Has anyone else ever seen/had this problem?? I checked the radio fuse and it appears to be fine, but have not had a chance to check any other fuses.
2015 Subaru Outback Limited 2.5
3L8Z-14B205-AA (w/Keyless Entry) $355.02
YL8Z-14B205-EA (w/o Keyless Entry) $318.76
This is a plug and go module so there is no need for dealer to program. This module should be in the engine bay area around the Fuse Box area and it will be a square module with a couple connectors coming out the side.
Good Luck!
Thanks again!
Cheers
The 2nd fitting is on a smaller tube, and runs from the condensor into the firewall (can't see where it terminates), and sticks up vertically.
I'm assuming that the first fitting above is the low side. Is that correct?
Thanks in advance for your help.
I have a 2005 Escape XLT with the 3.0
was still in warranty. Dealer had it towed to the shop, replaced all coils and plugs and PCM..had lass than 10k on it when it happened.
:confuse:
Has anyone else had a leak or coolant problem and what caused it? Please let me know. :sick:
http://codes.rennacs.com/ABS-Brakes/Japanese-Korean/Mazda-ABS.php
http://codes.rennacs.com/plugins/MazdaABS/MAZDA-ABS-10-626.php
You jumper the pins, turn the ignition on, the ABS light will flash with the error codes, there should be a list of codes on the internet or through ALLDATA which you can access via the local library for free.
Where is "Ford build tough" if one can only drive trouble free for 15000 miles?
Incidentally I mentioned a couple of interior design glitches to Ford when I bought the car - indicator panel (outside temp, compass and time) on top of scuttle is unreadable in daylight, lid on center console stowage has sharp corners on which one can bang elbows very easily - should be rounded off: no response from company on what are admittedly minor points but do detract from ones driving experience.
Ford Part# XR1Z-9D475-BA or Motorcraft #CX-2071
List price $86.89
Online Repair Manuals
