Check this thread starting at post #21 for the details.
Do some cells usually need to be replaced at this age?
Do you know of a shop within 800 miles or so of NC that rebuilds batt pack?
chris
He had the car since new. He is a retired engineer and you could not find someone who treats their insight better. She is like a goddess to him.
And he drives very mildly and follows all recs to the letter.
He had to replace his battery at 80K and again
at 119K, then again at 125K! Thankfully all under warranty and by the dealer
via Honda.
It has 130K on it now.
My question is why did it last only 39k the time before last and only 6K the last one? Honda doesnt really know. Maybe a defective battery the last time,
but the time before at 39K is low too. Is there something that could be wrong on the system thats eating up batteries? Honda said no.
It also helped that even though this car was not purchased new it was originally sold by this dealer and I have had them do all the regular maintenance. I also reminded them that this is the 4th or 5th Honda I have purchased from them over the years and I don't deal with their competitor down the street because of service and warranty issues.
10 years 150,000 miles.
Now can someone tell me where to buy a thumb throttle kit so I can start hyper-miling.
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Yes, but the jury is still out on whether it is a good thing to do or not. It wears out the cells, but the benefit of having them balanced may outweigh this.
Battery packs that are experiencing problems will definitely see an improvement, and for them, it is a no-brainer, but good batteries may be harmed by frequent charging.
>Routine maintenance on a lead acid battery is to loosen the caps and overcharge the unit, replenish the electrolyte, and reconnect it to the system. Can the same be done with NiMH batteries without blowing them up or having them catch fire?
No, these are sealed cells. The only maintenance that can be done is to charge them fully. You'll find plans to build your own trickle charger over on Insightcentral.net Search for "grid-charger". The parts will cost you about $100 and can be assembled in less than an hour.
The battery can be recondition; see "99mpg.com". I had the same problem of short battery capacity for years. Presently my 2000 Insight with 200,000 miles is performing well. It took eight discharge-charge cycles of the battery to bring it back to life. If you were not so far away, I would be willing to lend you the charger.
dclarke3
Living in Netherlands,owning an Insight from 2009. Reading this stuff about the battery pack is rather interesting. I just want to share my experience with a degraded crank battery. It triggered CAN-Bus errors and stopped the enigine. It was dead and could not be started anymore. After a while the battery was just enough "recovered" to get it started again. But after the shop guessed the cause I remembered that this thing was happening with lights on and could be temporarily solved by swithcing off lights and other electrical appliances as much as possible. Almost 5 years now this was the only problem(although a design flaw by not signalling low crank battery but only some weird CAN-Bus error). Insights will not be much different here in NL than in USA.
