Jaguar XJ-Series Fuel System Questions
FUEL/GAS LEAKAGE. Had 2500 miles on NEW jag, when strong gasoline odor came from our garage. There was gasoline leaking onto floor. called jag roadside service, who refused to pick up car until fire dept said it was ok. Fire dept arrived, and rolled car out of garage onto driveway, where gasoline poured out. Fire chief refused to have tow truck come, until they cleaned tray under tank that was filled with gasoline. This was done, and towed to dealer. Dealer replaced fuel seals which they say failed, but could not guarantee it would not happen again. Jag corporate would not tell me I was safe. Two weeks later, same thing happened and car was towed again. This time I waited 18 days until they put in new gas tank, without any guarantee this would happen again. DANGEROUS PROBLEM, AND I AM PETRIFIED TO DRIVE CAR. MY FIVE CAR PASSENGER AUTOMOBILE HAS BECOME ONE PASSAGE DRIVER, BECAUSE NO ONE WILL DRIVE IN IT. ANYONE ELSE WITH SAME PROBLEM. By the way, this happens when gas tank is filled.
After fixing my transmission, air con and timing chain, do you know of any other major problems you've had go wrong?
Good luck - let us know how it goes.
However, if no one shows up soon, try posting in our Answers section over there on the right sidebar.
Good luck - hope we can help one way or the other!
Cylinders numbered from front. As it is viewed from rear of vehicle (driver's seat), "A" is right bank and "B" is left bank.
Fuel filter Located in trunk behind spare tire.
Your symptoms suggest you could have dropped a cylinder, either a bad plug or wire or an internal issue. With this V-12, you wouldn't necessary notice a missing cylinder at idle but you would when you accelerate.
In any event be prepared for a bit of a racket at highway speeds.
NEED ADVICE!
Dennis
Dennis
Dennis
Dennis
YOUR ADVICE!
used Haynes Manual for Jaguar on Amazon
You may be getting fuel to the fuel manifold, but not past the injectors, if the computer is off-base (or shot).
Gene37
what is the answer
On the 1999 XJ8 sedan the Fuel Filter is located along the frame rail, next to the fuel tank, and near the driver side rear wheel.
On the 2002 XJ8, same place.
A 'no start' condition can be caused by many things--it would be a long list. First thing you can do is have the car scanned for trouble codes---sometimes chain stores like autozone or OReilly will do this for you for free.
Also, here's a CHECKLIST of things you or your mechanic can look at:
http://www.samarins.com/diagnose/
