check engine light
mike0356mike0356 Member Posts: 2
edited February 2014 in Chevrolet
check engine light is on then one day coming home from work something seemed different the light was off and my remote start worked again. It was time for oil change changed filter and oil, then started car and light was back on had tester put on and it said large leak in evaporation system .Have checked gas cap , replaced gas cap, replaced solenoid up by oil filter cap and have had code erased but comes back on . Any suggestions scratching head bald
  • Kirstie_HKirstie_H Administrator Posts: 11,148
    If you can, I'd inspect the hoses or tubes to make sure there's no obvious holes or cuts.
    Which code did you get?
    MODERATOR /ADMINISTRATOR
    Share your vehicle reviews
  • mike0356mike0356 Member Posts: 2
    It has came upPO455 and also PO449
