Lincoln LS Brakes
I need to replace the brakes on my LS. Going to do it myself. I've read about a special tool that is necessary when working with the calipers on the LS. Does anyone have info on what this tool is?? Where I might get it?? Thanks
Also post this to the other LS bulletin board. More people look there. Good luck.
There is nothing free there, and much besides.
We've had 4 brake boosters put on and the problem that was originally described (rubbery creaking sound) persists.
Is that the problem that you had on your car? How did you convince them to change the master cylinder? I also have the Ford extended warranty, but the dealer insists that it's bad brake boosters (even after 4 new ones) and that the master cylinder is fine.
Someone please help.
Thanks, Shag2
I am in Charleston,SC by the way.
I've had my 00 v6 for 3 yrs and every once in a while I attempt to fix the brake squeaking I've changed pads, rotors, etc. and no luck! Does anyone know the solution I would appreciate any help or advice.
Not sure about the brake noise but I'd replace the pads first and make sure all the clips are in place on the new ones - and check all the components for anything that's loose. The front sway bar bushings are prone to wear out but that's more of a clunk than a rattle.
any help will be greatly accepted imn at my wits end
Assuming the rotors just need to be resurfaced, how much do you guys think I'll be paying for an inspection and brake pad replacement? How about pads and new rotors?
How much do you guys think would be the price to have it done at the Lincoln dealership?
Going to a dealer potentially will be expensive. Most dealerships charge at least $60/hr. for labor, as well as charging FULL LIST for parts. So, for instance, if you indeed need new rotors, you'll probably pay over $100 each, I would imagine, and pads would also be marked up accordingly.
All you have to do is remove the wheel, remove the caliper (2 bolts IIRC) and hang it off to the side with wire (don't let it hang by the brake hose), then remove the caliper support. This is the only tricky part - it's 2 bolts but they're big and can be hard to break loose initially. Use a long ratchet with an extension handle or pipe to get leverage. Pull off the rotor and put on the new one and reverse the procedure. Piece of cake.
When I push in the pistons on the calipers is there any special procedure as a result of ABS. i.e, idle the vehicle, etc.
Any special procedures as a result of the rear Electronic Parking Brake.
Also do you know of a good maintenance/repair manual for this vehicle? I couldn't find anything in the Chilton/Haynes line and the Helm is high priced at $140.
Thanks for your help.
