Audi allroad Brake Questions
willi61028
Member Posts: 1
You sound like a smart guy, so heres my problem: 1, My 2002 audi allroad quattro 2.7T's brakes are squeaking, so obviously I took it to the dealer to get it repaired. At the dealer they told me the following: "Due to environmental concerns, Audi, along with other auto manufacturers, has eliminated asbestos in their products. As a substitute, audi has adopted semi-metallic brake pads. Which generate squeak sounds normally." they say this is normal! is that so?
Now, however, my 2003 squeals less than 1% of the time -- and this is my first Audi in years that has not required brake pad and or rotor changes more frequently than oil changes.
Perhaps 2002 was the last year for the particular combination of pad, caliper and rotor to cause chronic squeal.
If you do not have other issues, such as frequent rotor replacement, judder and other confidence robbing characteristics, well, I would probably say: it goes with the territory.
I would submit this question here and on other Audi forums/town halls that are on the WWW. I think you will find that you are not unique or even very rare.
Sorry, I know that is not what you wanted to hear.
- Excessive black dust
- Noise (squeel or scrape)
- Poor stopping distance
He said you get can always solve two of three depending on the pads you choose, but not all three. If you want good stops and low dust, squeel is the one you live with.
According to the Audi dealer, the original rotors were warped. The first time they were replaced. The second and third times they were trued. After the warranty expired, I checked runout and exterior appearance. There were all within about .001" and looked fine. Nevertheless, the car suffered from nasty vibration/pulsation when braking normally from speeds over 65 mph. Sometimes the vibration/pulsation was violent. When I removed the rotors and inspected them carefully, the inside faces had small cracks. The machining of the rotors by the dealer did help in the short term, but probably shortened the life of these very-poor-excuses-for rotors over the longer term.
My recommendation with any rotor is not have it machined locally and only buy first class braking products. It's much too important to skimp on.
I'm confident that if you follow my advice, you will leave your brake problems behind and for a very long time.
That's my two cents!
Im wondering if you can help with part no'd for the Brembos, Zimmerman rotors and repco pads. Im looking to replace my 2002 Allroad pads/rotors as well.
just had suspension work (1 new bag, 1 new "module",2new tires, alignment) 5k....was a big nut, but was hoping that was "worst case scenario, done & finished"...had timing belt changed same time b/c/it was "time".. 48 hours and less than 20 miles after getting car back (+1 short highway trip) and check engine light came on, next time out of the driveway lots of engine rumble and voila! no brakes!
tech says ...brake vacuum hose that broke has nothing to do with the work that they did....does this sound right?
and to boot as the car got on the flatbed for the 2nd time in two weeks, I noticed trim underneath headlights broken on one side, missing on the other.....wasn't the case when I brought the car in..I've heard techs will sometimes take fr bumper off to get to engine??true??
Thanks,larry145
