Volkswagen Passat Audio
jpbran
Member Posts: 37
Just got my new Passat on Friday. I did NOT spring for the pricey Dynaudio option, though now wish I did. CDs seem to sound more-or-less just OK on the standard stereo, but the Sirius satellite radio audio is pretty weak. Very tinny and weak. No matter how I adjust the bass/treble/mid, it still sounds kinda lame.
Any suggestions? Is it the stereo itself or the speakers? Would new speakers from Crutchfield (or somewhere) help? I LOVE the car, but am not impressed with the audio.
how to manage bass on this car?what i am trying to say is sometimes my breakers vibrate when the bass is on full.
what to do so that my speakers wont; vibrate on this 06 2.0t passat.
That's how it works on the audio system with navigation... Hope this helps!
Why do speakers on my music system vibrate when playing loud music,Is this normal or not?.
If this is normal,then how to listen music loudly without hearing the annyong speaker vibrations?
thankd and do let me know
It sounds like an MP3 compressed at about 48 or 64-ish bit rate, instead of 128 or 160; sounds "metallic," like it is both muffled and overly compressed. The Sirius is about 50% of CD quality.
Has anyone else had this problem with Sat radio in their car? Specifically, has anyone heard of this with Sirius, or more with the VW audio system? ARGH!!!!!!
Yours was a better anwer than disconnecting the battery - funny things can happen when the juice is cut to the entire car. The throttle body might need to be reset after a battery disconnect.
The XM radio was working fine last nigth (I activated it online). However, this morning the XM radio wasn't even available when pressing 'BAND.' I went into settings, and the 'XM' line was greyed out. I couldn't even select it. Any help is appreciated.
BTW: The person you talked to at the dealer is full of cr@p. This feature has nothing to do with security.
For your convenience, I am re-posting the answer below (just this once)
The radio in my 2003 Jetta has a "feature" that changes the volume with roadspeed. The intent of this feature is to overcome the noise of the tires and wind as you go faster. There are several "adjustments" for this feature. It can even be turned off if you dislike it.
As for most of the "complaints" in these forums... the answer is READ YOUR OWNERS MANUAL FROM COVER TO COVER. I am certain you will learn a lot about your new car that you did not even know existed.
My 1999 Passat's stereo just doesn't hit the low lows, because there's not chamber to resonate, and unfortunately VW appears to try to make up for this by over amplifying the 200 to 300 cycle range. Do I have to get a subwoofer? Is it easy to run the back speaker wires to the back dash and cut holes - and if I do will the crossover foil me?
http://www.dynaudio.com/eng/auto/passat.php?sid=4593131e8c9a3
You may be better off looking for a "used" Monsoon system from somone that upgraded theirs.
IMPORTANT: Make CERTAIN you get the "code" that goes with it otherwise it will be unusable.
I've just purchased a 2001 Volkswagen Passt which is fitted with a 'Gamma' Model radio which i think is made by Blaupunkt.
When i purchased the car from an auction, everything worked apart from the radio which i assumed didnt work as the battery was almost dead so i assumed it must've gone into shut-down mode and didn't start due to insufficient power in the battery.
now the car is working fine, starts ok, but their is still no power to the radio and cd player (separate units as i've got both tape & cd).
i cant work out the fuse layout as the fuse layout card doesn't tell you what fuse it should be, and the fuse reqd.
any help in sorting out this issue is very very much appreciated.
thanks in advance
Bav.
I think it involves pulling a fuse for awhile and perhaps even holding down some sequence of buttons on the radio.
I know that does not help you much... but there is hope for your radio 8-)
convenient spot and connect to your ipod. I plan on using velcro to attach the ipod to a convenient spot on the console. Press the CD button twice on your radio and you will see AUX ext. Start ipod and you're set. You might need to adjust the volume on the ipod higher. I just got an 07 Passat and I have to do the install myself. Enjoy
Any help anyone could provide would be great.
***Also as an FYI to '06 Passat owners (and some other VW models), the compressors in the car have been found to be faulty and IF anyone notices their A/C taking about 10mins or longer to blow cool air- BRING BACK to dealership and have them REPLACE the compressor. SO many people have had the prob that I'm actually waiting on one on NATIONAL BACKORDER at the moment. Allegedly, VW would have placed a recall on such only that it would cost them so much money they cannot afford to do so. My car is currently in the shop as we speak (been there for a wk already!) and I've only had it 10mos!!! And as most of you know, the Northeast is experiencing a heat wave at the moment and so a non-functioning A/C on a 10-mo old car just didn't fly with me.
IF anyone has any questions pertaining to the 06 model or would like to talk about it, drop a msg bc I'm looking for other people with the car to talk to.
One more thing--if there isn't a multifunctional shark fin available that I'm looking for, will the 06 Passat multifunctional antenna fit on mine?
As for the key- I dunno why but I want to say that my sales rep told us that you're only supposed to get one...but bc we insisted on having another, somehow he was able to obtain another...I think he said IF you EVER need to replace the key, that they cost $200 bc of the design of it (a keyfob). I could be wrong. Maybe they're supposed to give you 2, but I seem to remember my sales rep telling us they don't give out second keys...but he got one for us bc we insisted we needed one. You may want to check with another VW owner to find out whether they received 2 keys.
As for my overall experience with the car- it's been good- though I have had one major issue and a few minor ones. First off, let me warn you that if you're A/C goes on the car, GET that car to the dealer IMMEDIATELY and have them replace the compressor. The 06's have faulty compressors. I had to have mine replaced and UNFORTUNATELY it happened during a heatwave. They replaced it free of charge THOUGH they were NOT so quick to diagnose the problem! I brought it to their attention bc I found A LOT of info on the web about it.
Once I got the car back, the AC was fine. No problems AT ALL. The A/C was fine UP until the point the compressor went AS WELL. It's just that all of a sudden one day in the middle of a heatwave, my car started taking MORE than the norm to cool down. It was taking about 10-15mins INSTEAD of about 2-3mins. It woudl blow air the temp of the air outside the car.
Since I had that prob taken care of, I've ONLY had minor little things go wrong. My driver side visor does not light. My window lock button does not work. The driver side visor light is a common problem. I've spoken to other people with that problem. Next time I have my oil changed, I'll have them order the part.
Other than that, I LOVE everything about the car. It runs smoothly. It runs fairly quietly. It's got great pickup. It's a beautiful car. You name it. I like it.
Just one thing to beware of AT FIRST is that the car has a tendency to EAT oil...You may need to add oil BEFORE You go for your first oil change. I NEEDED desperately to add oil to mine. I was only about 2500 miles in or so when it DESPERATELY needed oil. But since then, I have NOT had to add oil in btwn changes. I'm at about 11000miles now...I've had the car a little over a year and just to be safe- I've had 2 oil changes already. My third one is coming up. At first I brought the car in at about 3000miles or so just to be safe...then at about 7500 or so. Now I'm taking it in in intervals of 5000miles bc it's synthetic oil which can stay in the car longer than the norm.
Lastly as for the ipod- I haven't looked much into it since I last posted. I can play the ipod through the radio with the help of the DLO Transpod but it's NOT clear at all times. I was looking for a way to play it through the car stereo itself...and not have to play it through the radio waves...unfortunately I dunno that there is a way to do that with this car since it doesn't have an auxiliary jack. At least mine doesn't. My model is the model without the satellite radio. I think it's like one above the value model. It's the 2.0T but NOT the value edition. Yet, it still doesn't have satellite radio. It doesn't have that little black fin on the back.
Anyhow hope this answers some of your questions. I know when I first got the car I had SO MANY questions (as it was my FIRST VW) but no one to answer them. I hope I was able to answer them and give you some detail. Good luck with the car! Keep me posted!
It is VERY strongly suggested that when you purchase a used VW to INSIST on getting all the keys (or write into the contract that the seller will pay for any missing keys) Do not forget, when you are negotiating the the sale.... YOU are in full control about what is written into the contract.
Of couirse, you may negotiate a reduced price in lew of any missing keys. (assume $120 per missing key!)
I'm finding it hard to believe that two different units would only receive in these few stations. It is more likely user error. Please help - I'd like to listen to more than espn news.
Another thing: I saw on the Passat photo there is an antenna on the top of the roof, in the middle just above rear windshield glass. Is that for satellite radio? The diversity antenna is only available on the comfort and above model. Mine is the base model turbo. I wonder where my antenna is. my radio does get clear signals, though.
My mothers 04 Jetta has the Monsoon, and I love it! It has a factory Amp in the trunk, but, I looked at the Passat and haven't seen one yet... I am hoping there is one, that will be all the better, I love my music!
Please let me know.
The RNS-510 however is coming for the 09 models. It's an Improved touch screen navigation system with dynaudio support. Supports the MDI very well and the European skoda bluetooth kit. RNS-510 has Built in sirius radio and live Sirius traffic. This system can be retrofitted but needs the US maps and a sirius antenna extension cable. The hard drive can store maps and 17.67 GB of your favorite tunes. SD card is a plus. Has DVD Video, MP3, and WMA. Can play DVD movies while in park. Only works up to 2 GB SD cards.
VW is also planning an RCD-510. The RCD-510 has the same touchscreen display but no navigation. Same bluetooth integration. No hard drive for music but has a SD Card slot. RCD-510 has a 6 disc CD changer. No sirius traffic but Sirius SAT radio will also be included in the US version. No DVD Movie support but has MP3 and WMA. Great for those who prefer portable over OEM integration. Can have a nice OEM touch screen but no navigation. VW wants to have touch screen controls and this is what they are planning.
