Drew
Vans, SUVs, and Aftermarket and Accessories message boards
paisan, the Trooper does not, repeat, DOES NOT have auto hubs (post #495). It uses a drive flange. More on this in a moment. Also, quite a few vehicles within the last 10 years came equipped with manual hubs. The "base model" Toyota pickups up until a few years ago came standard with manual hubs, as did Nissan base pickups. My 1992 Toyota SR5 came with ADD, but I installed hubs on it.
I think this is a good opportunity to provide valuable information to the faithful. I consider myself to be somewhat of an expert on hubs, but you be the judge(s). Let's start with the oldest 4x4 technology and work forward.
Drive flange - this is the original 4x4. The front drive shaft and axles rotate all the time, even when the transfer case is disengaged.
Manual hubs - I believe hubs were first offered by Warn in the 1960s. My dad's old 1968 International pickup had Warn hubs from the factory, so I know they are at least that old. My old 1969 Ford Bronco (the first SUV!) was also equipped with manual hubs from the factory. Manual hubs disconnect the front wheels from the axles, nothing more. They are simple and robust, and offer the owner the most options. As Moliere said in Tartuffe (as I recall), "It is the best of all possible worlds." They were eliminated from most vehicles because most people are too lazy (or the factory thinks we're too lazy) to get out of the vehicle and engage them when needed.
Auto hubs - these lock automatically when the transfer case is shifted and the vehicle is driven forward a short distance. They also unlock when the transfer case is disengaged and the vehicle is backed up a short distance. In my opinion and that of most serious 4wheelers, auto hubs are JUNK. I have personally seen several sets self-destruct. Take a look inside - they depend on a flimsy screw mechanism to lock/unlock, and are filled with tiny, weak parts just waiting to break when you need them the most. The good news is, if your vehicle has them it can probably be equipped with a set of the superior manual hubs.
Auto Disconnecting Differential (ADD) - this system is used by Toyota, Isuzu, and others. The front wheels are equipped with drive flanges (see above) but the differential has a set of slide gears on the axles that are actuated by a solenoid when the transfer case if shifted. So, when the transfer case is shifted into 4wd, the slide gears also engage the front axles. When in 2wd, the axles rotate all the time but the drive shaft does not. Get it?
AWD & full time 4wd - also use hub flanges to permanently keep the front wheels engaged to the axles.
My Trooper now has manual hubs, so that when I am in 2wd nothing up front turns except the wheels.
Everything old is new again!
Central - on your hub install make sure you have all the required tools, incl. the large & small allen wrenches, liquid gasket maker, snap ring pliers, and a big hammer (to persuade those flange bolts to come loose!). Follow the instructions on the web page (a good article BTW -I used it too) and take your time. You can do it!
Sorry for the extended post, but I hope it clears up some misunderstandings.
Best,
offroader
-mike
BTW I had an 88 Pathfinder also, put 167,000 trouble-free miles on it, sold it mainly because of body rust more so than any mechanical problems.
basketballkid - whatever happened to you didn't involve the hubs, or lack thereof. It could be a problem with your truck, or possibly the teeth on the front axle slide gears were not quite aligned and the vehicle needed to move a fraction to allow the gears to engage. I'm not sure what happened. If you have any doubts, put all 4 corners up on jacks and then engage 4wd. This would simulate a "no traction" situation like snow or ice. Both rear wheels should rotate (because you have limited slip) and one front wheel should turn (because it is an "open" differential.)
CalMini kit cause it gives a little more lift than the OME coils, or the OME springs w/a 1" coil spacer. Will these shocks handle the added lift?
If they don't expand enough they'll limit wheel travel. (Seen it happen on XJ lifts)
with my last ?'s. But guys PLEASE HELP again!
ALL Interstate Highway 15, constant 70-80MPH, NO START & STOPS, and ONLY 15MPG???? IS THIS NORMAL?????
What should I expect around town?? in 4WD???
Any suggestions/advise greatly appreciated.
acola
These are genuine Isuzu filters and include the copper washers for the drain plug.
FREE to anyone (you pay shipping), but I would prefer someone in the Denver metro area, so you could just come by the house and pick them up. We live in S.E. Aurora, near Quincy Reservoir.
Post a message with your e-mail or phone number and I will get in touch with you.
You are pushing a REAL heavy "brick" down the road, and at 70-80 MPH, I'm not surprised at your mileage. Its about what we got on our '98.
-mike
For those of you familiar with CA, the trip was from the Los Angeles area to Fresno (about 230 miles each way). Nearly all highway with some steep grades near the Grapevine, no offroad driving. Conditions were cool, A/C was off. Used cruise control most of the way, 70-72 mph according to speedo.
Got 18.22 mpg one direction, 18.25 mpg the other direction. This is excellent repeatability.
The best I could do before the manual hubs installation was about 17.8. I feel confident that the hubs increased my highway mileage by about 0.4 mpg. Not tremendous, but I'll take it. I do not think the previously posted 15 mpg is normal.
regards,
offroader
-mike
The process was relatively painless. The worst part was breaking the large bolts free. The problem was that when these bolts came undone they let out a loud snap sound. Of course, the first instinct is "what have I busted and how on earth will I ever get the stud out?". Fortunately this was just a series of 12 false alarms. The instructions at http://www.outdoorwire.com/4x4/isuzu/ suggested loosening these bolts with a hammer. Instead, I broke them free with a extension on my allen wrench, the wheels still on and the car partially on the ground (i.e. using the weight of the car to keep the axle from turning).
The thing that took me the longest on my 1999 Trooper was determining how to fit the wheel center trim caps back on as the new hubs stick out about 1/4 inch more than the factory covers will allow. This was a totally optional call on my part but I think it does look much better with them back on. To do this I drilled a big hole in the center of the cap. I then used a scroll saw to make 7 or 8 radial cuts to the edge of the cap creating 7 or 8 pie wedges. These wedges then simply snapped right off with a little back and forth help with some pliers. I then filled the edges smooth and had a perfect fit.
I didn't reinstall the hub caps on mine. You're right, it may look a little more original with them installed, but I'm more into function than aesthetics, & I didn't want to spend the time to do it. Another factor in my decision was that a friend once did that on an old Chevy Blazer, & he was constantly removing the caps to empty out debris & dirt that had slipped inside. If you don't do much offroading it won't be a factor. You may also want to drill a few small holes along the sides to allow water to drain out.
I'm glad it went well for you. Enjoy the new hubs!
The depreciation schedule according to the trade in values of used vehicles seems pretty harsh for the Trooper. It's value falls more like an American made car (my Chef Malibu, for example...). Is this because of previous years the truck had problems?
There is a dealership offering a Trooper I 4WD Auto for ~$24000 and 0%, which looks like a pretty good deal to me.
red
David
nobuynissan: You will love the trooper, it's boxy shape is very comfy for big dogs in the back. I've actually slept in the back of mine w/o a problem The body roll is no worse than comparable SUVs, just have to drive it like a truck not a sports car : ) Depending on where you are the 2wd models may be good for you.
You guys should check out the Isuzu owner's club area here on Edmunds. Also check out http://isuzu-suvs.com
-mike
Good Luck!
New Troopers typically are bought for $4-7k off MSRP. If you start there and calculate depreciation based on that number, it is fairly average vs. other vehicles, in my opinion.
99 Troopers that are selling for $18-20k now probably sold for $23-26k when new approximately 2 years ago. That's about $5k depreciation in 2 years, or somewhere around 20%. That's not too bad.
Also, I think there are some posts on shocks and lifts in the Modifications/Aftermarket section of the Isuzu Owners Club - check out that Townhall forum for more shock opinions.
Insurance rate info can be fairly tough to find on the internet, but I do believe that Microsoft's CarPoint provides a 1-to-5 rating (from much better than average to much worse than average) for insurance costs for each make & model. Intellichoice is another place to look.
-mike
The depreciation numbers I looked at were comparing actual purchase prices and trade in value. It's nice that a dealer is getring $20k for a two year old Trooper, but I'm not a dealer.
Fred
Once you get your Trooper, chances are you'll just be breaking it in at 2 years and 40-50K miles and have no desire to get rid of it at all, so the depreciation isn't a major issue as long as you keep it for 5-6 years.
-mike
When:
Tues, March 13th (Tonight) at 6-7pm Pacific/9-10pm Eastern
Click on the link below to read more about/to enter the chat:
http://www.edmunds.com/chat/chiricochat031301.html
Drew
Drew
chapla.t@mellon.com
Steve
My understanding is this only comes in Pearl White. The Trooper's seem to be well loaded, even with their "S" model.
The list is for $33,995. My best quote so far is for $31,197.
Not huge movement by any means, but wait... this is at 0% financing.
By my calculations, this is the equivalent of vehicle for $26,000 @ 7.45% financing (lowest I could find outside of dealership)
Am considering buying a 2001 Trooper Annv. Edition.
Seem like very nice vehicle. I priced the Rodeo, but for not much more, seemed like Trooper is good deal. I plan to keep car for long haul.
I was first attracted to Isuzu for the power train warranty (10yr/100k)
Any thoughts are appreciated....Good or bad.
-mike
-mike
Actually I wanted the leather, with heated seats.
The moonroof I don't want, or like.
They're asking $1295 for after market leather alone. The anniversary package is $2600 (MSRP) so I figured for $1300, give or take, I'd be getting the heated power seats, 6 CD changer, with upgrade stereo. All of which I do want.
Do you think I am just falling into the trap they want me too? You know "well for just a little more, what the heck..."
All that aside, I have 20K miles since june on my '00 and love it still after all those miles. Handles well, has tons of room, and the AWD is awsome. You can check out pics and info on my website http://isuzu-suvs.com/ These trucks are amazing! If you are in NY/NJ/CT call Mark or Ira @ Staten Island Subaru/Isuzu 718-979-9595. They actually have a Black 2000 still in the showroom which is going for $26,000 + Tax and Tags.
-mike
At least that's what I've read, and for a few dollars more, why take the chance???
Seems to good to be true. Do you just take the negotiated price (forget taxes, trade ins) and divide by 60 (12 months)?
Is Isuzu that hard up for business?
How do they make money, just on the mark up?
-mike
