Toyota Avalon Steering Questions
Net
So now i have 2 things to take care of: Rack n Pinon to be repalced from my toyota dealer and the valve cover gaskets from my mechanic
Question: is it a good idea to have the fluid flushed while i'm getting new rack?
Net
Also, is there any way I can have my dealer charge less? (any tips on saving money at service?)
Net
One reason could be overinflated tires, a common and dangerous oversight when new cars are first delivered. This happened to me twice, with a 97 Camry and a 05 Avalon, tire pressures were way over spec. Setting correct pressure made a huge difference in handling.
Your 07 has built-in sensors so this should not be happening -- but I'd still suggest to check tire pressure manually.
Any thoughts on what could be causing this?
I used a syringe to extract most of the old power steering fluid and added new Dex III, as recommended by my Toyota manual. Someone told me that I should add some Lucas power steering fluid to stop any leaks (none visible) and make smooth steering. I purchased the Lucas, but I am hesitant to add it to the reservoir as it is not mentioned in my Toyota manual. If it is safe I will take some of the Dex III out and add Lucas to the fill line.
I appreciate any help with this problem.
Ydnic
http://answers.edmunds.com/ViewQuestion.aspx?questionId=11471&#answer11486
Please feel free to come back here and talk about your Avalon but go over there for responses to your specific power steering question. I think you have 3 answers already!
Visiting host
