I had the battery, alternator, and started all checked--reading was perfect on all three. There is a drain somewhere.....any suggestions or ideas?? please and thank you.
If you're looking at the vehicle, the driver turn lamp (by the headlight) is lit. The lower turn marker (by the fog lamps) is not. The passenger side, the lower lamp is lit while the upper is not. I have replaced bulbs, obviosusly, but the problem is still there...have you seen anything similar?
I am stumped! Any suggestions?
Thanks for the reply!
Thank you so much for your help!
David
I am looking for some answers. I have a 2003 S-10 p/u. The problems are: the wipers won't shut off, the ABS and the Brake lights come on, and the a/c blower quits blowing. This doesn't happen all of the time, but it is starting to happen more often. We replaced the ignition switch and everything worked fine for about a week.... We will be replacing the ignition switch again, but I'm thinking there is something else making the switch to go out....any suggestions are appriciated.
Now the truck won't start at all!
