LOL - No, but God willing it (or perhaps an older, lighter Trooper like yours if I can find one in good shape) may be the subject of an EV conversion!
We're still doing the research and math for feasibility, but an EV should really work for us - and we love our Trooper, so we're trying to find a way to combine the two.
An "E-suzu" (paired with a regular Trooper for those long rides) would be great..
According to table in Chiltons manual.....code 32 is EGR system failure
code 44 is Oxygen sensor circuit (lean exhaust indicated)
By the way....these are the same codes I'm getting on my '95. So far, I've removed the EGR valve and cleaned it and removed the crusted area where in passes into the intake manifold. So far, no improvement, but I didn't clean the tube going from the EGR down to the exhaust manifold yet.....tomorrow!
I seem to have a common problem...the engine is "missing" at just about all RPMS, hesitates and chokes while driving. Error codes are 32 and 44 (EGR failure and O2 reading lean). So far, I have a new O2 sensor and have removed and cleaned the EGR valve and passage into the intake (but did not clean the tube going down to the exhaust). I have new plugs to install, and likely will buy new wires too.
Question: how do you check the 3 coil packs to verify they are providing sufficient spark?
matt
I picked up my truck tonight and to my surprise it is running pretty good. The lean running is gone, and when I step on it there is no black smoke and no bogging. The mechanic simply disconnected the O2 sensor. Im not sure if thats bad for the truck but it solved my problem. I did replace my original sensor with an aftermarket and thats what could have caused my problem. A new O2 is $600 CDN and i simply do not have the extra cash. I hope this helps you and keep in touch and let me know whats going on,
Chade
-mike
-mike
your aftermarket O2 sensor is your problem! MY mechanic plugged my aftermarket O2 and my truck is running better than ever! The 32 and 44 codes are gone! I have a 13 until I decide to spend the money to get the proper part! This is the best day ever! Thank you to everyone who has helped me out!
P.S. Has anyone replaced the O2 and what company should I purchase from?
I'd like to try it, I've got nothing to lose......I wonder if he just disconnected it or if he jumped the wire. Does anyone know if this would cause any other problems????
After cleaning my EGR thoroughly, I haven't seen the check engine light come on. However, it isn't running any better yet. New plugs and wires are next.
if you take a look at the sensor you will notice that there is a connector about 3 inches from the sensor itself, all you do is disconnect that connector but leave the sensor plugged into the exhaust pipe. cover the connector with a small plastic bag or covering and put a plastic tie strap around the bag and connector and it will stay clean and dry. New plugs and wires should help but im almost 90% positive that your problem is the aftermarket O2 sensor.
You will notice that once you disconnect the sensor you will most likely get a code 13 which means an O2 sensor cirsuit problem bacuse you have disconnected it. The other codes should disappear and your trooper will be back to normal. I wouldnt keep driving it the way it is because my mechanic told me that the leaking fuel injectors which cost me 2300$ were a result of the faulty O2 sensor. Good Luck.
-mike
What happened with your car? Did replacing the cylinder do the trick?
Cheers to All !!
Give me your feedback on what is a fair price for my 1998 Trooper. This beloved vehicle has served our family very well. 114k miles, some typical door dings. Very solid mechanically, except for the disconcertingly high oil consumption - currently a quart every 800 miles or so. Interior looks very solid, with some scuffs and scrapes in the cargo area. Everything works.
It's a Performance Package model, which in 1998 model year meant 6 disc in-dash CD changer and Torque on Demand system.
The Michelin LTX tires have a good 30-50k miles left on them.
I've already delivered the truck to my parents but have not decided on a value. Based on the above, what would you recommend as a fair price? I was thinking between $4000 and $5000.
The driver's power window is broken (glass has fallen out of the regulator?) and there's a small dent above the left rear brakelight. I'm going to pay a shop to fix the window because my own fix attempts didn't hold. The dent, my parents don't care about.
Looking forward to your feedback.
I'm sad to see my Trooper go, but at least I can still drive it when we visit my parents.
However your parents? I don't know, I would unload it to my dad for free or maybe like $2k (if he felt obligated to pay me something). There could be a big repair in the near future for your 98, and then it is $4k + big repair = more like $6k.
I recognize everyone isn't in the same financial position, but I owe them a lot more for college.
Also, I got a full tuition scholarship so my parents spent only about $2000 a year on my schooling for room & board-- so I helped them out quite a bit since they were prepared to pay for 4 years of my college!
-mike
So now I'm basically down to my '94 Legacy Turbo, '04 Armada, and the '96 Impreza Race Car.
-mike
I have the same story, '99 3.5L Performance that is DRINKING oil...I had the engine light come on twice and from what I am reading in different places, I am very lucky it hasn't locked up! The first time I put 4 qts. in before it was even close to full. It now has 84K miles, started drinking it around 76K.
Now I check it about every other day. I drive about 80 miles a day with it.
Same story, no smoke, not a drop on the ground...very baffling!
Anyone have any answers? :confuse:
-mike
All Trooper experts--what's the recent advice on how to resolve or live with this problem? I've seen stuff posted a few years back and that's what I'm trying now (this forum is GREAT!).
-mike
I'm not totally sold on Sea Foam, but it comes strongly recommended for clearing engine oil carbon. Thought I'd try it for a while, measure results, and then do the next thing on the list. I'd like to understand what the problem is through working solutions in steps. Sea Foam seems to have helped some, but 800 mi/qt is still unsatisfactory, and it's worse with highway (hi rpm) driving--no real surprise here. I know there's more folks with this problem, I see sooty tail pipes in lots of newer Troopers. So come on, let's see some chatter...
Are you currently using Mobil 1 or a standard dino oil?
I like the sound of the oil consumption reduction you seem to have gotten with it. i think I'll give it a try as well. I'm running Mobil 1 and have in my 99' since I got it. It now has 79000+ miles on it, and runs very well; very dependable transportation. Very solid feel and no rattles or squeeks except for the rear door jiggling some times.
"CD-2 Oil Detergent frees sticky lifters, valves, and rings to quiet noisy engines. Dissolves sludge, carbon, and gum to extend engine life. Cleans all internal engine parts for more pep and power. Protects critical engine parts during high speed or stop and go driving."
Like I said in my previous post, I tried everything and CD2 is the only one that loosened up the sludge to free up the oil holes that are clogging.
How many miles since your last timing belt change? Do you have good spark on all cylinders? Is your catalytic converter failed and clogging the exhaust pipe? These are items where a single part failure could cause the engine to act up the way you describe.
I cannot guess the cost of repair without more information, could be very low cost to swap a part yourself or quite high cost.
