Dodge-Plymouth Neon Starting/Stalling
I've had a 96 Dodge Neon for a couple of years now, a problem that started last year and I've been fighting with is it keeps stalling and sputtering. I've replaced the O2 sensor, plugs and wires, fuel pump, altenater, just about everything I can think of. I replaced the O2 sensor because the first time it did this the engine light came on and the only thing that came up was the o2. But when it did it again soon after that, I started changing things, I'm starting to wonder if it is the relay to the fuel pump, because that is what it almost seems like is that it is starving itself for fuel. I was wondering if it could also be the coil pack? Really need to get this problem fixed before I have more invested in fixing this problem than I do in the entire car.
Farout
Today, I was parked, and turned on my air conditioning, and it stalled completely. Can someone please tell me what is wrong with my car? I'm tired of these dealers lying to me to make money.
so far this year i have put 18"chrome rims with 215/35/18 on
lambo doors and i have full air ride on this car and a octane body kit.
this car is now 11 years old nad the own before never changed anything. so guess what.
i've bin changing this ever t month in this car.
but im having trouble with it stalling.
ive changed the plugs
wire. coil twice
2 new battery
3 fuel filtters. and still trouble
even time i slow down or stop at light my car will be fine until i push down on the gas. and theres nothing, no move ment no noise nothing. i have to tap it over and over again nad then slowly theres like a burp nad it slowly starts to move nad then the power kicks in.
and if it stalls i have to tap the gas pedal when turning it over....does anyone have an idea... i have it up on blocks right now so i can drain the gas out, and then in the morning im going to get a new fuel pump and hope to good it fixes it...
the only weird thing is the check engine light comes on and the codes tell me that its a throtle senor issues and a multpil cylinder miss fire.
and a injector miss fire...
so that changes things from what i thought but still they all need gas to fire so hopefully im right .... if anyone has an idea please let me know thanks steve.
if i start the car with out the filter pluged in nad gas should pure out it will for a bit then nothing. nad then the pump makes a howling sound and then starts up for a second nad then quites again.. so i have order a pump just waitting for it to come in nad try that if not im going to try what ur saying..... can anyone tell my how hard it is to change the timing belt on neon.
Cleaned my battery connections so you can eat off them.
Tightened battery connections.
Tested 12v across the battery. Tested 12v across the starter. So I have power okay?
Noises when starting
I can hear the fly wheel and the starter clicking. I can also hear something else clicking... Like a relay/fuse near the driver side dash... But Im just thinking thats the starter relay engaging...
Now originally all that was wrong was a bad starter... So whats up? Need anymore diagnosis on the situation to help me? Just ask and I'll go check... Ive been without a car for over 6 months and I just want a car again
98' Plymouth Neon SOHC 2-Door Red... It doesn't work
link title
:mad:
Also on a side note I put in a new battery about 5 months ago.
so next day i go to bring the car into the shop and when i got it started again it seemed to run fine but now when i hit about 20 mph it has a surge almost like a hard shift and then runes fine again doesn't do anything when slowing down the mechanic hooked up and found codes p0122, p0340, p0351, p0352d, p0422, cleard them out and the check engin light went off it has not cam back on yet but still have the surge at 20 mph and ideas were to starte looking they couldn't tell me with out charging and arm an a leg to replace the the seners the the computer said were bad Thx in advance
Sorry to have taken so long to reply. Also sorry I can be of no help. Gave up on the car and traded it in. Figured the car dealer could handle it better than me. Wish I had better news, I kind of liked that car and really wanted to keep it but the problem was driving me nuts. Hope you have better luck.
Scott
lionfish37@hotmail.com
Scott
I have the same problem with a 97 2.0 DOHC. It will run gr8 for 2 or 3 days then boom. I've been working on this car for 2 months now. When it stalls, if you don't turn the key off but try to start it, you get no rpm,cam or crank sensor readings on a Snap-on scan tool, no spark and no injector signal. but if you turn the key off (for 5 min.) it will start and run gr8, till it stalls again that is. I've changed the cam and crank sensors, egr valve, pcm (reprogramed it) asd relay, battery terminals, pulled and cleaned all fuses inside and out,and cleaned the throttle bore. I've checked the tps, map, repaired the crankshaft sensor wiring under the exhaust, and cleaned the contacts at the pcm. I'm running out of ideas. If anyone has run into this problem I'd like to hear about it. Fuel psi and ignition are fine. There are no TSBs on Mitchell's on demand about this problem.I'm hoping it's something stupid that I'm overlooking. If you didn't figure it out yet, I do run a small independent repair garage and yes this one has me stumped. sorry this was so long.
