Caravan/Voyager Electrical Issues
167891012»
  • does anyone know if i can split the fuse box on a 2000 dodge caravan engine fuse box, the metal flange that the positive and negative cables are connected to are loose but i cant tighten the bolts (if any) on the connection unless i can separate the box,,,, any one have any ideas a new one cost 400+ ouch>
  • Hi:
    Happened to us - change the speed sensor
  • I just had the exact same thing happen to me today. I just pounded the dash cover really hard and everything came back on. Smacked the dash above the ABS and it went out. The engine service soon light wouldn't work.
    Not very scientific or mechanical but the price was right
  • Thumping the dash will begin to lose effectiveness. Depending on temperature, vibration and even humidity, the problem will progressively get worse and the symptoms will start to vary... Do NOT trust 'any' major shop to attempt a fix, they'll try replacing everything from the onboard computer to the kitchen sink w/out success! The only solid fix is to remove the speedo cluster, strip it down and resolder the fractured solder joints on the socket which connects to the harness which you have to remove in order to get the cluster out. The entire repair process takes a competent novice about 2 hours to complete. I have pictures of the process but have no idea on how to post them to this site......
  • I bought a 1997 Grand Voyager with 133,000 miles on it last week. Everything has been fine until today. Get in the van to go pick up grandson from school and the a/c fan won't blow! I live in Texas so it's hot!! So I think, "well I'll just have to roll the windows down until we can look at that". The electric windows won't operate! Tried turning the van off and restarting it twice, to no avail. BTW - the radio wasn't working at this time either. Twenty minutes later I make it to the school thinking I'm gonna die of heat stroke. When I turn off the van I can hear the a/c fan blow for a split second. Start the van back up and everything is working properly. Obviously this is some type of electrical issue, but where do I start to try to figure out what's wrong?
  • pmarypmary Posts: 14
    On my 2001 Caravan with the same symptoms I replaced the PCM ( Power Control Module) to correct the problem. I believe on the 97 model it is called the ECM (Electronic Control Module) mounted in the engine compartment on the fire wall or on top of the D/S wheel house. You mite luck in for a used one at a local auto wrecker for $ 20. Good Luck.
  • I tried cleaning the blue plug because there was green corrosion visible on the wires. Have had the power lock problem, would pull the IOD fuse, worked great for a while until I had to start pulling the fuse daily. The instrument panel has freaked out a few times, but started working again right away. Most recently the car wouldn't start or charge, which forced my hand into looking for a problem. I took the wires out of the connector, cleaned them up as best I could with scotch brite and sandpaper and a couple of tiny screwdrivers. I applied conductive grease (hope this doesn't cause me more problems), wiped down the wires and put them back in the connector. My car was able to take a jump, and started up fine. The instrument panel freaked out once, but that has been the only problem since. So thanks for the advice on cleaning the connector. Only thing now is I've seen you talk about replacing the IPM and the PCM, and seen others talk about touching up the soder on the speedometer cluster, and I'm wondering if I should get out now before my van gets possessed. Guess I'll have to keep an eye on it.
  • the wiper switch on my 1996 grand voyager has quit working. The wipers will work when I push in the switch to activate the wash fluid. I have checked the wiper motor fuse and it looks OK. What can I look at for this problem?
  • I just bought this van, it has 188 k mi on it, drives and feels good but it's registration says it is a plymouth voyager while the vehicle has dodge caravan all over it. Carfax identifies it as a voyager also. Whats the deal here?
    Also, When I bought the vehicle a couple days ago, the dash guages worked but now none of them do. The lights, wipers, dash lights, radio and all still work. I checked the fuses under the dash and they are all working and functional. Any ideas or suggestions? Sort of frustrating. :confuse: :confuse: :confuse: :confuse: :confuse: ">link title
  • johnbeckjohnbeck Posts: 12
    edited April 2013
    Check this site for other posts on 1998 Dodge Grand Caravan electrical problems & you should find previous answers to this problem and other related intermittent dashboard electrical problems. Its caused by fractured solder joints on the connector spikes which the wiring harness plugs onto which is mounted under the dash board display cluster.
    Pictures on disassembly/repair procedure:
    http://www.flickr.com/photos/landar/show/with/3474557830.
  • lon37lon37 Posts: 3
    push the button to reset the trip mileage and hold it in for several seconds, The do the same for the actual vehicle mileage.....It my reset the gauges...Lon
    My 2003 dodge grand caravan sport has not electrical power. The battery check good. Nothing in the car works. Any suggestions.....Lon
  • i had this same problem so bad my van would just shutoff while I was driving and all it was was my groud wire to the battery corroded
  • arjona7arjona7 Posts: 1
    So I have 2000 Plymoth GV and the check engine light is on, we've taken it to the mechanic and its in top shape but I decided to check the computer with the little scanner machine n it reads a code of P0001, I look it up and it says that there is no info on it, just that it is a Fuel Volume regulator control circuit/ open, any help please????
  • driving along, at random times of the day, I hear the alarm beep and see the speedometer needle bounce from the speed I am driving to zero and back again, repeatedly. also, the dash lights (mileage, time, etc.) flicker, and the 4 brake systems warning lights pop on, usually the "esp bas" light and the pic of the rear end of the car with the curvy lines stay on. when I park and turn off the ignition the lights go off and the problem goes away, sometimes for the rest of the day and sometimes to reappear a little later. my mechanic wants to see this for himself but this is not possible as I am a delivery person. could it be a soldering issue behind the dash, or maybe the ecm module?
    While I'm not familiar with that exact combination of symptoms, you're probably correct.. Car manufacturer's switched to lead free solder back in the 90s. The net result, especially with Dodge is a multitude of problems all relating to micro fracturing in solder connections, especially on the dash display module. It also appears that many of these symptoms are caused by the fracture being in a common ground line which then of course affects multiple associated functions.
    DON'T let anyone sell you on any modules before you've had someone experienced with these symptoms actually see them...
    When the symptoms occur (while pulled over of course), take a video of these symptoms while gently (at first) banging on the dash above and around the speedometer array until the problem disappears.
    At least that way you can confirm the symptoms for the mechanic.
    The rest will come down to his experience and the damn car being cooperative...
    You'll get zero help from Dodge! Good Luck.
  • cscarlett1121cscarlett1121 Posts: 3
    edited September 2013
    Put new battery in my1996 Plymouth Voyager. Now it wont pass smog. Do I need to reprogram. And does anyone know how that's done?
  • It probably didn't pass because while the battery was out of the car the memory was wiped out due to lack of power to it. You should just have to drive it around for about an hour to trigger all the system monitors to insue they are working properly and are ok. The system runs a bunch of tests on the vehicle under various condition like speed, wide open throttle etc. during that time and when it completes the tests the system is reset. It is easiest if you check the system with a scan tool after driving it for awhile, and the scanner should tell you the monitors are "OK". Once this happens the car should pass the smog test with no problem.
  • Thank you Sir. I'll do these steps and hopefully its nothing else. When the man gave it to me he said he replaced 3 sensors, he said everything ran right but couldn't pass smog. Here I go on a hour long drive. Thanks.
  • Ok sorry but regroup. the smog man said that the previous owner put in new computer and when he tested it 3 sensors went off he said 1 too many So is my best bet to put it on a scanner? I mean does it sound fixable?
  • So this car has about 175k on it. It was running great up until about 4 months ago. It sat for a couple weeks, then I went to start it and at first, it started once, ran for 3 seconds then quit. Then I'd try and start it again and it wouldn't even engage the starter. I left it alone for another month... went back... and the battery was dead.
    So today, about 4 months from the first issue, I slow charged the battery overnight, got in the van, it turned over, ran for 3 seconds and quit. Now won't engage starter again. Both times, all of the other electrical works in the car... radio, lights etc... just won't start.
    Help!
  • Many years & models of Dodge vehicles experience this. It's been determined that it's either hairline fracture joints on the central connector pin group (which connects the cluster to the car through the only wire harness connected to it) on the circuit board on the back of the instrument cluster which have to be resoldered or corrosion on several of the connector sockets and matching connector terminals underneath the power distribution block next to the battery OR a combination of both (my references are from a '98 Dodge Grand Caravan so you'll have to account for any physical differences between mine and yours). Search on this site OR on the internet for repair procedures.
    Repairing these problems is not all that difficult if you're handy with a soldering iron and aren't afraid to get your hands dirty putting in a maximum of about 3 hours work for both fixes...
    Do NOT let anyone rip you off by attempting to change any of the associated major control modules - they are NOT the problem!
  • I'm not sure of the transmission that is in it. I've been trying to find out. I believe it is 3-speed. The past couple months I've noticed while on hwy, where usually would kick in overdrive between 50-55mph. It hasn't been, I can hear how loud the engine sounds. and yesterday my speedometer just stopped working for about 24 hours. It started working again last night. Wondering if it is a sensor problem, maybe a vacuum, hose. ???
  • Quick question. Im pretty sure I kno but I have a 96 plymouth voyager it turns off while driving lights flicker just before. It cranks back up for now. But have to keep gas petal slightly tapped when slowing down.
  • Hello. I purchased a '98 Dodge Grand Caravan a couple of months ago and when I did the environmental controls did not function at all, aside from the blower working if you turn it to the highest speed. Shortly after getting it the front drivers turn signal stopped working with a fast flash, which replacing the bulb did not fix.
    After trying the environmental system reset procedure (no lights at all) and reviewing a number of sites and reading many posts here, I'm thinking both issues might be related to the BCM and wanted to take it out to check the solder and possibly replace it with a junkyard module.
    However, I can't seem to get the thing out! I dismounted it from the brackets, removed the screws on the right side, and don't see any screws at all on the left side. I've tried pulling as firmly as I feel is safe without breaking it, but I can't get it loose. Is there a trick to this? Or am I missing something on the left side of it? Or am I on the wrong path with the BCM to begin with? Thanks for the help!
  • RE: removal of the BCM – That got me too! There are two screws on the left side which you appear to have removed. The third screw is oriented vertically on the left side of the fuse block at the top and is difficult to see. Once that’s removed and you have disconnected the two lower big connectors at the bottom, you’ll be able to wiggle the fuse block/BCM asys downwards and outwards slightly… You then slide the BCM downwards until it comes free.
    RE: replacement of the BCM – Replacing the BCM is a turkey shoot and may or may not address your particular problems. If you really must replace it, be VERY careful that you matchup the part number to the replacement part. The BCM stores not only your odometer reading but also your vehicle VIN numbers AND the features your van are equipped with… Getting a superior version with more features may allow the features you do have to work while a BCM from a vehicle with less features than yours will prevent your advanced features from being accessed. You may also end up with a lot more miles on your odometer than you had and if you don't have access to a diagnostic reader, you won't be able to change it.. for that matter, I haven't been able to determine just how much data in the BCM can be altered manually...
    Before swapping the BCM, take the circuit board out of the case and inspect the upper leads which make connection at the top of the fuse block (I think it’s pink). Look for white corrosion creeping along between the pins going through the connector at right angles and clean with 99% isopropyl alcohol if present. Also, there’s a notice of an intermittent 300 Ohm surface mount resistor on the underside of the circuit board. It’s marked 301 and apparently it’s the only one… Carefully remove that resistor and solder a 1/8th watt axial resistor in its place.
    This may or may not address ‘your’ issues but it is definitely an issue with these BCMs.
    RE: Turn signal issues: On the same fuse block which is attached to the BCM, about midway up is an elongated black relay which is about 3xs as wide as the regular relays… This is the DLR control relay which control the various turn signal/flasher functions.
    Unplug it from the fuse block and carefully spread the case where the lock tabs are around the bottom of the relay and lift the black cover off. Inside you’ll find 5 relays - inspect the solder joints going to the connector blades of the relay which plug into the fuse block, they’ll be hairline fractures around the base… Just resolder all the connectors using 60/40 Kester solder and problem solved..
    NOTE: since all the modules communicate via the CCD bus, you may also have a problem with your instrument cluster solder joints even though you may not have the symptoms – yet -.. We’ve posted plenty on that damned gremlin here at Edmund’s and you’ll find further info on it… Since you’re going to have part of the dash apart anyway, go the extra mile to remove the instrument cluster and resolder those dozen or so pins on the back of the instrument cluster whose solder is also fractured…
    They made a big mistake going to lead free solder. It’s basically responsible for most of these problems because the rocket scientist in the damned government didn’t understand that reduced lead and increased tin meant greater rigidity. Combine that with a vehicle which rattles teeth loose and you’re going to get fractured solder joints as has proven to be the case with most brands of cars….
    Good luck !!
  • Wow! Awesome info! It sounds like I need to avoid a replacement BCM unless I have no choice. I looked at some pictures of the BCM online and saw where it looked like another screw might go, but I was thinking it would be on the bottom, not the top! That will help a ton :)
    I think you're right and I should just pull the whole thing apart and fix all of these various issues. After trying to get the BCM out the dash displays did stop working, but when I tried to get it out again shortly before posting here the dash came back on; it sounds like it's just a matter of time before it goes for good, though.
    I was wondering if you had any ideas on the heat/AC/rear wipers/defrost sections. I did pull it out and the white in the middle of the panel seem to have some burn/scorch marks along the top on one pin, but otherwise seemed OK. I don't know if this indicated the environmental panel needs replacing, or the cable, or if there is some test I can do to find out. Any ideas? Thanks again for all of the great info!
  • mweiandmweiand Posts: 3
    I'd like to follow up to my last post half a year ago, as I have additional issues, and have taken a number of actions from the forums, but I'm still stumped.
    I did replace the Environmental Panel from the junk yard, which fixed some of the issues. It now passes one test, but fails the AC test, which I assume is because the AC has issues. I still haven't figured out the turn signal because the instrument cluster stopped working, like so many others have. I went through all of the posts and tried most of what I could find:
    I recently went to a junkyard and pulled an instrument cluster and BCM from a matching van year/model, but after installing and testing each, I was still unable to get any gauges to work. I also tried replacing the 300 ohm resistor on the original BCM, which didn't do anything.
    I've re-flowed the solder on the instrument cluster and BCM for the connectors. I've done the IOD fuse trick. I've checked that the cable under the steering column is securely attached to the frame. I've replaced the battery with a new one.
    I recently cleaned the pins on the male and female side of the instrument cluster connectors. After doing this the needles seemed to ping slightly like they were trying to work, just twitching at the bottom of the gauges, but I'll be trying the clean them again to see if that was the issue. I didn't see how I could bend the female side to make the connection closer, so if anyone can provide additional information, that would be great.
    The van is great aside from not being able to see how fast I'm going, or how much fuel I have. When I turn the key the mileage does show up, along with the reading next to it, but once I turn the key further to start the van the mileage and other reading disappear. I'm also open to any other ideas on what I can try with this thing as I feel like I'm running out of options!
    I've probably taken the BCM out about 10 times at this point, and the instrument cluster 4 times, so I'm getting good at that, at least! Thanks again for the information, it has been helpful for troubleshooting.
167891012»
Caravan/Voyager Electrical Issues - Page 12 — Car Forums at Edmunds.com
