Lexus RX 300
1270271273275276304
  • bobgailbobgail Posts: 12
    My rx300 has 155k miles on it. At 80k I changed the transmission oil using T-4. On the dipstick there is a tag that says "no need to change the transmission oil under normal driving conditions. On awd, change the transfer case oil according to schedule" I changed it anyway. The transmission is really working great, but with all the postings lately, I looked at the oil on the dipstick and it was "kind of black". I brought the car to my new local mechanic and asked him to do an oil change. He refused saying that with the amount of miles on the car, it may never run after the oil was changed. I now post this to get you opinions regarding the advice I received from a certified (ASC) mechanic.
  • wwestwwest Posts: 10,706
    Something is seriously wrong within the transaxles of our RX300's. Whatever it is results in the fluid being burnt appearing and smelling burned. Mine at 38,000 miles.
    But the shorter term problem is that the fluid is becoming highly contaminated with debris from the inordinately high clutch frictional surface wear. This contamination is preventing the fluid from functioning properly in its primary functions as a simple hydraulic fluid and lubricating oil.
    Last July I contacted Lexus directly twice via email and both times they sent me to the dealer for an answer. The dealer assured me that Lexus was now recommending fluid flushes at each 15,000 mile interval.
    That was at 38,000 miles. I changed out the fluid myself, 4 qts.
    About 2 months ago during my 45,000 mile DIY oil and filter change I checked the fluid again. Dark and odorous.
    So I changed it out again, 4 qts.
    Checked a week later and the oil appeared just as dark, again.
    Discovered that the diff'l, but not the PTO, also runs in transmission fluid and holds about a qt. unless drained via the separate drain plug. So this time I not only drained the diff'l I dropped the sump pan and cleaned about 1/8" of what appeared to be ground up pencil lead from the bottom of the pan. Installed 5 qts this time. ALL fluid came from Lexus.
    Three magnets in the bottom of the sump pan had a few metallic particles attached but in my opinion not enough to indicate any serious problems.
    Bellevue Lexus service manager has now informed me that the factory has come down on them about undue service recommendations so now the recommendation for our transaxles is not to flush but to inspect and only flush if the inspection indicates a need.
    Yours indicates a need.
    Were I you I wouldn't put any further trust in that particular ASE certified mechanic.
  • jiaminjiamin Posts: 556
    I don't have any problem with my 00 RX. At least it's noticeably quieter than my 02 QX4, more so at higher speed.
  • jheflin1jheflin1 Posts: 1
    Hi Alex,
    Have you had any luck with finding others that have had the same problem? We have a 2001 Toyota Highlander and got the same news yesterday.
    After the local guy refused to change out the transmission oil, I took it to my local Lexus dealer. They took care of the service without a "hesitation" and charged me $129 for the procedure. (12 qts of oil, filter clean out, etc) Not too bad. Car still rides great after 155 k miles.
    bobgail
    20.7MPG over 1300 miles 80% between 75 to 80MPH.
    2001 AWD RX300 w/45k miles.
  • roc17roc17 Posts: 3
    Thanks for all your considerations. I have found some of the parts I have been looking for. If anyone needs something not needed in this project. Some suggestions may be very helpful. roc17 :blush:
  • pschiffepschiffe Posts: 373
    Just had the rear wiper on my 99 RX die. Squirts work but blade is stuck in the up position. Suspect at nearly 90K miles I may need a new motor. Any other thoughts before I tear down the tailgate? TIA
    Pete :confuse:
  • ayh55122ayh55122 Posts: 2
    Both my 200 ES 300 and 2002 RX 300 have this frequent noise that occurs when AC is on. It is not very loud but certainly audible. It may reoccur in short intervals ( less than a minute) and last a few seconds. The noise sounds like air discharging or something. Just wondering if any other owners have the same experience. Is it a problem? :confuse:
  • lordkamalordkama Posts: 23
    Hello!
    I have 2001 RX300 AWD.
    I hear the same sounds you do when the AC is on. The dealer tells me it is the refrigerant (non CFC, of course) being shot out at a high pressure. It is quite annoying if the radio/CD is not on. I also wonder if others have noticed this.
  • mikeytmikeyt Posts: 22
    Never did one but be careful not to break the retaining clips of the panels, they pop out on one side then slide out on the other. Not sure which side GOOD LUCK!
    where to buy my broken lexus rx300 now. sale of 1999 lexus rx300 with bad transmission , sludged engine . :sick:
    That's what a Lexus technician told me when I took my RX in for a check up. I haven't taken the ES to the dealer yet, which I plan to do soon. The noise is actually more pronounced with the ES.
    See messages 8526 and 8529 above. I removed the wiper motor and with some diligence found that the problem was corrosion where the shaft passes through the bushing in the door. I disassembled that portion, cleaned, lubed and put it back together. Motor was fine, works like new, took about two hours total. Dealer probably would have just replaced the whole assembly for only about $200-$300! BTW, inside panels just snap in and out using "xmas tree" type retainers.
    Pete :)
  • jlemjlem Posts: 1
    I am looking at a 2002 Lexus rx300 at a local used car dealer. It looks great and drives like a dream and is fully loaded with a sun roof, CD changer, leather seats, etc. The dealer has put new Michelin tires on it. It has 70,000 miles which is somewhat of a concern to me. I have talked the dealer down to $23,000. The Blue Book shows about $25,000 retail. CarFax says there has been no damage reported. It was apparently on lease to one owner in Pennsylvania. Does being under a lease give one a warm feeling that the proper maintenance has been done to this car? What sort of Lexus recommended maintenance items will I be in for with this car at this mileage? Plus, I don't know how long things like hoses, shocks, wiper blades, fan belt, etc. will last on this car. Overall does this car sound like a good buy? Thanks in advance for your response.
  • steverstever Viva Las CrucesPosts: 48,757
    Check out Real-World Trade-In Values.
    And do an appraisal with our tool here (link).
    Moderator - Buying questions? Please include city or zip code and trim you are shopping, FWD or AWD, etc.
    series seems to be having an inordinant level of premature transaxles failures at 60 to 70,000 miles.
  • lmoonlmoon Posts: 1
    Hello - I am new to the forum but I am hoping to get some good advice on the problem I am having with my RX300.
    Starting in 2004, for about a year now, my car has stalled (just goes dead when coming to a stop or when turing into a driveway) five times so far. The dealer has told me that I need to use premium gas, which I have started to do at the beginning of this year. But my car has stopped 2 or 3 times more since that.
    What happens is that the car just goes dead with all the panel lights coming on. I then simply turn my engine off and restart the car. And the car starts fine after that. So I am not overly concerned but it is still bothering me this happens and it is happening more often now, it seems. I have only about 33K miles on the car.
    Any advice??? would be greatly appreciated.
    A fellow teamseattle member drove his brand new Ferrari Scarletti(SP?) to Daytona for the 24 race. It stalled in SFO and went to the shop for a few days. Again in LA, to the shop again. He went to dinner on Sunday evening after the race and the car wouldn't start when he came out.
    Flatbed to Orlando where they discoverd that the battery connection at the firewall was loose.
    Check your battery, battery connections, both ends, thoroughly.
    Just got these quotes from irontoad.com:
    right rear taillight assembly (lift gate portion only) P/N 81580-48010 $150.34
    driver side wiper blade P/N 85222-50040 $22.46
    passenger side wiper blade P/N 85212-36030 $18.81
    rear wiper blade P/N 85242-48010 $23.98
    Yes, these are genuine Toyota® parts and supposedly Irontoad allows a 20% discount, but these prices seem usurious. Anybody know of a more competitively priced supplier?
    Pete :confuse:
    What's so special about OEM wiper blades?
    The taillight assembly sounds in the ballpark.
    Hello!
    I have had a few instances similar to you regarding the stalling issue and with the dash lights all lit up. It occurred when I first bought the car and it again a year or so later. In my instances, the car seemed to be jumpy and rough sounding prior to the stalling. I attributed to possibly bad gas---automobile gas, of course.
    This has not happened to me while turning or braking.
  • rugmankcrugmankc Posts: 133
    My 2002 RX does fine on regular, I don't think your problem is gas. Have a 98 Windstar with a similar problem. The problem was a component on top of the engine, which I think was the throttle positioning sensor. Someone else may be able to confirm that. Ford has a TSB on it. It died only when making slow turns. It was allowing the rpm's to drop too low and the engined stalled. Replaced it and no problems. Maybe you can leave the car with the dealer for a few days to see if they can duplicate the problem.
    Good Luck!
  • parockerparocker Posts: 2
    I have a 1999 RX that I bought as soon as they were available in June of 1998. Love the vehicle and plan to keep it til it dies, which could be some time. My question revolves around when to replace the timing belt. The manual for the 99 says replace at 90K if you drive in certain strenuous conditions, which I do not. Otherwise there is no recommendation for replace with just normal operating conditions. Does anyone have any experience with timing belts and when to replace. Local Toyota (no Lexus in Charlottesville) quotes about $450 to do the job.
  • mikey00mikey00 Posts: 462
    00 and 01 RX owners manual says change timing belt at 90K. Nothing about strenuous driving. From reading posts here and on other RX forums it looks like most play it safe and have it done at 90K, which is a good practice. I will most likely play the odds a little and have mine done by the Toyota dealer at 120K and have him do the plugs at the same time.
    on my 92 LS400 before the timing belt was changed out and the one removed looked like it might be good for another 150k miles.
  • wil_atlwil_atl Posts: 1
    My wife is obsessed with the RX300. So I'm looking for one for her. Our budget dictates that we get one for $14k max. I'm thinking that would mean a '99.
    What are the chances of getting a '99, or possibly a '00, with under 100k (say 75k)miles for $14k or less?? Thanks.
  • erik_herik_h Posts: 77
    Just keep looking around for one, I did a quick search on autotrader and found a few within 200 miles of my house in VA. I bought my '99 a few years ago for about $23K still under original manufacturers warranty and added an extended warranty. :)
  • duane3duane3 Posts: 7
    I just came from the Lexus dealer. My check engine light came on shortly after I left a gas station (I checked the gas cap and it was on tight) - car runs perfectly, but I felt I should have it checked. Dealer found code P0171, said I need to replace the Mass Airflow Sensor - $300.00. I told them to forget it for now. Is this really the problem? Is the cost appropriate? can I do this myself?
    If you remove the gas cap and do not fuel up then you will get an engine check light becuase the system thinks the gas tank vacuum was lost due to "other' causes. Same thing can happen if you start the car first and then put the cap back later.
    When the fuel tank level increases (enough??) coincident with a loss of vacuum the diagnostic is cancelled.
Lexus RX 300 - Page 273 - Car Forums at Edmunds.com
