer looks like they need to start wheels turning. They would not give me a reference number to document my call.
First new car, and what do I get in return... Nice looking, poor sounding.
trying to find a fix for my humming/droning Odyssey. All deny
having any knowledge of a humming problem relating to the
2005-2006 Odyssey.
Today, I had my “A pipe” replaced to no avail.... Now get this, the service manager tells me that the Honda America engineers have solved this problem but wouldn’t be releasing a fix/recall until the 2007 model debut.
Also, people plagued with this problem now would just have to wait.....
I'm ticked off to say the least.....
this time. I will the next time.
DL
as far as controllability and crosswind sensitivity - one of the very attractive aspects of the Hondas i have driven is what i can expect from the cars re: road feedback, vehicle dynamics and stability, which for the accord and the odyssey is quite acceptable to me. this is an important consideration for some drivers when selecting a vehicle to own and operate on a daily basis.
i too have been in rentals while on travel and have been "blown away" by the different experience re: road feedback, steering response, and crosswind sensitivity to my accord. admittedly, i do not have any information w.r.t. crosswind sensitivity in my odyssey vs. some other van as i only have rented sedans and test drives of vans occured on pretty calm days.
i assume vehicle weight is a factor, but suspension and steering setup probably play significant roles among others (perhaps tire size / inflation)? just guessing.
if your lucky enough to have the opportunity, people should try to test drive a car on windy days. you wouldn't want a car that is so sensitive you feel you're fighting the thing, specially if it's gusty. what a major pain that would be.
It looks like the problem your car had was similar to mine.
After I had my A-pipe replaced, the humming noise was virtually gone. Now after a few weeks, I can still hear it when the rpm is at about 2200. I would say the noise is now reduced by 90%. The vibrations can still be felt, specially on the front passenger side with your feet on the floor. I will keep bugging my dealer every time I take my can in for service to let them know that the problem is still there. There is a design flaw somewhere in the area of the exhaust system including the attached points.
My next step is contacting Honda and trying to convince them that this is a problem - maybe not a mechanical or safety issue, certainly an annoyance issue.
If you have an issue with this humming / droning sound, call Honda and let them know.
:confuse:
