My second guess would be the multi-function lighting switch on the steering column.
the fuse for the dome light is under the hood, in the fuse block next to the battery (at least in my 1997 Camry). there are a few clips that release the long, black plastic lid of the fuse block and there is a diagram of the fuses on the underside of the lid.
i took a quick picture showing the dome fuse:
If that is good, and you've already checked the 15A Tail fuse, then I would suspect the Taillight Relay. The way it works is that the taillight relay is turned on, by the integration relay. When the taillight relay is engaged, it provides power to the 15A tail fuse. You need to make sure that relay is turning on, and the secondary points have connected providing power to the 15A tail fuse. One easy way to check, is to pull the 15A tail fuse, and with the light switch on, with a digital voltmeter you should find 13.5 +/- volts on 'one' of the legs in the socket where the tail fuse was.
Lightswitch turns on the integration relay, integration relay turns on the taillight relay, the taillight relay provides power to the tail fuse. The tail fuse provides power to the dash lights, tail lights, etc.
Thank You
- 7.5Amp "Panel" fuse, in the fuse box by your left knee. Or it's the
- 15 Amp "Cig" fuse, or it's the
- 7.5 Amp "Dome" fuse
You probably blew it by something in your cigarette lighter outlet.
See your owners manual.
driver side windows work ok .
central locking system does not work u need to lock unlock each door manually .
any suggestion plz.
thanks .
For the power window circuitry, there basic power comes from the 30A power fuse, goes thru the power relay (which is turned on by the integration relay), and feeds all of the power window switches. The fact that at least the drivers window works, leads me to conclude that the power fuse and relay are okay. You should try the windows switches on each of the other doors, to verify that they are able to control each of the individual windows. If so, then I would conclude that your window motors are okay and suspect that your window problem is caused by a bad drivers side door panel switch. You would verify that before replacing, by checking the workings of the switches with a voltmeter.
If the individual door switches do NOT work correctly, then the problem could be that all 3 of the non-driver motors are blown (very unlikely, but possible), or again the drivers side door switch is bad. Here again, the proof would come from a voltmeter on the switches.
The door lock circuitry, has three power sources. The 30A power fed thru the power relay (which should be okay based upon your driver window working), and a 10A Gauge and 25A Door fuse which feed the integration relay circuitry, which then contorls the door locks. Verfiy that those two fuses are okay, visually and with a voltmeter/ohmmeter. If fuse bad, replace it and retest. If not bad, then we start to suspect that the integration relay is bad.
windows does not work from any switch. every thing quit working at once central locking , keyless entry ,window rolling and little clock in the dash. i did lock my car with remote at my work and every thing was working fine. end of day when i try to unlock the door with remote it did not work i did open driver side door with key which is may be first time in 10 years of car life i did. the alarm go off. after couple of minutes i turn the ignition on car started and i drove home . every thing looks ok except dash clock. then i notice all the problem mentioned above. i will also check voltage at each window switch after work. but i feel like main culprit is some kind of fuse or relay .
"driver side windows work ok "
Given that windows do NOT work, then check the 3 fuses that I referenced earlier.
With NONE of the windows working, it is much more likely a fuse issue, so just check those first.
It's in the fuse box by your left knee, 3rd row down, 2nd fuse over.
Your owners manual would show you where that's at.
Any ideas on what to check next? PLEASE HELP!
Get a digital voltmeter, and check the voltage of the battery, it should be sitting around 13.5 to 14.0 volts. If you are down at 10-12 volts you still have a battery problem.
Verify that your voltage is good, and if so we can take you deeper into the electronics to trouble shoot. You may have blown another larger fuse or alternator out while putting the battery in. Who did this installation work?
If so, the alternator could be bad. But that circuit feeds a lot of other stuff, so we'll have to do some sleuthing to figure out what is causing the problem. Don't want to jump immediately to the alternator, but at this point since you were working there....that is probably more likely.
Who did the alternator repair......where did the part come from, and who put it in?
Who did the battery repair....where did the part come from, and who put it in?
Depending upon where the products came from, and who installed them, will determine the suggested course of action to diagnose/fix.
We bought the parts from AutoZone and did the work ourselves, meaning my dad and I. My dad is a retired mechanic so he knows a lot about cars. The battery is also from AutoZone. Right now we're looking around to see if there's a wire that's been stripped or is touching the metal frame. When we bought the car it was missing the radio, so we're looking to see if something happened when they took it out.
The battery says 14.64 and so does the alternator so we really don't think it's either of those.
Since the 10A Gauge powers the control circuitry in the Alternator, I think there are at least two scenarios that are possible:
1.) It could be that there is some problem in the wiring, causing the 10A Gauge to blow, which in turn makes the alternator not work because it doesn't have any voltage to power the control circuitry. That then, causes the battery to run down as it's not charged. Hence, you may have replaced an okay alternator and and an okay battery......unless at AutoZone you had them check the alternator and battery before replacing.
2.) It could be that the new alternator is bad, and there is a short in the control circuitry, which is causing the 10A gauge fuse to blow. That is causing all the other things on that circuit to not work.
One thing you could try, is to unplug the alternator, replace the fuse, and then try to run the car without the alternator in the circuit. You'd be running just on the battery at that point. If the fuse blows again, you've eliminated the alternator as being the cause of the problem. If the car runs fine, then you should suspect the alternator is bad.
One thing you should also check, since you are checking some wiring. Get on your back and lay down in the trunk, with your head up by the left drivers side rear seat. Inspect the wiring, wear it rubs against the metal framing as you open and close the trunk. Sometimes people overjam things in the trunk, the wiring becomes pinched or wears, and shorts out.
Any other suggestions?
- combo meter
- cruise control
- door lock control
- transmission
- engine computer
- key reminder and seat belt
- headlight control
- light auto turn off
- moon roof
- power windows
- stop light
- tail light
Note: a number of items have the control circuitry powered by the gauge fuse, but then has another fuse for that same item which may go thru the secondary points of a relay. As an example, the control circuitry powers and controls a relay, when the relay is turned on it supplies power to the device thru a different fuse.
Take a look at all of the relays, see if any of them look (or smell) burnt/melted.
Looks like you found out why they were interested in selling it.
Let me go look at the schematics, and see if there is some way I can get you to unhook some couplers to see if we can get it to stop blowing the fuse.
Radio was removed.
Whoever installed that 15 fuse amp may have done so knowingly and for good logical reason. I would first try another 15 amp fuse on the chance some past owner knowingly put an extra load level on that circuit.
Was a new radio installed and who did the work..??
As of right now, there is no radio in the car. The person that owned it before said he took it out and to a place to get the radio fixed because there was a cd stuck in it. He also said it was expensive to fix and it would have been cheaper for him to buy another factory one. We were gonna put a Sony one in that we had already bought awhile ago.
The purpose of a fuse, is to blow before the wire burns......it protects the wire.
If you burn the wire, you'll have a real mess trying to re-wire that circuit.
Try disconnecting the park/neutral switch, to see if it is causing the fuse to blow. You can also disconnect the reverse switch on the tranny, and pull out the daytime running light relays. If those don't cause the fuse to stop blowing, pull out the integration relay. You can also try disconnecting the connector on the speedometer, which provides the power to pin 7. Pull out the cruise control computer, that is also powered by the fuse.
Turn the instrument, guage panel back lighting down to minimum and then check with a new fuse.
But is this relevant: When the fuse is out, the battery and the alternator are running at 12.15. As soon as that fuse is in, it goes up to 14.64.
Also when the fuse first blew, we were driving up a hill and smelled like something was burning...almost like burnt metal.
When it blew the second time after we thought we fixed it, I was going up a little hill. It blew again, when the key was just in the ignition and then again shortly after the car started.
Without power to the circuitry, the alternator is just free spinning, no producing any output voltage/current to charge the battery. As a result, the engine is just running off of the battery.
When you put the fuse in, the alternator control circuitry would determine that it needs to charge up the battery, and would try to do now do so.
If you smelled something burning, something undoubtedly burnt. You will need to inspect the wiring to see where the insulation is worn off and touching metal somewhere. You should never put a higher rated fuse than the wiring is rated at....you'll burn the wiring instead of tripping the fuse.
Start at the 10Gauge fuse, and start tracing the wire to all of it's branches. It is going to be a nightmare. You might actually be better just re-wiring that circuit with new. You are going to need to buy a set of Toyota electrical schematics for your vehicle.
Or simply subscribe to techinfo.toyota.com for a day and print them out.
It appears the car ran for quite some time, some period of time, with that 15 amp fuse installed.
What changed to blow that fuse..??
You turned up the instrument panel lighting level.....??
The 10A gauge fuse provides power to a number of things including the gauges, which allows the gauges to work. The illumination of the gauges at night with the rheostat controlled dimmer is powered via the 7.5 Panel fuse.
Two different circuits.
Thanks for any help
Nick
Did you check the 15A "Tail" fuse?
Let me know what you find.
Thanks for the speedy response.
All other lights are in working order.
Actually, I think I need to go check whether all the bulbs dim, or only some of them.
What I'm trying to verify, is that when you turn the rheostat....at least some of the bulbs are dimming. That would let us know that the circuit is working.
I guess after 16 years it's reasonable to burn out a bulb or two.
Personally, I'm not sure it would bother me enough to replace them. I'd write it off as my attempt of 'going green', saving electricity.....
- 7.5 Amp Panel
- 7.5 Amp Dome
and you say the 15A cig is okay.
