This car only has 71500 miles on it, and in the 1 year I have owned it, it has incurred over $13,000 in repairs. All mechanical, and all related to problems with the engine.
Several days later I took the car in to Savannah Toyota (where I bought it) and after running a diagnostic test the technician, according to the invoice, "Replaced Charcoal Canister." (On the invoice I also see "PULLED PO441, 442, 446", whatever that means.) The light did go out, but two days later (July 30th) the "Check Engine Light" came on again and stayed on.
A few days ago I finally got around to taking the car in again and had a second diagnostic test done. This time the invoice reads "PO 440, 441 VAC. VALVE SWITCH INOP REPLACED." So I assume that means some sort of valve switch was replaced. In any case, today the "Check Engine Light" came on once more and has stayed on.
Has anyone had a similar problem, and, if so, how was it resolved? Both times I've wasted approximately three hours at Savannah Toyota, and this is really starting to get annoying.
"Is there a sludge problem on the 2003 Avalon XLS with the 3.0L 1MZ V-6 engine?"
After announcement of the sludge policy in 2002, Toyota made some running changes to the V-6 engine to help prevent the build-up of sludge. This was reported to be a modification to the PCV system and some other minor engine modifications.
"Has anyone figured out why there is a sludge problem on some Toyotas? "
There has been nothing definitive reported, only a lot of theories. Toyota continues to blame it on owner lack of maintenance. Based on the changes Toyota made to the 2003 engine, it may have been due to the PCV design. Others have claimed that the engine runs hot, cooking the oil and turning it to sludge. The long oil change intervals recommended by Toyota (7,500 mi. normal driving conditions and 5,000 mi. severe driving) were also pointed to as a possible contributor to the problem.
I have 40K on my 02 Avalon. I change the oil every 5K, almost on the decimel. I use regular or blend during the months other than winter (North Country) where I use Mobil 1 synthetic 0W-30 (Viscosity is superior in temps below 0 F.)
I have NO sludge problem. I do not burn any oil.
abfisch
I know they extended the oil for sludging problem to 8? years. I could just keep filling it with oil and turn it in at the end of the lease and shut up. I have the receipts to show that I did all of the required maintenance. I am wondering if there is any other explanation for the oil use?
I would prefer to come clean now and get the car fixed before it comes off lease. Any suggestions? Thanks for your help.
I was told that the car must be fixed before I can surrender it at the end of the lease, even if the problem is covered by the warranty.
I strongly suspect that I am going to need a complete rebuild just like I had at 26,000 km. I probably won't see the car again because the lease is up at on March 22nd.
Does anyone know if the extended warranty for the oil sludge problem entitles you to a loaner?
I've searched the major Avalon discussions and have not found anything like this. Has anyone else experienced this type of problem?
The "chug" at 6200 RPM sounds like you are hitting the REV limiter, which I think is at 6300 on these cars. -nomad56-
Another clue. Maybe unrelated, but after a leaving a rest-stop on a long highway drive 2 days ago, my check-engine light and VSC lights went on and stayed on. Otherwise, engine performance and gas mileage are just fine. My gas-cap was tightened correctly (which was the cause of the same problem two years ago). I have an appointment at the dealer tomorrow to read the computer and reset the lights. I want to be prepared to accept or reject any service they recommend (like an engine flush).
Please post the results of your dealer's diagnosis.
I had a Mazda 626 GT a number of years ago that did the same kind of knocking going up slight inclines in high gear. Like your Avalon, the problem began after many thousands of miles had been put on the car. I was already using premium gasoline and the knock sensor was working properly. I found the timing when the car was built was set 2 degrees higher than specification. Reducing the timing to specification permanently eliminated the knocking.
Code P0171 indicated the Mass Air flow meter needed cleaning. This could have triggered the check engine light. This could also explain the knocking problem. The car runs smooth now with no knocking.
Codes C1301 and C0215 relate to independent tire spin in rear wheels compared to fronts. I had my wheels alligned about 500 miles prior to the incident that caused the check engine light to go on. But the dealer speculated that these codes could have been stored, and the VSC lights then went on after the air-flow meter problem caused the check-engine light to appear on.
In all cases, my car went over a bump while coasting when the light activated.
My independent mechanic said it was an electrical wire probably loose.
I'm thinking it could be a fuel injector (or 2) going bad. Any thoughts?
a bit brown.
What do you mean by the problem still being there?
You could put a High performance air filter in. That may do something, but I would not mess around with this engine too much. They just have too much electronic componetry to mess with, and having a first model year (2000) I would hesitate.
The suspension is something different. Same as the old Camry and ES300. You can put on Tokico HP shocks, and Energy Suspension sway bars PU bushings as well as front control arm bushing. The handling will change substantially.
abfisch
Please advise me. I am very worried.
I bought 1999 Avalon XL with 90K miles in ebay. I found the previous owner didn't do anything except oil change. Immediately, I did
- All brakes and all tires.
- trunk release cable.
- Charcoal canister at dealer.
The car WAS GREAT. It gave 27 miles/gallon (I drive slowly on highway) and was very powerful and smooth.
Then, the problem came. I saw SIGNIFICANT power loss and the gas mileage dropped to 24m/gallon.
I checked and found that the transmission fluid was BROWN. I went to VALVOLINE (was it a mistake???) to flush the transmission fluid completely. I am NOT sure if they used the correct fluid. After then, the power loss became MUCH WORSE and gas mileage became 21m/gallon on highway. I feel as if I am towing a heavy trailer.
I will do spark plug change. But there must be some bigger problems. No check engine light is on....
Please advise me. Thanks.
A Toyota dealer or a good independent garage should be able to find the problem. But you do have a problem at 21 mpg highway and it is probably not the sparkplugs.
As long as the proper transmission fluid was used and the transmission is shifting normally the cause for your mpg loss is probably elsewhere. You didn't mention changing the engine air filter.
Agree with fin.
I did
- Spark plug change. --> It didn't fix.
- Brake check -> It was moving OK.
- Transmission. --> Probilt said it looked OK.
The issue is MPG AND the power. I knew how powerful the Avalon was. Now, it is like a UHAUL truck at uphill.
I begin to suspect
- the HESS gas station where I went before it happened. Any wrong additives?
- mis-timing (firing) due to slipped timing belt? The belt is original but it is FINE. Can spilted oil make it slip??
Once thing I recall is
- The same power loss was observed WHEN the check engine light came on last month. Then Dealer changed the Charcoal Canister as I said earlier. After Charcoal canister was replaced and dealer reset the computer, the power came back. Someone said that "Changing charcoal canister CAN'T affect power". Is it true ????????
If so, can resetting the computer make the difference? can it be computer problem??? As I said, 'check engine light' is NOT on now.
I had no problem so far with any toyota engines. Any similar experience or advice would be appreciated.
This made a noticable improvement on power, don't remember a loss of mpg though.
MikeS.
Poor accelleration and performance can also be from the vacuum system, such as leaving the EGR engaged, etc. Also might check any electrical connections near or at the cannister location.
Just worth checking....
I've got a '95 Avalon with 158,000 miles on it, and I'd like to keep it for another year or two. Dealer tells me my valve-cover gaskets are leaking, and the fix will cost $700, including materials. Seems like a whole lot of money to me, at $80 per hour. Is this something I should entrust only to the dealer, or can any competent mechanic do it? If the latter is a possibility, about how much should I expect to pay in the suburban DC area?
I'd like to have a new Limited, and She-Who-Must-Be-Obeyed has okayed the release of funds, but I'd feel better about waiting for another year or so, just in case there are some "kinks" in the new model. Besides, I think the colors offered now are REALLY crappy!
Thanks----Phil
Thanks for your input..my sentiments exactly...at $60 for parts, that leaves a $640 labor charge, @ my dealer's $80.00 per hour rate. It just boggles the imagination that Miller Toyota in Manassas needs to take 8 hours of a qualified mechanic's time to do what I consider to be a Mickey Mouse job!!!!
p.s. I just did a quick check of my service record receipts, and nowhere have I found that my pcv valve was ever replaced, even after 159,000 miles....could that be the culprit, or is it better to just blame the mileage?
