Dodge Charger Transmission Problems
I've been VERY interested in getting a Charger or Magnum, but now I'm spooked. I have a friend who works in the auto industry (technical information) as well as one who's an engineer at Consumer Reports who are both pretty set against them.
It all comes down to transmission issues. This would seem to be confirmed after digging around on chargerforums.com it seems like a huge percentage or people have experienced the trans. leak and needed new gaskets etc.
This does not give me a good feeling about long term durability. That said, those same guys all seem to LOVE their cars.
I'm spooked. Thoughts?
My last car was A '02Intrepid SXT with the same 4 speed that the 300 owners are complaining about.I can tell you that the 5 speed is lot better than the 4speed.I have just
over 1000 miles and so far its been great.I think another problem is it takes time the the computer to get to know your driving habits.Once its complete it should shift better,that what I found with mine.Also being a retired mechanic,I had to reprogram the computers(trans) with a test drive giving it all driving conditions.You have to do this once power is lost.I also think the '06 have the bugs out from the '05 trannys.which were the trial transmission.Thats to bad for the ones with the problems,but thats what they count on to improve the product.I hope this helps.
http://tinyurl.com/b9hnr
In the US, there are NO civilian 4spd Chargers. The 2.7/spd combo is limited to just fleet units. You can get the 2.7/4spd. in the Magnum though.
The Hemi and the 3.5 both get the same 5spd auto, and it IS having issues.
Coming from a string of ultra-reliable Japanese cars, I'd hate toe buy my first American car in a decade and have major issues.
I'm not trying to bash the car, I'm just concerned.
bulletin for leaking transmission.Only thing on the tranny is a shudder from torque converter,but I think these are early production cars.I'M a retired Mechanic and can pick up a problem right away.So far I see no problem and say its one of the smoothest transmissions I ever had.I think the gasket leaks could have been bad gaskets.If it was serious ,I think they would put out A bulletin.
Great ride though...
I found it frustrating at first because with it being a brand new car I didn't want to take it to the dealer.
The manual states that when the car is new it learns the shift points and when cold you need to pause for a few seconds when shifting from park to drive.
What exactly do you mean by klunking? When (cold?) and at what speed and hard acceleration?
If I owned this car - it would be back at the dealership.
Have you floored it while driving at 30-40 mph?
I remember test driving before I bought and the 3.5L isn't that great at highway speeds when you floor it.
The acceleration and smoothness is best when flooring it from a stop. It makes some nice sounds too.
shake.
I have a little less than 1000 miles so once I hit 1000 I will try it more often. What I felt was probably the transmission downshifting hard.
Once the rpms go down to 650 I can tell the transmission will shift a lot smoother.
Thanks for the heads up on the service bulletin. I will be sure to pass it along. They no mention of this at the dealer.
I have an '06, 3.5LHO with 45K on it.
Had the O ring changed at 18K (I bought it at 16K).
Went to the dealership Saturday for an oil change and was recommended to have the throttle body cleaned, which I did. Driving away from the dealer, I had that old familiar hesitation and skip in the trannym followed by the usual service engine light coming on. This has happened in the past, with the light clearing up after a drive cycle and Dodge saying that there is nothing wrong. Started 'er up this morning (14 degrees in NYC), felt the familiar sluggishness of the very cold tranny... but she had a new trick for me today... would not get out of 2nd or 3rd gear and th eautostick wouldn't work. Couldn;t drive any faster than 50, with the engine revving to high.... so I took her back home and will drop her off at the dealership tonight for hopefully a fix under the extended warranty.
For the record... after taking the car back home, I fired up my '99 V6 Mustang with 202K miles on it (original tranny and engine-it's literally a high speed sherman tank) and blasted off to work. If this tranny issue with Dodge isn'e rectified... it may very well be my last Dodge... ever.
Larry Jackson
Hewitt,Tx
This is the GERMAN tranny.
Like so many of you, I too am starting to notice this shimmy in the tranny. I can't believe they never put a dipstick in these trannies. My issue: my tranny lines run right next to the power steering pulley (as yours do) which eventually wore them out because they were so close. I was cooking down the highway doing 70 when it happened. I saw nothing but smoke. I pulled over, had it towed only to have the dealership tell me they need to get the part ordered. 2 weeks later and 3 attempts they tell me that they can't get the part. So now I'm stuck with a car payment and an immobile car. Being a backyard mechanic, I am very tempted to say the hell with it and fix it with a rubber hose replacement.
So my warning to all check the lines that run up the driver's side to the transmisson cooler in front of the radiator to make sure they are far enough away from the pulley so you aren't stuck without a ride like myself. Does anyone know who actually manufactured these lines so I can order them direct?
:mad:
It seems that everytime a Chrysler product has a tranny problem, then everyone says they are all bad. I have had 6 Dodge products and never had tranny problem.
I bought this car on 9-11-07 and from then until now the car has been in the shop 115 days." A HUNDRED AND FIFTEEN DAYS." I tried the Lemon Law way. But that did not work. My only recourse is to get me an attorney and sue their [non-permissible content removed].
Can't really think of any reason not to buy a Charger anymore then any other car. What people buy should be their own choice if they like it or just want it. Good luck on your decision.
