Toyota Echo Accessories and Modifications
124»
  • dakedake Posts: 131
    Yep, what kneisl1 said... HERE'S my old post from earlier in the year with pics (scroll down for pics).
    I wanted variable spd intermittent wipers and the Echo came with just single-spd intermittent as an option. I have the Matrix switch on mine, and I'd wager that almost any Toyota wiper switch from those years will probably work. The extra knob for the rear window wiper doesn't effect anything.
  • Does anyone know where I can find a bra for my 2004 Canadian model Echo Hatchback? How about a bug deflector?
  • echoecho7echoecho7 Posts: 4
    I am trying for last for weeks to figure out where is the VSS (vehicle speed sensor) wire located in my Totyota Echo 2001. Without any success. Please help me if you can
  • kneisl1kneisl1 Posts: 1,694
    Well the VSS SENSOR is located under the air cleaner assembly so I assume its screwed in to the transmission. Is this an auto transmission? So if you find the sensor youll find the wire. According to the manaual its under the air cleaner which has to be removed to get at it. Let me know what you find out!
  • mnmanmnman Posts: 31
    It has been a year since I put my cruise in, but I just looked at a wire diagram I have on the computer and it looks like a violet wire or a red/white wire. I found mine by the instrument cluster. I'm going up north now w/the Echo, I'm sure you know the cover to the cluster snaps out very easily... I can look closer if you need me to. Good luck, Mark from Minnesota (mnman)
    I checked for the wire that I used for the vss in my '01, it is violet/white colored and is in the right wire bundle going into the speedometer cluster.
    Mark,
    Thank you so much for taking time to check this. hopefully, i will be able to solve this "Cruise puzzle" this weekend.
    Thanks again to everyone who found some time to help!
    Lj
    yes, you are correct it is auto transmission.I found a sensor located on transmission , but there are 3 wires. which one to chose is the question now. Mark helped with answering
    this question (please see his reply), so I am hoping that this weekend I will be able to locate wire and finaly get cruise running.One more question: do i need additional vacuum canister for cruise for Toyota Echo?Already bought one but didnt installed yet...
    Thank you for your help and time!!!
    ~lj
    Try to get ahold of nippononly, he's installed cruise in his ECHO (manual trans though) so he might know just what to do. You can find his posts in the main ECHO forum.
    Sure I will. Thanks again for your help!
    echoecho7- so I take it that you didn't get a Rostra electronic cruise? I put a Rostra in and it is the smoothest cruise I have ever had! But I have not driven many luxury cars...
    I took the Echo in for a flush/fill on the brake fluid tonight, kinda surprised Toyota didn't use a dot 4 or 5 rated fluid in the car. I have a 180 mile trip in it tomorrow, chow for now.
    Well Dot 5 bf is based on silicone or something so, hell no, you dont want to use it in your ECHO! It would just gum up the works! Dot 4 is just "improved" Dot 3. Who knows what that means? My new Yaris takes Dot 3 also.
    edited June 2010
    Alright gang - I bit the bullet and ordered these: Raceinpsired.com Tein basic coilovers - does anyone have any experience with them?
    No I have no idea what they are made for. Racing or something? (with an ECHO?)
    Well, not really for racing, but just for tightening up the body roll a bit on the Echo. I figure I'm going to be driving this car for a while yet and my only complaint has always been squishy suspension. It's not like I'll be out doing road courses in this, but it'd be nice if it stayed even a little flatter through the bends.
    Thats a common complaint about the ECHO and something that isnt going to get better as the cars age. :mad: Let us know what happens!
  • nippononlynippononly SF Bay AreaPosts: 12,696
    The Echo rolls like a drunken sailor who hasn't got his land legs back yet! :-P
    I know they did it to smooth out the ride with such a short wheelbase, but really the amount of body roll is totally over the top for a roadgoing vehicle.
    2016 Camry hybrid, 2009 Outback Sport 5-spd (keeping the stick alive)
    Actually Ive heard it does pretty well in a skidpad test.
    0.77, just slightly better than that king of flat cornering, the Jeep Grand Cherokee! :-P
    http://www-cs-students.stanford.edu/~kpfleger/auto/handling.html
    And then, of course, how fast it can go around a skidpad doesn't measure how far onto its side it leans to accomplish the task....
    edited July 2010
    Thought I'd do a quick update on these bad boys. I finally had some time to spend switching out the old for the new.
    This set is pretty nice - Everything is beefier than the stock components and high quality.
    As you can see from the comparison shots, the rear springs are quite a bit shorter. This is somewhat made up with the new base that allows for height adjustment.
    The front springs are actually shorter than the stock, but obviously much harder as they have more coils for the length.
    Installation was relatively easy. I've never replaced shocks before, so I tried to just take it slow. I borrowed a spring compressor from O'Reillys (it's free if you return it within 2 days) and I had everything else I needed.
    The set provides you with everything you need when used in conjunction with a few OEM components. This actually is my only real complaint b/c while everything else was fine, there's a dust seal at the top of the front shock column which the instructions say to reuse but mine had completely disintegrated. This can't be more than a 50 cent fiber or composite washer basically and there's no reason they couldn't have thrown it in with their kit - they are good about providing all-new top and bottom nuts and what not, but for whatever reason they didn't provide this part. The nuisance here is this stupid little gasket thing was a pita to replace.
    Outside of that it all works as advertised. The directions are minimalist - basically just an exploded view of the shock tower which shows you how to build it from the bottom up and a few notes on basic settings for your car.
    Once all was said and done - WOW what a difference (Toyota)!
    These do lower the ride height a bit - a solid inch if not closer to two. That being said, the ride is fantastic. Still perfectly comfortable, but stiffer and more responsive. Body roll no more - cornering and braking are both noticeably better.
    All in all, I would have no problem recommending this to anyone who wanted to spruce up the ride of their Echo just for fun. It's a little costly and it took me all day to do it myself - but I'm very happy with the results.
    Good work!
  • I'm very late to this forum; just bought an '02 with auto trans about a year ago. One annoyance for me was the O/D off button, which I kept bumping with my right leg (I'm about 6' 4"). Not a big deal at low speeds, but after it happened a couple of times at 70+ mph I decided I'd spare the engine and trans the sudden downshifts and do something about it.
    Rather than permanently disable it, I put a toggle switch in series with the wire to the button, and mounted the switch on the front of the center console, pointing forward & out of the way. So if I ever need to lock out 4th gear (have had this feature on my cars for the last 10 years & have never used it, but who knows) I can flip the switch & the button will work again.
    Anyway, if anyone else has this problem & wants to do something similar, let me know; I could take pictures or something if it would help. It was pretty easy; the console comes off with only one screw (underneath the rear cupholder - remove the little plug to get to it).
124»
Toyota Echo Accessories and Modifications - Page 4 — Car Forums at Edmunds.com
