Lexus LS 400/LS 430 Starting Problems
Please help!
I tried posting this problem on the "electrical problems" board, but since there's been no action lately on that board and with the new set up, I really didn't quite know where to post this. I have been having a problem with my 2002 LS. It does not start sometimes after sitting in the garage overnight. There have been times when after waiting for a half an hour or so after the initial try, I will try it again and it will start. Other times, I have gotten a jump and it will start. Has anyone had a similar problem? Can anyone give me any ideas of what might be the cause?
cn
cn
My first thought was maybe your battery is flat. A 2002 Lexus battery may be at the end of the road.
Good luck to you
Jens
I appreciate your response.
cn
Thanks to all.
cn
If not output, then you have some device on the car draining the battery overnight, like a radio that stays on constantly, or light somewhere. IF anything is hot in the car, that's your problem.....
My mechanic has checked for what I'm told is called "parasitic drains", as you mentioned. The Lexus dealer and my independent mechanic both agree that if the problem is not happening when they check the car out it's very difficult to diagnose. This is very difficult, because, even if I had the car towed, it still might start, once it reaches the mechanic. However both also agree that if I hear a clicking sound outside of the car, which is very hard to do, by the way, when you're alone, that it could probably be the starter. In spite of knowing very little myself about the mechanics of a car, I too also thought that it could possiblly be the altenator or the starter. Since I was able to finally have someone else present when the car wouldn't start, so that they could attempt to start the car, I did hear a clicking sound while standing outside the car. I'm taking it to the mechanic today and hopefully this will be the end of this episode. I will keep you all informed, in case this experiece might help someone else in the future, as you have all helped me and many others with your knowledge and experiences. Sorry for the lenghty post.
And again, thanks to all.
cn
So are the early Lexus 400's ok in the snow?
Thanks, driveRight in NH.
Welcome to CarSpace! Let me know if I can help you find anything, or with anything at all. You can get my email address by clicking on my name. Have fun!
1991? OR WOULD SOMEONE SUGGEST ITS' WORTH TAKING IT
IN AND PAYING DEALER TO INSTALL? DESPERATE IN LA PUENTE
CA HOPE TO HEAR FROM SOMEONE SOON. THANKS FUR NEE
Clicking sound not "click", as in a single click?
Clicking (continuous for as long as the key is held in the start position) is usually the result, A) low battery charge, poor connections from the positive battery post to the starter solenoid or the "ground" return from the starter to the negative battery post, or, C) an internal problem within the battery.
Piece of cake..
TO HEAR. THANKS WWEST,IF YOU HAVE ANY TIPS IT WOULD BE
MUCH APPRECIATED. PEACE OUT...FURNEE
Thanks again and Happy Holidays to all.
cn
Are you kidding? You have to move the Power Steering pump first, don't you? It's certainly doable, but I wouldn't put it in the POC category.... :surprise:
Lexus LS: Problems & Solutions
and do a search. Lots of postings in that forum regards starter problems.
cn
do you know of any website that might have a a step by step illustration of how to install the alternator. desperate in la california. furnee
Was it the interlock failure or the removal of the Lexus Link that corrected the problem? Please let me know as soon as possible.
Brich
Not sure how much this will help, still not sure why I had this problem. All I can tell you is that after having the Lexus Link disabled per Lexus and also I stopped setting my alarm at night(it's garage kept, but I just had this habit), I no longer have the problem. I have not tried setting the alarm just to see if I would still have this issue, after having the Lexus Link disabled. I just haven't had the time to mess around with the chance of it not starting. I do plan to do this at some point. It may have nothing to do with either situation, I just can't be sure. Of course I'm just happy not to have the problem.
cn
I bought this 1998 LS last year with 105K miles on it. Everything looks great, except there are couple of times it wouldn't start. Most of time it happened on raining days or very cold days. But after couple of hours, it can start without jump cable.
I heard a clicking sound when it had problems. I asked a guy in auto parts store. He told me that it should not be alternator or start motor problem. He think the electrical connection on alternator or start motor is loose since my battery is brand new and connection on battery looks very good.
I asked my lexus dealer, they want me to replace start motor, which cost about $1000. I really don't trust them. When I bought this car, they asked me to replace brake pad and rotors for $750, but my mechanics told me the rotors are almost new.
So if you have any experience on this model, please help me to make a right decision. I don't depend on this car so I try to find the best way even if it take some time.
Allen
The clicking sound is most likely the starter solenoid picking up the starter load and then quickly dropping out, repeating rapidly, since the battery (or cables/connections) cannot sustain the load.
Were it me I would first remove the battery terminals, clean and burnish the connections and the posts, reconnect and then try if for a time. Also check to be sure the heavy duty wire from the negative side of the battery is well grounded/connected to the engine. The cable from the positive side of the battery connected to the starter solenoid is nice and tight as is the cable from the other side of the solenoid to the starter itself.
If the problem repeats replace the battery.
It is not unusual for a battery to be intermittent due to metallic debris piling up in the bottom and sometimes temperarily shorting out a cell or two.
I have 2003 LS 430 that I just bought. My navigation al system is outdated. I went and bought the DVD Navigation Map that just came out. I bought off a guy who had a GS. The DVD is in perfect condition and my screen keeps saying that it cannot read the DVD. Someone let me know what to do. The guy promised me it would work. If need be I can bust his face up for lying. But, I think there might be something wrong with my DVD player but it plays the older version just fine what should I do. Also can that DVD player play regular DVD's?
GILLIGAN1
I spent a lot of $ having the starter replaced. What else is there? A few days after having my starter replaced, I turned the key to start the car and while the car started, it took a few seconds for the engine to turn over. Before I started having these issues (months ago) all I had to do was turn the key and the car would instantly start. Now, it always seems to take a second or two from when I turn the key to have the engine turn over.
Any suggestions or hints would be greatly appreciated. I've tried everything and I really like the car and don't feel like getting rid of it.
My LS400 98 has 162K now, no any other problems. It is the most economical car I've ever had, yet most luxury, powerful and comfortable.
Any other thoughts - besides that really expensive option - new starter?
If NO, then you still have a cable or possibly a fusible link problem
If the lights DO go on, you could have a bad starter, starter relay (solenoid), ignition switch, or perhaps another fusible link to the starter relay.
If you had a test light you could test for voltage from the igntion switch to the starter relay--probably requires a lift to do this.
A new starter motor is nothing more than an expensive guess at this time.
Any suggestions will be appreciated.
Dandydon
The problem was exactly as you suggested, I had inadvertently pushed the lockout button. Didn't even realize there was such a button there.
Thanks to all for your suggestions.
Dandydon
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Remember, being a genius is a thankless task -- and yes you can quote me.
