2006 Mag SRT8 (25,000 miles) same problem last Friday. No indication lights & stuck in park. Had to have Chrysler send a tow truck. The driver (independent tow company) says this problem happens often with Dodges. The trasmission lock module failed. He had to lift the rear of the car climb under to pull (a cable?) to release the car from park to nuetral. Luckily the car was not in the garage. By the way the wife's Honda and my company car (accord) have a key override to release to park.
The dealer confirmed and replaced the module luckily still under warranty. I thought I would own one Chrysler product that did not require towing.
While on highway car would rev but speed stuck at 90km an hour.This has happened twice.We are not sure what to do since it only happens to me.Wayne only has seen the problem with headlights shutting off and on.Hope to find a fix before spending to much money.Magnum lover.No answer yet :P
Thanks Dan
kcram - Pickups/Wagons Host
The transmission problem you are describing is EXACTLY what i had/have on my 2005 Magnum R/T (62,000 miles). First the high pitch noise started, took it to the dealer and they replaced the filter. Noise gone. One week later, the transmission started to slip and seconds later, all gears gone. I called a tow truck and they took it back to the dealership. This time, they explain this is known problem for this transmission, Chrysler directed them to flush the transmission, then replace the valve-body. They believe there is some debree stuck in one of the valves. This is as far we got today, the new valve-body is getting installed tomorrow.
Common for all these failures are they only occur when the transmission has reached normal operating temperature. When cold, it is all fine.
Hope some of this helps.
Dan
they told me it was made better this time.
p.s. if you need a picture fill free to contact.
