Saturn VUE Rust
I couldnt believe my eyes!! We did have a hard winter in indiana, but rust all ready? talk about disappointed. Any way, the rust is coming up around the chrome piece that sits above the license plate on the tail gate door. I would really like to know if anyone else is seeing this issue.
I also have put two sets of brakes on this vehicle, the first ones the dealer ship covered the next two sets came out of my own pocket. I think it was all from a bad rotor that came from the factory. In addition to these two problems there is some type of squeaky noise that started in the front passenger side and now is on both sides.
I feel like I made a bad choice when I bought this brand new vehicle. :sick:
The rotors on these have been known to be troublesome - don't get them resurfaced - when you get new brakes again have the rotors replaced, usually gets rid of the problem. I'd recommend not getting it done at the dealer as they will just put on another set of GM rotors - do some research on the web - there are lots of good brands to choose from. NAPA sellls pretty good ones...
Rust above chrome trim...
I've read that there are sometimes issues in this are of the Vue with "rail dust" - basically what happened is that during transport from the factory (by train) dust from the railroad rails flies up and sticks to the paint...the metal dust then rusts looking like rust on the panel - they even have a procedure for removing it...I can't see your Vue so I can't tell if that's it but I've read of it in just that area...a good body shop or the dealer can fix it pretty easily if its not too bad...
squeaky noises...
commonly the bushings on top of the front struts of the Vue will squeak - go under the hood and spray some WD40 on top of the bushings on top of the struts - there are "slots" in the bushing where you can spray...that might get rid of it...
good luck - the Vue is a pretty good car, hang in there!
best of luck :shades:
Has anyone had any satasfaction from GM on this & got a straight answer to it's cause & effect?
My body shop repaired this for around $350, & also did a nice job on insulating the handle from the paint. Although my car was just over 3 years old GM considered it surface rust, then said the car had too many miles for repair to be covered (70K).
I used a tube of clear silicone and ran a small bead all around the assembly to seal out any additional water/salt that could get behind the piece and cause more paint to work loose.
I believe the paint originally worked loose from the piece vibrating causing the paint to chip.
Moisture gets behind the loose paint and causes it to loosen more.
