Toyota Avalon Interior
01 Avalon XLS, 22000KM. Rattles from front right door on any hush roads. Anyone experiences this? How to solve it. Have sent the cat back to dealer for 5 times without fixing it.
Annoying!!
Thanks in advance for any suggestions.
Annoying!!
We bought 2 Toyotas in the last 2 years thinking their quality and service was top-notch only to find out they're no better than anybody else.
Has anyone else had this problem or maybe know what can be done?
The window channels are clean and so is the glass. It has happened to both right side windows in the last few weeks: They won't open. Nothing wrong with the electrical connections - I can hear the motor in the door click. On the rear window I was able to get it free by pushing down on the glass while pushing the power window button. The passenger side front required taking off the door panel and tapping the track while pushing the button.
Everything is clean and the windows work fine once freed.
Sweet tech advice on the HVAC system. Not my game above.
Sticky windows. You found the problem. To prevent it the easiest way, I have gotta think, some "Blue Marine Grease" (Hydrophilic) in the slides, will keep it from sticking. You have an 8 year old car, and I would imagine the seals and channels have changed a little. Without replacing the entire mechanism, I would first try some Blue Marine Grease or any good quality synthetic grease on the mechanism that sticks to it, Weather or not.
abfisch
I was able to pass a wire completely around the glass along the door frame, so I'm sure it was not sticking to the channels or weather strip. That leaves the track. The plastic (that holds the window) that rides on the track was not rough and appeared undamaged. The track itself was clean with no rough spots, though there was some lubricant on it.
I suppose it could be the window motors, but two at once?
The manual says that the displayed value is updated every 2 seconds, so I expect the value to change, but not wildly.
Is there something I need to do to "set it" or is this something I should check with Toyota about? (Car has 29,000 miles, and I purchased the extended 100,000 warranty.)
Nick
My dealer did a diagnosis and has determined that both the sensor and the left airbag unit needs to be replaced based on an error code from the diagnosis. The cost is rather steep - $930!!
My questions are
- Is it possible for an original, undeployed airbag to be deemed faulty?
- What can happen to it that necessitates a replacement?
Before I ask the dealer to go ahead and replace the airbag I thought I will request this forum to weigh in!! If any of you have an experience with this, I would appreciate a response.
PS. The Toyota Customer Service did a search for me and didn't find any recall. Additionally they were not very useful with hints on how to verify the dealer's claim!!
...or, any work that included an airbag "reset"???
If the diagnostic code is for sensor/airbag replacement, I (personally/IMO) would start with the sensor, first, and retest. You may also get a second opinion. Perhaps with a tech who has seen this before???? ...but, I am imagining it is unusual. -nomad56-
Thx for the response.
Nope - no struts work or airbag reset! The service reps at my dealership don't appear interested in probing into this issue but rather would replace the unit. Hence, I'm wary!!
I will try to get some other opinions - one problem is that a diagnostic costs around $70 - so there is cost associated with these additional opinions.
Thx
I've pulled off the interior door panels, unmounted the motors, cleaned and lubed the track, and made sure nothing was binding. I also tried bypassing the main switch and the individual door switch, as well as he anti-theft system, when I powered the motors directly from the battery. Didn't work. Sometimes, tapping directly on the motor or track will get the motor working again, but usually not. Then, hours or days later all is working perfectly.
My Avalon received the wind noise upgrade kit years ago that included new windshield side moldings, new door weather strips, new front window motors that closed the windows tighter, etc.
It is hard to believe that I have four bad window motors or four bad individual window switches. Even when a non driver door window is stuck shut I can hear the click in the door when the driver's door master switch for that window is pressed. That eliminates the master switch on the driver's door and other non-motor electrical components. My volt meter says the switches are okay too.
Please post what it takes to fix your reluctant window.
I also have had what I consider excessive wind noise from the front driver side window from Day One with this car. Fndlyfmrflyr, when did you get your wind noise upgrade kit, might it apply to 97 models also, and did you have to request it or were you contacted (i.e., a recall)? I've heard nothing about such a thing.
The wind noise fix was for 1995 and 1996 Avalons. New windshield moldings like those on the 1997 model were installed. New door weather stripping and new design rubber sound strips around the doors were installed. Insulation was added to the side mirrors and new front door power window motors were installed that closed the windows tighter.
There was no recall. Dealers would do the fix for customers that complained of wind noise around the front door mirrors and near the tops of the front door closed windows. The fix did not make a big difference. However, I stopped noticing the wind noise after the fix, so it must have done some good.
This may not give you alot of comfort, but way back in 2001/2002, I was at a similar dilemma. I did not want the package but wanted similar items in the package, but could not order "a la carte".
I wound up buying the XL instead of the XLS, and while frustrating getting the options that I wanted put on for 1.5 years, I have a car that I like very much, and is not available on the North American market. If you are handy and patient, you can outfit the lower priced model your way.
I did with upgraded PIAA bulbs, XM Delphi stereo, PIAA fog and driving lights, 2 sets, both separate relays, Tokico HP struts, Energy Suspension PU bushing changes, a manual compass believe it or not, a Canadian Bug/Stone deflector, I changed the horn cause I could not stand the little bitty horn they used (probably off all the other models), added the splash guards myself, Weathertech mats, etc.
You get the picture. It cost around the same as a XLS, about 4-5K and that is on the high side, maybe a little less. I forgot the trailer hitch and the wiring. And, for the XM question, the delphi antenna on mine looks like a little mouse. We ran it down the right rear window rain channel, then under the truck seal, and then under the truck plastic and inner fascia through the rest of the car under the interior panels. Took some doing but came out very good. Seal it up with chaulking.
abfisch
Developed a strange "squeak", not really a rattle, somewhere around the computer display panel (where the GPS option would go, but I don't have it). Not very loud, but I can hear it on almost every bump I hit. It's really annoying, especially for a car costing >$30k. Since the airbag equipment is behind the dash, I'm hesitant about taking the dash apart to try to locate it. Also, I can only hear it on a bump while driving, so it would be difficult to find standing still. I also have a '91 Cressida with >150k miles that's still has no squeaks or rattles, but that car was still made IN Japan. Any other owners have a similar noises in their Avalons.
MikeS.
I live in west/central Florida and recently bought an '05 Limited from the Sales Manager at the Toyota dealer in Ames, Iowa. He gave me a great price, with absolutely no port of entry add-ons, no dealer add-ons, no dealer prep charges, or any other "smoke and mirrors" charges. We dealt strictly from the true Factory Invoice. The dealer also delivered my car to Florida and picked up my '03 XL trade-in at no cost.(gave me $500 over KBB) He sends a truck from Ames to Florida every two weeks to pick up used Caddies and Lincolns for the Midwest market (big supply here, big market there). Painless, big money saving transaction.
Bakeroid
Now my issue. I'm not sure if it was always like this or this just happened. At night when I turn the headlights on, the backlights behind the defrost buttons and other buttons to the left of the radio do not turn on. Are there lights there that should turn on? Right now I can't see the defroster button at all at night and the other buttons around it. I am not sure if its always been like that or if something went out.
Has anyone else experienced this problem? If so, what were your solutions? How easy is it to remove that portion of the dash?
Thanks in advance!!!!
-TC
these are all backlighted. On mine they intermittently come on. what i do is tap gently on the middle between the buttons (not ON the buttons)and they come up.
The grill fitted very loosely and was also a possible source for rattling, so I applied some self-adhesive rubber weather-stripping from Home Depot to the underside circumference of the grill where it contacts the body when in place, and I used different retaining clips from Pep Boys to secure the grill firmly in place.
No more rattles!
Note that dry leaves trapped in this lower grill area, toward the hood, also cause a rattling sound which sounds like it is coming from the dash, so check there first!
Hope this helps.
