Oldsmobile Intrigue Heating and Cooling
dirkwork
Member Posts: 210
in Oldsmobile
Ok, after crowing about how much I liked my new 2000 GLS, it has developed a problem with the A/C. When I select AUTO and turn the temp to cool, it blows air on high speed but the temp does not cool and the compressor and cooling fans I have confirmed do not come on. Before this sudden problem, the AC seemed to work well.
We have confirmed that power does go to the relay for the AC, but its not making it to the compressor clutch to engage.
I noticed in the docs I got with the car that it had the controller replaced under warranty once before. I am hoping its not that. Also wondering about a sudden loss of coolant, maybe that would also have the same effect like if the evap coil rusted out.
Any hints from anyone?
Dirk
Dirk
We're not equipped to go much further, will have a dealer evaluate the issue. BTW, this car is basically like a small Cadilliac Seville STS, so my dad's shop manuals apply the 3.5 GLS more often than not. The 3.8 is probably more like other cars.
Dirk
Put a gauge on the AC suction pressure port. If the pressure is very low, then the pressure switch will not allow the compressor clutch to engage. If the pressure is near zero, go buy a couple of cans of 134a and put them in. Some cars (not sure about the Intrigue) have PCMs that lock out the compressor if low pressure switch cycles X times. You may have to pull the PCM fuse or disconnect the battery briefly. If this works, then the previous owner topped off the refigerant to get it through the sale. You then need to look for a leak.
I could have saved some money by following your advice, if the AC compressor is not running, chances are there is no gas in the system and the computer has shut it down. I had the dealer fix and it was a bit over $100 but it runs fine now. Couldn't find leak, it was not perceptible, but I'm guessing the evap core. they also put dye in, so we'll run it and see what happens. good for now.
Dirk
Took it in this week for a new compressor, dryer, hoses, and orifice tube. Now it's nice and quiet and cold again. An expensive repair, but I'm not too mad about it since the car has been paid off for nearly 4 years and I haven't had to repair much outside of the warranty.
Next up will probably be replacement of the loose front hubs and maybe new struts all the way around. At 82K miles the suspension is wearing out, I think.
Oh yea, don't know if I got taken or not but the condensor cost $800 for everything, and they had to change the radiator fluid while removing the radiator.
Other than that, the car has been great. Even the wife who snubbed her nose at the "grandma car" has gone out of her way to drive it :~)
Dirk
I have a 99 Intrigue and have several problems with it. Mainly, the AC only blows cold on the passenger side. The driver's side is either warm or the same as the air outside. The temp. readout on the display NEVER reads correctly. It could be 85 degrees and it will read as 67 degrees. Has anyone else had this problem? I have tried playing with all the knobs...especially the one that selects a colder/hotter temp for each side.
Any ideas on this would be greatly appreciated.
regarding the main problem, does your Intrique have an air filter for the cabin and have you ever changed it? When I changed mine it was filthy, filthy. It was seriously cutting down on the air flow when A/C fan was on high. Probably not the cause of your problem but worth knowing about. I suspect that the cause of you problem is an air diverter plate is not working, maybe a vacuum line is bad. Never had that problem so can't be more specific. Run an internet search for other ideas. You are not the first one this has happen to but I can't remember the fix.
Someone on page 26 said that adding freon got rid of the problem on his car. I may give that a try tomorrow and let you know. Please post any success you have. I hate taking it to the dealer--something else always goes wrong afterwards.
When the rain quits and i drive a while the temp slowly creeps back to 50 F and the AC will come back on as if something or some sensor is drying off. I am totally stumped to the problem and any help would be greatly appreciated. Thanx
It's under the front bump on the passenger side. It's the only thing connected to a wire so its not hard to find. disconnect from electrical switch then turn the plastic nut then pull it out part number should be 10248414.
It list for about $10. Verify part number with dealer and buy it first. That will make it easier to find it if you are looking at the new part.
For $10 and 10 minutes of your time to replace, it's worth a try.
Let us know how it goes. Good Luck!
It's just to the passenger side of the license plate. It faces the outside of the radiator. You can get to it without lifting the car. Good luck and let us know how it goes.
-PacMan34
Some days when I start the car, the climate control works fine. Other times, it wil be completely shut off (no lights, no air, no heat, nothin'.) Other times, there will be no lights, but warm air will be coming from the blowers.
I'm hoping that this is just some kind of loose wiring problem, that can easily and cheaply be fixed, as I'm a bit cash-strapped right now. Has this happened to any other Intrigue owners and if so, any idea as to the culprit? (Other than the car being possessed?)
Engine Coolant Temp Sensor Circuit High Input ,
but don't know where the sensor is or thermostat? can u help?
Not sure about the temp sensor but think it is on the back head drivers side.
Good Luck!
:sick:
"Some days when I start the car, the climate control works fine. Other times, it wil be completely shut off (no lights, no air, no heat, nothin'.)"
I'll pretty much ditto that. Anyone have any ideas? Most of the time it works, but sometimes (probably about half the time) it doesn't turn on at all. After driving for a little bit, the whole unit, lights, air, and everything else will kick on. Like I say, not an every time issue, but often enough to be annoying. Any help would be greatly apreciated, and feel free to write me at AMCurnes@hotmail.com if you don't feel like posting here. Thanks!
The drivers side heated seat is not working. When I press the switch the orange light comes on for about 4 seconds then goes out. It does the same for HI or LOW temperature settings.
As I was told, air conditioning needs to be charged. Would this affect the heat output? The car has climate control as opposed to traditionally separate buttons for AC and Heat. Warm air was coming out but not warm enough for my ankles.
The recycle air button keeps switching off and the outside air button switches on. Is this some sort of default? I haven't read the manual yet .
I bought the car this afternoon. I will be registering it tomorrow. I plan to have the oil and filter changed tomorrow. Any suggestions on what else I should do for it on my first full day of ownership?
The AC needing freon should not affect the heat. With the auto climate control, it will not blow out hot air until the car warms up. On cold days, it could take a several minutes to feel warm air. Also the climate control system depends on the outside temperature sensor. In other words, you simply set the temperature you want it and the car dictates where the air is comes from (defrost, below, vents, etc.) based on the outside temperature. This may explain why the recirculate button keeps switching off. Is the outside temperature sensor working properly? If not, it is extremely easy to replace.
Along with the oil and filter, i would also get the coolant changed since it is over 5 years old. I would also change the transmission fluid.
What is the best way to run the power and gound to the amp?
Has any one else experienced this?
Chad
any ideas are welcome,
thanks,
Zoli
Any recommendations?
thanks,
jeff
You might try disconnecting the negative cable on the battery to reset it. (This is how to get rid of a ServEngSoon light-on as well.) If it does not reset to normal, you need to replace a part. Sorry, that's all i can supply on this one. (Our family has two 'trigues and my brother's family also have two. We like these cars. We are tall and the have the most front-seat leg room of any car I would want to drive.
