Some vehicles will have an over-ride of this firmware if the driver uses the brakes even ever so lightly.
Ford has a US patent, likely used on their FWD hybrids, that reduces the level of regenerative braking as the OAT declines toward freezing due to the rising probably of loss of directional control should the roadbed be slippery.
Rusty
almost off... but it is holding tight on the left side, and for the life of me, I can't find anything else to remove to kick it loose. Chilton had the most accurate steps and about the only drawings, and everything is off and the steering column is dropped onto a landscape tie on the seat. I'm thinking that with everything known off, it may be that the left stud bolt into about the middle of the dash frame has a shoulder that is exactly the size of the dash frame hole, and the frame was effectively swaged onto the shoulder as if somebody drove it there with a hollow tool and a hammer.
am I right or wrong, and is there something else that Chilton doesn't know about I need to yank yet? for the life of me, I can't see anything else that attaches to the left.
SOP....
First introduced within the US circa '80's on asian made cars that used the (soundly IDIOTIC) NipponDenso climate control system design. Not much later one of the major US suppliers of these designs was aquired and became Denso US so now we have this idiotic design in many US cars.
If you want HEAT to the windshield, say for the episodes of sudden windshield fogging these systems are prone to, the only method I know of is QUICKLY turn up the temperature setpoint to MAXIMUM HEATING and the switch the mode to defrost/demist/defog.
I modified the climate control module in my '92 Lexus LS400 and those of a few friends, such that when I activate the defrost/defog/demist mode the interior cabin temperature sensor suddenly indicates a VERY COLD cabin.
Must remember that...
Scott
second, if the multifunction switch (turn/dim/wipers/world_peace) is starting to get funky and junky, it may fail to make contact with the wires for one of those bulbs, resulting in fast (or no) blinking. the wife's Taurus is doing that. you may get relief by getting a can of electronic contact cleaner and shooting a blast into the blinker stalk off the multifunction switch, then operating it a few times. that would be a temporary fix.
one silly thing I had on my car... replaced a MF switch because it wasn't dimming... and then the headlights quit. for jollies, I cleaned it up well with contact cleaner and put it in the box and held on to it. loaned the car to a relative for a weekend, and they broke the new one. put the old one back in, and three years later, not an issue, working fine. that's in the $250 neighborhood. live and learn.
On Panthers you can often clean them by spraying a bunch of electrical cleaner down the hazard light switch while working the stalk.
1954 N 190 E
Orem, UT 84057
Do not resaturn contacts.. Does this mean resolder?
Just wondering, so I understand what you mean so I don't try the wrong approach.
My 2006 crown vic police interceptor won't switch back from heat no matter what I do and the check engine light is always on, the engine light was first and the error code later, which I forgot, indicates a slow leak in the system (not fuel leak) somewhere, the heat always on problem just happened, after I had the heat on for the first time this year.
https://www.ebay.com/itm/Easy-Fix-Blend-Door-Actuator-repair-1993-2011-Crown-Victoria-Grand-Marquis-kit/253244442681?hash=item3af68b8839:g:aXUAAOSwQcJZ~5Dp&vxp=mtr
