Mazda5 Warning Lights & Problem Codes
Is it normal for the Security Indicator Light to flash when the key is taken out of the ignition and continue to flash until the car is started again. My car has only 300 miles on it and today was the first time this has happened.
Is everyone this is happening to getting thier Leak Detection Pump replaced??? as Markii of Dec 02, 2005 did? I was hoping I could just take it to a AutoZone and have them hook up the code reader and reset it...?
Any other thoughts on this???
Thanks!!!
a) If you have 2 or more sets of keys and all, except one, work, the faulty key might not be recognized anymore. Either the key has to be reprogrammed or you may need to cut and reprogram a new key. You need 2 good keys to reprogram a 3rd one (this is for security reasons, i.e. valet parking)...
b) If none of the set of keys works, the car immobilizer system has issues. In this case you will need to take it with a dealer to check it out.
The battery is low. When the battery is low all needles in the instrument cluster will pulsate, i.e. go up and down.
It happened to my CX-7. Just needed a jump.
My Mazda (3) started flipping out with lights flashing and horn beeping.
Apparently, the car immobilized and went into lock out mode.
Nothing worked - the remote starter, turning the key, using the spare, etc.
I Googled pages of threads without any clue except taking it to the dealer.
But, I fixed it!
All I did was jump start the car. That's it.
I put the key to "On" so, I could put it into Neutral.
Then, I pushed it next to my other vehicle.
Then hooked up jumper cables for a minute or two and it started right up!
I think the whole security thing is triggered by a battery that is a little low.
I hope this helps.
1. Turn the interior lights off w/ the door ajar after 10 minutes instead of 30 min?
2. Unlock all the doors and tailgate w/ one push of the unlock button instead of two?
3. The time required for the doors to relock automatically after unlocking with the
transmitter to 60 secs instead of 30 secs?
Bubba
I would suggest maybe the factory shop manual might discuss it, but I won't buy one of those either because I did get one for my 2006 MZ5, and it seems to be written in some form of Klingon instead of English -- e.g. the plastic engine cover is called the "plug hole plate cover".
Is this behavior considered totally normal? Or is my car's thermostat not quite cutting out the radiator as much as it should?
The dealer in Austin said they would condecend to do it for $156.00. Buster says this is way too much. We'll live w/ it the way it is. :mad:
Thanks... B
