hi, I have 93 chevy blazer s10, 4.3 lts. i check my brake sistem, everything looks good. sometime when i apply the brake the rear wheels grabbing. usually does when the vehiculo is cold or take more than 12 hours parked, after three or four braking the sistem is normal
I have a 2001 S10 4x4, Brakes were having intermitent issue with spongy brake pedal, I have taken it to a shop and they replaced the master cylinder, worked Ok for a week and same problem, took it back and they said rear calipers were sticking and had to be replaced, after a couple weeks problem returned, took it back and they said ABS needed to be bleed and they said they bleed them electronically ?? Never heard of that but worked OK for another 2 weeks, brakes spongy again and sometime down to the floor, took it back again and they replaced the master cylinder again, worked OK for about 3 weeks and now have problem again. They now said the ABS modulator and pump MAY need to be replaced, but truck showed NO ABS CODES, I now have about $600 into brakes and no good brakes yet. Any ideas would be appreciated. All this started about a month after they replaced a broken brake line. This is a great running truck and never gave me a problem I owned it since new.
