I see from other comments here about HCH TSB 08-001. Anyone got a link where I can download/print it? We're going to put the nows back on now, which means in the Spring, we either sell the car or buy new tires; any suggestions?
JR
Good Luck.
I noted the uneven wear when having an oil change while the car was up on a lift. The dealer said there was a kit they needed to install p/n 04523-SNA-A01 which they accomplished for free along with the alignment. I think this was the upper control arms. However the two new Dunlop tires costs 111.00 each plus 50 labor so it cost me a total of 294.37.
Guess what, had the car on the lift last week at 22,000 miles for another oil change and rear tires are again worn on the inside surfaces and the car rides very noisy and vibrates like crazy above 75 mph. While on the lift we did some checking and the front edges of the rear tires are 5/8 inch wider across the front compared to the rear edges of the rear tires. i.e. the tires are towed outward 5/8 inch.
I wonder if Honda even can fix this problem which I think is caused by the extra rear end weight of the batteries. Put a load on the car and in the trunk and it just makes it worse. The rear end is not designed for the squat caused by this weight.
What do you guys think? Tom In north Fla
Edwin Geels
2008 Honda Civic Hybrid 16,000 miles and rear tire wear is unbearable. Car shakes and is loud. I bought my car with a salvage title due to a storm on a dealer lot, it had 3 miles on it and still had all the plastic on the outside and inside. There was nothing wrong with this car other than scratches and broken glass...with that said I bought the recomended kit in the TSB-08-001 since Honda would not cover mine under warranty. I can understand that since I have a salvage title but when I went to install them I discovered I already have the ones with a "C" marked on them. Are the ones with a "C" supposed to fix the issue? Did Honda just sell me the same ones I already have? I realize I have a salvage titled car but Honda has really shown their true colors when trying to get answers and or help with trying to solve this issue. Local dealerships played stupid..."never heard of such a problem" I only paid $15000 for my HCH so I can swallow a little extra to fix crap like this but I feel really bad for anyone who paid top dollar for their HCH and have to deal with Honda on this issue...this is one reason I don't buy new. Honda's have always been great cars for me but they really screwed up on this one : ( I am still waiting to get an answer from Honda customer service on this "C" marking to see if maybe I have a new batch that are different then what I already have...tic toc tic toc...and I wait. I will most likely buy some aftermarket adjustable arms so then I will not waste another set of tires. Pitiful!
The car was designed with hard-rubber tires (for better gas mileage) that wear terribly.
The car also had a service bulletin requiring exchance of a rear linkage in the suspension (you can Google the bulletin).
Honda and the dealer will likely give you the runaround (they did same to us) since they've heard it all before.
We (and apparently most other owners) have changed tires to minimize our problem. Suggest a low rolling resistence tire (see Tire Rack for data on selection). Expect gas mileage to suffer (approx, 5 mpg.) when you change tires.
By the way the OEM tires were/are (in my estimation) a safety hazard ! We discovered this once when we decelerated approaching a stoplight. The car skidded into the intersection (dry, clean pavement).
From my engineering point of view, Honda made trade-offs to optimize mpg. Unfortunately, you are noticing/experiencing the trade-offs at your cost !
Sara
I was wondering if anyone has any recent opinions on the best tires for an 06 hch.
I'm due for new tires again and wanted some opinions on wear vs. mpg vs. price.
I just read the majority of this discussion and was wondering if any of you had any new experiences to share about tires.
I have a constant loss of air in one tire. I have to put air in the tire sometimes several times a month, to every other month depending on "i have no idea what"
I have been advised that there are no holes in the tire.
Why would I be losing air in one tire?
It's like pulling teeth, asking questions getting them to do anything to pursue the issue.
is something like this covered under warranty?
I am being told if it is what they think it is...wouldnt be covered under warranty BUT I have been taking the car to the dealer since I bought it for this very reason. So i feel it was a pre-existing condition.
It HAS to be one of those, because there's not much of anything else that could go wrong. I really can't imagine anything associated with a "wear item" like a tire being covered under warranty. If you go to a reputable tire shop, they should be able to figure out fairly easily where the issue is.
No, this is not covered under warranty - and, pre-existing or not, that makes me think that your going to the car dealer is exactly the wrong thing to be doing. You should be going to a tire dealer. If they can't find the leak, they need to be in another business.
But you should be prepared to have to pay to get this fixed. It might be a simple puncture, but it could be that the wheels are leaking ($$$!)
