Pontiac Grand Prix Transmission Problems
18911131417
  • 2007gxp2007gxp Posts: 6
    edited July 2011
    2007 GXP== Well car is still at the dealer , and I have been put into a rental for the repair time. spoke to the deal this week and he stated that the transmission needed so many parts that it was just 600.00 less then a new one. so they are ordering a new one from MI lansing sp? but it will take a while Did find out that GM has issued a service bulletin for the transmission on my year . The service bulletin is TSB , the service department person told me that GM now welds some of the parts together in the trans to make it stronger ??? When I get the final repair done I will be glad to list all work done . And will seek more info on the service bulletin TSB Any GM people on here got any info on that????? Please share ..... Think I will still car shop in the next year , sad cause I really like this car .
  • should I put my vin on here or whats your email?
  • I found a tranny online for $3100 and that includes them coming and getting my car with a lifetime waranty. All the others ive found localy only come with a 2 or 3 year wananty...I have a 2006 GXP
  • gmcustsvcgmcustsvc Posts: 4,246
    romierome79,
    My email is available in my profile. Just click on my name. I look forward to your response.
    Christina
    GM Customer Service
    the service repair bulletin # is 707030012 I believe need to do some searching
  • I have a 2001 Pontiac Grand Prix with 162k Miles. I've recently experienced an issue where while driving I push on the gas and the RPM gauge will push to 3k RPMs, however the vehicle will not increase to speeds higher than 35 miles per hour. The car had been stalling at low speed (around 15-20mph) occasionally over the past two weeks but today it would not increase speed over 35 mph. Since I bought the car I have had issues with loss of lighting on the radio, I don't assume that this is related but I figured that I'd mention it just in case. I suspect that it may be a problem with the catalytic converter. If anyone has any feedback on this issue I would appreciate your help.
  • I have a 2006 and mine is doing the same exact thing. i have taken it to the dealership and now I'm told that my 2nd and 3rd gear is gone which costs me $95.00 for them just to tell me that. I think it's a shame that when you get the warning signs in the beginning noone can give you an answer and then in the end you have to pay just to get an answer not including the work to be done. hopefully someone can help.
  • Hey everyone, I have an interesting situation with my Grand Prix. Yesterday, I jumped in and went to leave for the store, put the car in reverse, backed out the driveway, and when I put it into drive the problems started.
    In drive, it acted like it wasn't shifting at all, like trying to start out in third gear on a manual, even though this has an automatic transmission. RPM's went up, and it gradually picked up speed, then seemed to drive fine, until I had to stop. As well, the engine is running a bit rough.
    Next, I noticed that I had lost power to my windows, I checked the fuse box next to the glove compartment, the fuse was fine, and it had power. On top of this, my heater is also affected. I had it switched to defrost when whatever went wrong happened, and that is where it is stuck. I cannot switch it to any other setting, and I cannot turn the AC on at all, just heat. The rear defogger does not work anymore as well.
    Lights, blinkers, etc seem to be working well though. I have read through some of the posts on here, but haven't seen anything of this scope. I did notice a hot wiring smell the day before this happened, when I got home I tried to locate the problem, to no avail. Anyone have an idea of what could control all of this? Any help would be appreciated.
    marcelc,
    I apologize for the problems you are experiencing. Were you planning on having the vehicle diagnosed? P Lease keep me posted.
    Thank you,
    Caron, GM Customer Service
    n2everything,
    I apologize for the problems you are experiencing. I am checking in to see if the issue been taken care of.
    Thank you,
  • Hello I am in a real pickle here..lol I bought a 00 Pontiac Sunfire a couple months back for a real great price only to find out the clutch was bad and it went up very fast. When I bought it I would go to get into 1st and second gears and it would hesitate, stummble, sometimes stall.
    I would be stepping hard on the gas but the rpms would remain low until I actually got it into third gear then it would cost just fine no problems. I thought it was the clutch that was causing all the problems because a little over a month and the car would not move anymore.
    I just had a new clutch installed from a friend of mine who does great work and is a mechanic and I went to drive off and what do you know the car is moving again but the same thing. Lack of power it seems, stalls sometimes if I don't get the sync just right and you step on the gas hard you would think you would take off but low rpm's. The clutch also smells like it is burning.I am not sure what could be going on he said I may need to replace the flywheel. I do not want to go out and buy one if it is something else. I have been trying to find out more info on it but come up short. Any ideas?
  • Hi, I have a 2005 GXP that I took to the Dealer last year for the trans slipping. They could not repeat the condition at the time and told me to bring it back when it "got worse". Well it's a lot worse now to the point of the car not being driveble, which all happened in the matter of two days. My extended warranty expired a week ago. I have contacted GM regarding this and hopefully they will repair it, and I believe there is someone that saw a service bulletin for this very problem.
    Make / Models: Model/Build Years:
    CHEVROLET / IMPALA 2006-2007
    CHEVROLET / MONTE CARLO 2005-2007
    PONTIAC / GRAND PRIX 2005-2007
    Service Bulletin Number: 070730012
    NHTSA Item Number: 10021844
    Summary:
    4T65-E TRANSMISSION SLIPS, NO DRIVE/REVERSE, TCC SHUDDER, NOISE WITH TCC APPLIED. *KB UPDATED 08-15-07. *KB (DIAGNOSIS & REPLACE TRANSMISSION, IF NECESSARY). UPDATED 2/19/08. *NJ
    This is only ONE of the service bulletins regarding the transmission on these vehicles, there are others.
    GM is aware of this issue but isn't taking responsibility for it. I am personally not okay with that.
  • Make / Models: Model/Build Years:
    Summary:
  • Knock on wood, HARD! I have had to have my starter, alternator, water pump, Oil pressure sensor, 3 batteries, and replaced the tie rods 3 times and now my trans is gone! Oops almost forgot the oxygen sensors 6 months after I bought it! It is not normal for a transmission to have enough metal shavings in it to fill a measuring cup especially when it has been babied. You are very lucky indeed my friend.
  • Hi, my car's drive (D) and 3 shift not working but the rest is. transmition problem? how to fix?
  • mbgp97mbgp97 Posts: 1
    Last night when i got off work i filled up with gas and mine did the same thing i work at advance auto parts im going to try the filter and new fluid i will keep this post in mind and let you know what i find out or you can reply if you have a fix
  • Unfortunately if you are speaking to a 2005 to 2007 Grand Prix GXP, changing the filter and fluid are not going to do you any good. If your car is doing this your transmission is already gone. Sorry to be the barer of bad news.
  • I am looking into filing suit against GM for the transmission failures in 2005 - 2007 Pontiac Grand Prix GXP, Chevy Monte Carlo SS & Chevy Impala SS. Anyone interested in re-cooping the cost of having to either rebuild or replace the transmission in one of these vehicles, please contact me. would much rather make this a class action suit than a individual suit.
  • Check the tcc (transmission control circuit) it’s a fuse box under hood.
  • hi Malone we have the same problem with my grand prix too. did you fix the problem? please let me know thankz man
    grandprix24,
    I apologize for your frustrations. Have you spoke with your dealer of choice? If not, I would recommend starting there. Please keep me updated.
    Christina
    GM Customer Service
  • I have a 05 Grand Prix Basic model and I've experienced many problem i.e. engine harness, water pump, throttle body, tie rod, hub bearing etc.. On top of that I've had to maintain regular maintenance. Last winter I started noticing the trans slipping. Also, when the temp is below 50 degrees the car will not go in (D)rive; I have to put it in reverse first or wait until the car heats up. I would definitely be interested in re-cooping the cost of having the trans re-built, being that I will have to invest in that very soon.
  • I also have a 05 Grand Prix Basic model, and I am having transmission problems I was told that I have to have mine re-built pretty soon! It is going to cost me about 2,800 I am interested in what you are saying!
    lkcollins,
    I apologize for your frustrations. Have you spoke with GM Customer Assistance? Do you have this work done at a GM dealer? Please feel free to email me.
    Christina
    GM Customer Service
  • I have noticed at times it does not go into drive if I am moving backwards at all. I am talking less than 1 mph. I use tap shift for braking and it hesitates dropping in to first, from 25 mph. I have had the car for 14 months and it has about 97,000 miles. Has anyone notice this before a big problem?
  • I have a 2001 GP GT. I had the same problem.
    CHECK THE CATALYTIC CONVERTER. Mine was clogged and caused the engine and transmission to run rough, not shift well, not accelarate, all of the issues you are experiencing. Alot cheaper to replace a CAT than a tranny.
    tiretroll,
    If you think you are experiencing concerns I would recommend speaking with the dealer and having the car checked out. Please keep me updated on your situation.
    Christina
    GM Customer Service
  • My 2005 grand prix when changes from second two third it feels like is going over a bump. The dealer told me to wait until the whole thing goes bad and get a new transmission, and another mechanic told me I have a problem with one of my valves and maybe the cluctch, and the pump need replacing. I wish I would really know what is really the problem!
  • tiretroll,
    I had all the same problems that you are experiencing. The more I used the tap shift the worse the trans got.
  • I have a 2004 Pontatic Grand Prix and once in a while the REDUCE ENGINE light comes on, I lose power and can't accelerate pass 30 MPH. Everyone tells me its the catalytic converter - Please help or how can i check the problem.
Pontiac Grand Prix Transmission Problems - Page 11 — Car Forums at Edmunds.com
