I compared Edmunds TCO data for a 2002 TLC. With a cost basis of 41K, they determine that it will cost 67 cents per mile for the next five years. An '02 X5 with a basis of 34K will cost 66 cents per mile. An '03 Nav with a basis of 37K will cost 64 cents per mile and an '03 Denali will cost 37K to get into and 65 cents a mile for five years.
But wait, there's more: an '02 Sequoia will cost 36K to get into and run 63 cents per mile.
I'm surprised that the '02 TLC with its minimal depreciation and with the first two year's depreication already taken, would cost so much per mile.
I didn't do as well with a 7 year old 1997 TLC as depreciation was 4.6332% per year
Since the truck is still like new with 146k, I would like to fix it, but the dealer wants $330 for the lower half only. It seams like a crazie price for a cover that is cloth with vinyl sides.
Any links or suggestion are appreciated.
Another thought - forget a dealer and just go to a regular seat upholster, it HAS to be cheaper than $330 for just a seat bottom.
Or, check out this website:
http://www.rufftuff.com/toyota_landcruiser.asp
Or: http://www.greatcovers.net/shop/categories.asp?category_id=4271&a- mp;a- mp;a- mp;a- mp;make=4019&model=4717
Or, get Ricaro seats which fit the Fj80 according to an Australian owner "A used Recaro is better than a new aftermarket
seat- better built, quality materials make the difference":
http://www.2002parts.com/html/recaro_front_seats.html
I would like to keep it original if possible. Are there any discount OEM suppliers on the web?
I also need center hub covers and the plastic side bumbers.
On a side note, my oxigen sensor came off the exhaust pipe along with the mounting base... rusted off I guess. Anyway, they want 1,300 each for the two exhaust pipes that come off the manifolds and end with cad. converter... ouch! I need to find a welder or some other solution.
Not complaining about reliabilty since I have put under 1,000 in parts for 10 years.
I just returned from the So. cal. mountains and the new tires (revo's) did great in the fresh 8" that fell last night. Went out first thing in the morning before it was plowed and I went all over without a problem, what a blast.
Bryan
Since I don't know your zip code here is a link.
What size Revo's did you put on your LC? Except for the vibration problem, which also goes away above 75 mph, they have done really well. They look awesome also.
For OEM parts, I use Toyotaparts.com. They seem to have good prices and reasonable turn-around.
Good luck!
O and any one with some steering know how on a 94 TLC, I have recently noticed alot of play in my steering wheel, more than is recomened how can I fix this?! I know that theres a simple way but I cant remember.
Bryan
Bryan
A search of this thread yields but a few instances of problems with these sensors. Is that really the case? We wonder how that can be since one dealer is selling so many.
Does anyone have any comments? And does anyone have any suggestions as to how to hold Toyota's feet to the fire? Thanks.
scott@mobi-arc.com
Will this be an easy project?
Toyota has really missed the boat on this item. I guess someone will have to be really hurt or killed because of the TPS issue before Toyota will do something.
fj100
About a month ago I had another throttle problem, different part, it was $280 installed. This problem occurred on start up, the truck did not want to start, then would start, the revs would go up real quick and then it would cut off so I started it and floored it, it kept running, the check engine light came on and I took it straight to the dealership.
I love my LC and would not drive anything else however I am having alot more unexpected repairs on the 100 series than I ever had on the 80 series.
You will be fine on the cross country trip. I would leave tomorrow in mine and drive anywhere in the USA.
fj100
Failure # 2 - This happened on start up and the check engine light came on.
fj100
The second time was when I nearly ran out of gas. I suppose I was nearly running on vapors. Both times I assumed it was a computer function to protect the engine. Both of these scenarios, were obviously preventable by me.
Where is the throttle position sensor, and how can I tell if mine's been replaced? I could not find it listed in the index of my manuals either.
Oldman- I haven't noticed that problem with mine. I only get some bearing noise when the engine is first started and cold.
All failures occurred during the winter months under wet slushy snow conditions.
In all cases, shutting down and restarting the engine immediately restored normal operation.
Here's my understanding. The ECU uses the TPS signal to monitor for proper operation of the Engine (e.g. If the throttle is depressed this far, the Engine RPM for this gear should be this much, etc). If the as found conditions are not within a specific range, the Engine Trouble light comes on to prompt the operator of the abnormal condition (potential engine problems).
When the TPS signal is lost (temporary interruption) during operation, the software of the ECU is programmed to take the throttle to idle position (what it thinks is a safe condition). When the loss is temporary, shutting down and restarting the engine resets the ECU and restores normal operation.
Here's my thoughts. I don't like the idea that the engine defaults to an idle condition, but I'm not sure what would be better.
I believe the moisture intrusion problems of the TPS could and should be addressed. The sensor needs to be moved or better designed for the environment that it operates in.
I currently accept the failure because I don't want to spend the $300 it costs to replace the sensor. Frankly, I suspect the replacement sensors are prone to the same failure mechanism.
Do I fear taking trips with the vehicle? Absolutely not.
My 98 has 115,000 miles and runs virtually the same as the day I purchased it 5 years ago. I have no intentions to get rid of it now or anytime in the near future. It is still one of the finest products available.
My 99 has none of the symptoms, so far but good to understand what may be coming my way.
Bryan
Your experience seems exceptionally dangerous. This issue needs to be raised with some of the big wigs at Toyota, in case they don't already know about it. Has anyone who has experienced this problem written to Toyota Corporate? If not, perhaps a letter should be written (with a copy to the NHTSA), with support for a recall coming from the various people on this board who have had similar experiences.
Thanks to the posters, that info may come in handy if mine goes haywire! So far my 99 has been bulletproof. I agree with the fellow who said he had no intention of selling it after 115k miles. That's just broken in for a LC. My partner has 200k and just recently had the drive belts and one idle pulley replaced, the only stuff fixed aside from the usual items like brakes, tires, oil.
The towing brake controller connector is about a foot above the accelerator pedal area behind the right side of the driver's knee crush panel. It is very well concealed, but can be easily seen if you remove the horizontal heat duct at the bottom of that panel. No need to remove the panel.
A hex head screw at the left end of the duct must be removed using pliers from the side. You can't get a regular nut driver tool in there without removing the panel. With the screw out it's just a matter of jostling the duct out of the two end fittings. Then look straight up for a white 5-pin connector with nothing plugged into it.
Toyota does not supply a mating connector and cable for the LC, but they do for the Tundra. The Tundra part number (82132-0C010) is correct for the LC. I had to convince the dealer of that fact before he would get one for me since it is not listed in their database for the LC. I talked them into giving me one from a Tundra on the lot and re-ordering a replacement.
The cable/connector set is not a complete ready-to-use-assembly. Rather it comes with free wire ends which you must wire to the brake controller connector cable wire ends. Toyota includes a sheet with the assembly showing the functional connections. You have to use that along with the brake controller wiring instructions to make up the final cable.
For a Prodigy controller:
Black-Red goes to Prodigy pin A
Green-White goes to Prodigy pin B
Brown goes to Prodigy pin C
Red goes to Prodigy pin D
Green is not used.
I chose to remove and uncrimp the contacts in the Prodigy connector and solder the LC cable wires directly to those pins. But you can also just splice the two cable sets using Prodigy supplied crimp splices.
From the factory service manuals that I bought when I got my 03 LC, here's some additional info.
As most of you know, the LC throttle control is a fly by wire system - no mechanical connection between the accelerator pedal and throttle butterfly valve. Both of these assemblies communicate with the ECU and the ECU actually controls the throttle valve.
Each of these units has two Hall effect (magnetic) sensors, one for the actual signal and one for validating the other's data. These are non contact sensors - no electrical wiping action to wear or get dirty. By this means, the ECU knows both the accelerator pedal position and the throttle valve position and has redundancy checks on both of them. The throttle valve position is set by a motor which is controlled by the ECU.
So the ECU decides on actual throttle position based not only on driver input but also on all of the other inputs it has access to (RPM, road speed, temperature, etc).
The failure mode described (default to idle speed only) could arise for a couple of reasons.
Specifically described in the FSM is a failed redundancy check where the two sensors in either the pedal control or the throttle assembly disagree with each other. That sets a trouble code and triggers the idle only condition.
A second reason for the failure (not described specifically in the FSM) could be that an ECU requested change in the throttle position did not take place (sticking throttle valve). Here the idle speed default sounds like a particularly good idea to prevent an unintended acceleration situation, provided that the throttle motor can overcome the sticking condition.
When I was looking at LC's last summer, one dealer indicated that there was a recall on all Toyota V8's for just that problem - sticking throttle valve. But I have never seen it confirmed anywhere. I suspect that at least internally at Toyota there is some kind of contingency planning or "secret" recall agenda should this kind of problem become widespread.
His choice of our vehicle is the ultimate acknowledgement of the world-class nature of this magnificent vehicle.
Another question for LC: Is there wisdom in repacking the front wheel bearings? At what interval? The maint. guide from Toyota does not make this clear. Some say drive it until it fails because the bearings are a sealed unit.
