Chevrolet Impala: Problems & Solutions
I thought it might be useful to have
a central location where the current
status of the various common Impala
problems could be found. This topic
seems to be an appropriate place.
Below is a partial list of the
problems I can remember. Others may
want to add to the list and those
with experience or knowledge of the
problems could summarize the
condition, update and supply status
details, fixes, solutions and TSBs
currently being employed by GM and
dealers. Copying some pertinent posts from the main Impala topic might be a simple way to start.
Problems:
** Engine shutdown at speed.
** Engine shutdown at idle.
** Engine stutterings.
** Click sounds from cradle.
** Clunk sounds from steering column.
** Poor radio performance.
** Wheel well coverings.
** Poor fit of headliner @ moonroof.
** Road noise from tires.
** Non-recording of problem codes.
Problems:
* Click sounds from cradle = Rear cradle frame brackets not welded around the sides, only on the bottom. This problem only applies to 2000 Model year Impala/Montecarlo vehicles. TSB for "Rear cradle Shim Material Fix" issued on 10/23/2000, addresses the engine cradle clicks and other noises related to unintended movement of these rear support brackets. GM has discouraged dealers to attempt to rectify the welds with aftermarket welding procedures. The Shim material fix is as good as it gets for 2000 model year owners.
The engine cradle problems have been corrected properly on 2001 model year Impalas. Hint: If buying a new Impala try to get one built after 10/2000.
The TSB number for the "Shim Material" cradle fix is: #00-08-61-003 dated 10/23/2000. The official TSB title is "Clunk/Pop Noise from front of Vehicle (Shim Rear Frame/Cradle Mounts)" It applies ONLY to all 2000 model year Impala/Montecarlo vehicles
I want a new cradle or I'm buying a dodge.
Has your dealer replaced the intermediate steering shaft??
I had the same exact problem and the Intermediate Steering shaft was the culprit behind the steering clunking noises I was experiencing. This seems to be a very widespread problem on 2000 model year Impalas.
And..do yourself a favor....Don't buy a Dodge! Do you want to have a transmission failure at 40K miles?
I don't think so!
Let me know if you have any other questions, as I have traveled down this road before.
Dear Readers,
I'm departing this week from the usual question-and-answer
format to issue a warning: The manufacturer's recommended
service interval for extended life anti-freeze/coolant is true
only for well-maintained cooling systems.
Extended life anti-freeze/coolant has been the
factory fill on most General Motors vehicles built since 1996,
most Ford vehicles built since 1999, and some Chrysler
vehicles built since 2000. Unlike traditional green anti-freeze,
DEX-COOL(R) is orange/pink in color.
Technicians all over North America
report that extended life anti-freeze can turn into rusty jelly
well before the 60,000 mile mark -- even, in some cases, in as
little at 30,000 miles. The jellied coolant is extremely difficult
to remove from the system. Depending upon the severity of the
problem, the heater core, radiator, and core plugs may need to
be removed and/or replaced. Repairs can cost hundreds
dollars or more, and aren't easily performed at home.
Although it makes no mention of "rusty jelly," General Motors
bulletin No. 99-06-01-12B, "Engine Overheats, Rust in
Coolant, Heater Inoperative," attributes rust to running the car
"for extended periods of time with a low coolant level
(usually in excess of 20,000 miles)." The bulletin recommends
using a heavy duty chemical cleaner (one that requires a
neutralizer), and power flushing the system at normal engine
operating temperature for two and a half or three hours.
How do you avoid this problem? Many postings in the
"technicians only" section of the International Automotive
Technicians' Network (www.iatn.net) concur with the GM
bulletin that the problem is caused by neglect.
Don't let the coolant level get low. Check it at least once a
month. If it's low, top it off with a 50/50 mix of anti-freeze and
water. If your tap water is extremely hard, substitute distilled
water. Avoid mixing extended life (orange) anti-freeze with
traditional (green) anti-freeze, or vice-versa. Both are ethylene
glycol products and theoretically compatible, but mixing the
two "muddies the waters" literally and figuratively. Under no
circumstances mix "pet safe" propylene glycol anti-freeze (e.g.
Sierra) with DEX-COOL(R).
Have your coolant tested at least once a year. The Texaco
product sheet states DEX-COOL(R) coolant should have a pH
of about 8.3. General Motors bulletin 73-62-13A states that
freeze protection, as measured with a refractometer (NOT a
floating ball tester), should be minus-34 degrees Fahrenheit.
Change the coolant regardless of mileage if tests show it to be
marginal. If you're in doubt, follow the traditional coolant
change interval of two years or 24,000 miles. Always replace
DEX-COOL(R) with DEX-COOL(R) to properly maintain
your vehicle warranty.
The poping noise occurs when you speed up and also when you slow down. One time pop for each case. Seems to pop more often and louder when the weather is warmer. I had the original repair done just before winter and the poping came back once the weather was above 50 degrees here recently in PA.
This problem has been fixed with the extra welds on the newer models.
My question is, is this shim fix going to work and be just as strong and last as long as a fully welded 2001 cradle?
Just so you know this poping noise doesn't happen when you steer. I did have clicking noises when I would turn the wheel so they replaced my rack and those are gone, maybe for another few months.
I love my Impala and I want to keep it but if it's just going to have problems with the cradle, I don't feel safe.
I want to feel safe.
wwnf
Impala 2000 LS, built/bought 8/99, 29,440 miles
This started with a tire that went nearly flat before the light came on. They replaced the tire. Now the light is on all the time.
Anyone else have this problem or know of the bulletin that GM has put out about the sensitivity of these monitors?
You can look for current TSBs (technical service bulletins) through the NHTSA link on Edmunds.com.
Hope this helps!
KarenS
Owner's Clubs
Anytime that you rotate/change your tires you need to reset you tire monitor system.
Check your manual if you need help on how.
later
wwnf
http://home.hawaii.rr.com/impala/Welcome.html
later
wwnf
"For those of you who still have the cradle clicking and/or steering problem, the following might be of interest:
..... A few weeks ago, the steering clunks diminished and the cradle clicks came back, but less severely. Obviously, there is some kind of a connection between the two problems.
... When I explained to the service manager that did I not want the shim fix for the cradle, he informed me they were no longer doing that. Instead GM was once again replacing cradles!
The replacement cradles are not 2001 units. They are 2000s that have been STRESS TESTED and so stamped - I don't know if they are also reinforced. He explained that early on, the cradles were not tested and that some faulty ones got installed. These are the ones we have been reading and posting about for the last year. Further, he said that the cradle replacemnt would probably fix the steering clunking problem and if it did not, GM would replace the intermediate steering column (essentialy, a universal joint to change the steering column's direction). The service manager also mentioned that the intermediate steering column clunking is a common problem on some of the GM cars.
Its only a few days now since the new cradle was installed, so obviously no definitive fix can be claimed. But, so far, so good. The LS has no more clicks or clunks. It's tight and feels like it did when I fist got it. ...."
Picked up my car yesterday. It had been in the shop for the "clunking" noise and front brakes pads repair. Anyway, it's running fine. Apparently, the service dept. found that the
intermediate steering shaft was too tight and causing noise. Therefore, they removed old
steering intermediate shaft and ordered a new one and replaced it. They also inspected and
tightened the cradle bolts. When I drove the car, I got a much better feel in the steering wheel,
especially when making turns. No more noise! They also discovered a loose track under the
driver seat. The part was ordered and I'm waiting for it to come in.
Thanks for the help and advice.
Susan
Wont be able to give feed back because I am trading my 2000 LS for an Avalanche.
My tires did make noise too. I just replaced with Kelly Chargers and no more noise. I think it is a GoodYear tire problem. I had a Monte Carlo with the same issue. One thing that bothers me is the AM radio stations come in very poorly. I took the car in several times for this problem and it was never resolved. Perhaps I will call Chevrolet on the problem.
Besides those minor problems. The car has been perfect. I have not even had to put brakes on it yet. It handles and runs great. I will probably buy another Impala.
Front end clicking: What is the build date of your 2001 Impala????
(Check the factory sticker located inside the driver's door jamb)
Get that info first...
ontheotherhandiknowsomeguyswhorefusetousetheshiftkeyatall, andwhomustbeusingadefectivekeyboardthatdoesnothaveaspacebar. itsashamethatwecantallbesuchgoodtypersasoutbuddyteo!
Not to knock your problem, but it will be easier and it is somewhat courteous if you'd like a response to take the time to post with punctuation and grammar correct.
Spelling is a different story - I'm guilty there sometimes!:>
So I have to ask, has anyone else had problems with their tires or brakes?
In a few days I will have had this car 1 year and this is the only problem that I have had. I really, really like this car!
Thanks in advance for any input.
I too had the issue with warped brake rotors. This is caused in many cases by overtorqueing the lug nuts (some service guys never heard of a torque wrench). If your car is under warranty don't let them get away with just turning the rotors. Make them put new ones on. If they turn them they effectively shorten the life of the rotor (most can only be turned once) and you'll be footing the bill for new rotors right after your warranty runs out.
by the time I brought it to the dealer, the car was at around 13500
my dealer said the rotors were only warrantied for 12000 miles and suggested I just stay with my current setup as opposed to paying for rotor replacements
my car is now at 17000 miles (shimmy still present)
One possibilty is to run the car for maybe 2000 miles after the oil change, then manually reset the OLM, and wait for it to trigger. That would allow me to run synthetics for one normal "lifetime", plus 2000 miles, between changes. Another possibility is to wait for the OLM to go off twice, which would have me running synthetic for twice the life of normal oil.
I guess my ignornace is showing. Anyone have an idea as to what kind of benchmark I should use, and how to use the OLM to help me change my oil in a smart (=non wasteful) manner? I would really hate to be changing oil that dosen't need changing, especially when Mobil One is running $4.59 a quart!
Rotors, I have had my oem rotors turned TWICE. My shop guy has told me that my rotors are cheap plus my imapala is under braked. Too much heat. So I'm trying to look into high performance brake/rotors so I don't have to worry about it anymore. I've been finding it very hard to find anyone who sells any. Most auto parts only carry the cheap stuff. I've looked in PowerStop rotors with 911 brake pads but they don't make the pads for the impala the guy said. Oh well, I will be looking some more.
later
That doesn't make any sense to me. This car has monster sized brakes and so far have had no problems in this area. Malibus are notorious for premature brake wear problems and those cars are incredibly underbraked...but the Impala? I don't buy that.
NEVER agree to have the rotors turned. This just decreases the useful life of the part. If you ever experience premature rotor warping problems under warranty, insist to have the rotors replaced with NEW units. Also, make sure that whenever the car gets its tires rotated or the brakes are serviced that the lug nuts are manually HAND wrenched to specifications. NEVER allowed them to use an air wrench to tighten the nuts...this will only cause to warp the rotors due to excessive lug nut torque!!!!!
http://www.shotimes.com/brakes/part1.html
Is it 90 or 100ft lbs for the Impala LS???
Your car has a build date of '10/99' or 10/00'????
If it is the first,your car is a 2000 Model year Impala.
If it is the second date, then your car is a 2001 Model year Impala...
Which one is it?
This means that your car built in 10/00 barely missed some of these important changes.
But to make absolutely sure, please refer to this excellent Impala website. Read the section titled "How to indentify a 2000 and 2001 engine cradle". Its got pictures that I took a few months ago, along with full detailed explanations on how to identify a new revised cradle from an old one, what to do, etc.
To check your engine cradle and the two rear most brackets in the cradle assembly, it is advisable that you put your car in a lift as it will be very difficult for you to slide all the way under the car to see these brackets.
Here is the link to the website:
If you have any further questions, pls let me know.
Good luck!
