BTW, the service manager said with confidence that there WILL be a new Trooper for '05/'06, although possibly with a different name. And, he says they were assured by Isuzu that mechanical and crash parts for current Isuzus would continue to be available. Any guesses on whether this might be what we see in a year or so? http://www.thairung.co.th/English/Consumer/Adventure.aspx
-mike
Isuzu had better do something:
Total sales Mar 2004: 4,057 vehicles.
Axiom: 322 in March 2004, vs. 665 in March 2003.
Rodeo: 3,102 in March 2004 vs. 1,765 in March of 2003.
Seven-passenger Ascenders: 383, compared with 434 in March of last year.
Five-passenger Ascender totaled 235.
Isuzu sales through the first quarter of 2004 totaled 7,570, which compares to 8,583 vehicles sold during the January-March period of 2003.
-mike
Anyway, this is the only thing you have to be worry choosing a diesel vehicle. Good luck.
Drove a DI Axiom while there. That thing will scoot!! it has a good road manner about it and the suspension is tuneable which is nice. The seating position surprised me for a BIG guy. Had plenty of head room, and a comfortable ride. The DI engine boasts 235HP and 24 MPG. Sounds pretty enticing to me. Anyone here own one of these??
-mike
I did it once before and am about 8 months from rolling over 100k again myself. I think you need a 100k sticker for the Trooper now.
As I research the web I'm finding that many people have had no problems with their Troopers (other than routine oil consumption) while some seem to have had major engine and transmission problems. Has there ever been a survey to find out how common these problems are (I don't trust the CR reliability reports)? The challenge with anecdotal information is that its hard to gauge how common a given problem might be. Has there ever been a survey on this board? If not, may I ask the following questions and invite anyone and everyone to reply?
1. What year is your Trooper?
2. What is your engine/transmission/4WD combination?
3. How many miles are on it?
4. Does it burn oil, and if so, how much?
5. Have you had any problems with the vehicle (excluding routine wear and tear, etc.)?
6. Can you estimate the total cost of repairs to the vehicle since you've owned it?
Please feel free to answer this for as many Troopers as you've owned.
Thanks, I'll also check intellichoice.
Cheers,
Sean
Yeah your Quest is another keeper, should last for a long while.
2. 3.5L / 4L30-E(AUTO) see link below/ TOD
3. 100K
4. 1qt./1K
5. At 80K, Transmission went into a "safe mode" shifting erratically and very hard. Solution, pull over turn off engine for a minute and re-start ala re-booting. It's done it twice since then.
6. 30K = $400.00, 60K = $500.00, 90K = TBD
Tranny link http://www.gm.com/automotive/gmpowertrain/transmissions/hydra/app- - s/4l30.htm
2. 3.5L / 4L30-E / TOD 4wd
3. 44k
4. 1/2 Qt. / 3k
5. Rear pinion seal leak at 22k, drive by wire accelerator board at 26k - all warranty.
6. No repair costs to date - all warranty as stated above...only routine maintenance plus installing 4 Rancho 9000RS shocks & 4 B-stone A/T Revos.
Thanks to those who have responded,
Sean
3.5L/4L30E
Poly Sway Bar Bushings
36K
ZERO oil usage!
30K service = $300
EGR/Fuel Injector/General Emissions (?) service at 35K = $300
New Battery at ~20K
Typical routine maintenance
Trooper been veddy good to me . . .
2. Auto/TOD
3. 37K
4. burns very little oil
5. Steering column replaced due to wear, catalytic converter failure, intake manifold gasket, battery went at 3 years, front end alignment needed shims to correct caster problem when brand new, **
6. More $$ than I would have liked. Original aligment problem cost a few hundred out of pocket. Dealership screwed me 1 month after 30K service they said that my brakes needed replacing and that includes hub repack, which was done at 30K so I had to pay another $200 or so for that work twice. It has cost me a lot of time taking it far out of the way to get it fixed (and each problem required several trips due to weak dealership...which is the only one within 1 hour). I have spent some of my own money on getting tranny flushed at 30K and the axle/differential fluid changed after summers of offroading.
7. I added bullbar, offroad lights, OME Shocks, CD/MP3 player, thule rack and CB.
**Engine short block replaced due to sucking in a bunch of muddy water, insurance and Isuzu covered all but $100.
Had two bad intake manifold gaskets, a bad fuel pressure regulator, and the CD changer crapped out twice. All but the second CD changer were under warranty.
Burned maybe a quart of oil in 3,000 miles.
I would love to get the opportunity to go 200K with this truck, but I'm concerned about the tranny. I wonder how much damage I've done when it goes into "safe mode". Others recently have had transmissions go bad, but covered under warranty, I'm way out of warranty.
Got to admit though, I've been shopping around for something new, just can't find anything that I "must have".
Also got new tires and alignment and it's nice. Now I need to get OME Shocks for it and i'll be in good shape.
-mike
-mike
I excuse for my complete ignorance :-)
1999 S (base model)
3.5 L TOD 4WD
75000
No
Changed engine intake gasket at 30K. No other problem
Change oil by myself.
I used to use ISUZU dealer for 15K 30K 45K services. They are pretty expensive (about $600 for 30K service). Now I switched to a local mechanic who did the 60K service for $250. I don't think there is much difference.
Upgrade/maintenance:
New battery at 40K from Sum’s club, and it died in 10 months, got full refund. Now got Optimal, which is damn good.
Yokohama Geolandar H/T-S G051 (Highway All-Season) tire at 50K, they are good.
Rancho 5000 shocks at 40K, it is a must
Get rid of stock radio and speakers, they are suck. Upgraded to Alpine. I should have get the ones that can place MP3
Garmin PDA-based GPS
Try \\www.arbusa.com
1998 Trooper S with Performance Package (equivalent to the LS model of newer years)
3.5L V6, 4-speed auto (4L-30E), Torque on Demand 4wd.
102,400
Has gradually increased from 1 qt every 3000 miles to 1 qt every 800-900 miles at present.
Very few.
Intake manifold gasket - warranty covered.
CD changer replacement - warranty covered.
Also, I think the replacement manifold gasket is in the process of going bad based on similar symptoms as last time.
Can't think of much else besides routine maintenance.
'Repairs' - I am pretty sure I have not paid for any unexpected maintenance aka repairs on this vehicle. Excludes body damage due to fender benders - had a couple minor issues fixed at no cost to us.
'Maintenance' - probably spent $2-4k. Dropped $1,200 on a major service at 75k miles - timing belt, water pump, new brakes, etc. Do own oil and fluid changes (exclude trans). New tires @ 52k $450. This set of Michelin LTX 245-70-R16 is still going strong. Recommended. Serpentine belt. Never needed an alignment or steering work.
1996 Trooper S
3.2L SOHC 24valve V6, 4-speed auto (4L-30E, I think), shift-on-fly 4wd.
51,000 at time of death.
If I recall, a quart every 2000-3000 miles.
Very few.
Power window problem (caused by me trying to open it while frozen shut) - warranty covered.
Very little else - cannot recall exactly. No major component problems - engine, trans, etc.
Did not spend anything on repairs - vehicle was under warranty until shortly before its demise.
Routine maintenance was pretty minor - did not need new brakes or tires yet, or major service (timing belt etc.).
Overall, the 98 is smoother and quicker and more useful in bad weather because of the TOD. I wouldn't really say it is more refined than the 96, because both are trucks through and through. Somehow, the 96 got better fuel economy in spite of lower EPA ratings.
I've posted on Edmunds before about differences between the 98 and the 96. Search back and I'm sure I have given more detail in the past.
'99 Trooper w/Luxury Pkg.
3.5L/4sp. Auto/TOD
53,000
Yes, since day 1. Burns about 1 qt. every 2k, more if extended highway driving or towing. Used Mobil 1 since 1st oil change.
Has transfer case and transmission mounts tightened under warranty after 2 months of ownership.
Not counting routine maintenance, I have only replaced the battery. Cost was $110 for Optima.
Tom
1999 Trooper S with Performance Package (equivalent to the LS model of newer years)
61.200
Has gradually increased from 1 qt every 3000 miles to 1 qt every 2500 miles at present.
Very few. Recently replaced EGR valve. Replaced serpentine belt and plugs.
6. Can you estimate the total cost of repairs to the vehicle since you've owned it? $450
Been to the dealer 4 times now for driveline noise (clunk) when coming to a stop. The replaced the driveshaft and fiddled around with transmission mounting bolts. No resolution yet. The driveshaft cost $600+ at dealer cost. Mileage was 59,800 barely under the warranty.
Do my own oil and fluid changes (exclude trans). New tires @ 39k.
2. 3.5L/Auto/TOD 4wd
3. 65k
4. no oil burn between changes
5. no major repairs, 30K service was done
6. typical stuff like 1 battery, 1 set of tires 255/16/70 Bridgestones
7. always changed oil at ~4,500 miles - not synthetic
8. See following for record of expenses:
http://www.isuzu.8k.com/First-57k-miles.htm
- 98,000 miles
- Average overall condition - some scratches in and out.
- Oil leak at one of the spark plug coils
- When transmission is in neutral, and move 4wd leaver to 4Lo, slight grinding is heard (my 1999 Trooper does not grind)
- Parking break leaver is tight and can only barely pull up
- CD player missing
- Good tires
- Green with grey leather interior
- Asking $7,900 - said will take less
I would appreciate any opinions on this purchase. Have not driven vehicle yet but it starts up ok and idles smoothly.
http://www.edmunds.com/used/
I wonder if anyone has done a do it your self brake job on an '02 trooper with 31,000 miles. I have pulsing brakes and had an estimate from the dealer to replace all pads and rotors for about $1500.00. Seems kinda overkill in terms of price and extent of service due to low mileage. I did a front brake job on my infiniti j30, replacing pads and rotors. It was quite simple. Due to TOD, removing the hubs seems to add another dimension to the job. Any help or suggestions will be greatly looked forward to.
I know from other Isuzu guys that the front hubs are a major PITA.
-mike
OME 929 Expedition Springs
OME HD F/R Shocks
-mike
-mike
Anyway, its been months and months now that he is fighting with them. They do admit, however, that, if the problem exists, they will fix it. The process is taking so long because they keep dancing in circles regarding their "testing procedures" and how to exactly measure this oil consumption. (I believe the latest excuse is that they need to have the same tech check the oil both times in that one month period and they haven't done that yet)
But as far as I understand, if you have documentation regarding the issue prior to the end of the warranty, you have a leg to stand on.
An experienced front end shop can remove the wheel/hubs in minutes. Also, are you sure that the breaks are not covered under warranty - especially if they are so inclined to change out parts.
