I was hoping to remove it, but didn't know if anyone has experience with the 2006 model, and whether that screws anything up to take it off. Apparently there are some wires (for the center rear light) in the spoiler...
Do you think a body shop could do a good job of taking that off? What about a Toyota service center? Would they do that?
If you don't mind me asking, why would you want it off? It does a very good job of keeping the spray/dust/grime off the rear window.
Ken
Thanks for your reply. I like the classic look of the TLC without the RX300 or Sequoia-looking spoiler.
In terms of the spoiler, do you know that it is 4 bolts + 1 wiring for the 2006 model year? I was told it was different from the '04 or '05 model spoilers. How would I add back a rear center brake light, since the '06 apparently is on the spoiler itself? Thanks for your thoughts.
Ken
Sorta new here - go easy on me, lol. Anyway, I really like the older styling LC's and may be looking to unload my Jeep Cherokee (ugh) for a used LC. Im probably looking for something in the year range of 1996-1999 I think - can't really afford to spend more than 10K max.
I know I'll be looking at something with over 100K miles on it, but for a Toyota thats really not a major concern - I was just wondering if you LC experts can help me what to look for, what to avoid, etc, maintenance costs, etc. Thanks!
I have the 2002 Toyota Landcruiser with the 2001 dvd, I upgraded to the 2004 dvd. Now my neighborhood and lots of other streets show up for Houston.
I purchased the dvd from Toyota for $250, but I think you can get it for half that on ebay from someone selling lexus nav dvd's.
Update, could this be water trapped in the wall between the passenger and engine compartments? The grill area near the base of the window wipers might be blocked and water going in the wrong direction?
I was told that the sunroof drains through the rocker panels but I am still unsure how I ended up with this problem. And how do the rocker panels drain if water makes it inside? I cant find any drain outlets.
I have read through the previous posts about a major upgrade coming soon and would like to put her off until the new model is available to compare with the RR - based upon what is known now - any idea how the new TLC will match up against a RR? Will it look like a larger 4Runner? Thanks in advance
Bullethead
Visit an RR discussion board. Or you might like to know about the 80 some new RRs rec'd at the processing center that all had water in the transmissions instead of transmission fluid, or the huge # of them that can't keep a charge on the battery. (Good old RR electrical systems) RR is consistently at the bottom of JD Powers customer satisfaction ratings. (But they are sexy looking)
Better yet, just send me the money you're planning on using to buy that RR
Thats why I bought an Fj80 over the RR when I got my first LC.......
Thats true - when the RR is actually on the road. :sick:
Ken
may be torque convertor shudder;
usually that occurs under light load, like going up a
slight hill under light pedal pressure; or even
on a level road under light pedal;
and I mean very light pedal pressure.
It will go away with heavy pedal pressure,
that is until it fails entirely.
I would put the tranny shifter in drive and leave it there
during your driving and testing.
You could try dropping the pan, changing/cleaning the filter screen,
and then using the Toyota approved tranny fluid.
Sometimes, if you are really lucky, it is just a bad
torque convertor solenoid; but you would have to find
a very very good mechanic, who was also very very honest
to diagnose that properly, and not try to sell you a new unit;
only happens once a year on Christmas Eve.
Look for bits of metal on the dip stick also under
bright sunlight; this is usually a tell tale sign that
the tranny is being eaten up somewhere.
You could also pay $100 to have the tranny flushed;
but I would still drop the pan and clean it out first.
good luck
g
usually they will have a package price for all the gear boxes
both diffs and transfer case.
I would recommend shopping around for a shop that will let
use your fluid, that is, if they do not carry Mobil 1
synthetic GEAR OIL; you could go to any of the parts stores
and buy your own.
Also, find LUBEGUARD additive for gear boxes;
Napa usually carries the line; not cheap, but if you change
everything to synthetic, and add lubeguard, you will not
have to do it again for at least a few years.
You can drain, or suck out, the fluid from your powering steering unit;
Buy a suction gun at the auto parts store; like Napa;
and just suck it out a little at a time, replacing it with
new fluid, run it a minute, and repeat 4-6 times. Done.
I would recommend having the tranny flushed; but make sure they
fill the flush machine with enough fluid to completely flush your old
fluid out; that should be around 14-16 quarts;
I got smarter after I learned the local Toyota dealers were only
using 6 quarts!
The LC has a big tranny.
The fuel injection cleaning for $55 is only a can of stuff they put in your tank;
the dealer uses a high pressure can they attach directly to the fuel rail
does a better job.
Toyota's use a special long life radiator fluid;
I would only have a dealer do that service
Bottomline;
I would go to the Toyota dealer for everything;
OR, do it myself.
g
The 97 uses a real timing chain, not a belt, that does not need changing;
ever.
So it is odd that he changed it; must have been something wrong with
the engine.
13K is a lot of work; like a complete engine rebuild.
Does depend on the deal you are getting.
Only problems I have had has been a vibration that no one can
figure out, and a loud whistling noise from the exhaust;
sound like a jet engine when I accelerate.
When you have to replace the front rotors on the 97, it is a big
and expensive job; about 8 hours labor, plus parts.
On the 98, you do have to replace the timing belt at 80,000 miles;
and it costs around 1200, as they replace the water pump at the same time.
But then, as it has an independant front suspension,
the rotors are easy to replace.
Whichever way you go; use synthetics.
I use gear oil (Mobil 1),
synthetic engine oil(Mobil 1 extended life)
and a K&N air filter; and get much better pick-up
and around 17mpg in the 97.
g
do to the cost of gas;
you should be paying $5000 LESS than sticker.
g
are you sure you don;t have them already?
g
pour a small amount of colored water into the
grill in front of the windshield,
and see if it dribbles out on the ground.
There should be a clean out port on the firewall for that area.
If you part under a tree that drops a lot of junk
on the car, the drain hole could get plugged.
The doors and the floor also have drain holes;
get under the car and look for them near the edges
there are also rubber plugs on the inside of the rocker panels.
A Toyota dealer should be able to help
g
If so, run very very fast (from the RR)
The LC is 10 times the vehicle..
good luck
g
g
I'd stick with factory recommended plugs and wires.
HTH
Engine Oil - A slippery subject Part 2
and
Synthetic motor oil
I'm looking to buy a used Landcruiser year 1999 or 2000 or a Sequoia year 2001 or 2002. Aside from the Sequoia being newer, are there any other pros' / con's to looking at purchasing one of these two vehicles?
bradesp
