Thanks so much for any help
I seem to have a leak on my driveway (have had it since I've owned the car). I've put the vehicle back on the lift to look and it appears as though there is a leak coming from the pan forward of the transmission pan - if you have the Chilton's Isuzu 1981-96 repair manual there's apic on page 1-79 fig 183. I can not figure out what the heck this is. Is it an overflow pan of some kind. How and where can i order a gasket for this?
thanks.
Sly
Sly
Sly
About 4x4, it will bind on turn on dry surface,there is no cluches or cental differential to provide diff in wheel speed. If you try to push it, it may grenade tc as well.a
My wife took our 01 Rodeo LS 4x4 in for a transmission gasket replacment and we were told the Gas Mileage Regulator was bad.
I can't find any such part on the net.
Does anyone know what is going on here? Strangely, when I press the horn, it continues to honk even when I release the pressure. I have to punch the wheel hard to get it to stop. Could these things be connected?
help!!!
started fine Monday morning- let idle- went in to get books came out and it was dead. will not restart
I have another that I parted out and replaced every seeable electrical start component...still nothing
any clues?
Bob
Thank you,
fabian
Chris
So I bought this 98 Honda Passport used @ 137k miles. It's running pretty good - and my mechanic looked it over and said it seemed pretty stable.
I was driving it yesterday and smelled gasoline with and without using the heat - any ideas?
thanks a bunch - you guys helped me with my 02 Honda Odyssey
I can feel a loud thump while acceletaring or decelerating/braking on my '99 Isuzu Rodeo. Sounds like it is coming from the rear of the vehicle. Has anyone experienced similar problem, and had it fixed? Thanks.
(97 Rodeo LS 4wd)
#660 of 1898 ABS light on by pondview Mar 30, 2002 (5:51 am)
Bookmark | Reply | E-mail Msg
The ABS light on my 1998 Rodeo stays on all the time, it statted about 3 months ago(it has 37k miles) My local mechanic tested the brakes and said they were fine. Is it probably just the sensor and no reason to be concerned...or could it be something more serious? I really don't want to take it to the dealer.
#661 of 1898 ABS by paisan Mar 30, 2002 (5:10 pm)
Probably a sensor. The parking brake light would come on if it was a problem with the brake system.
-mike
Also needed was 4 part engine clean and replacement of a valve.
Scheduled 60,000 mile service
New front brake pads.
In shop 3days
total cost of parts 616.00
total labor $$1933.94
look on my face when I recieved the bill....PRICELESS..
I cant help but feel like I got scammed.
Does this sound like a reasonable price?
Oil is cheap, you know...You can do a lot of 60K service youself, it mostly check this and that anyway, you can do brakes, it really easy. Shop around for parts and labor next time. Hey, you paid "for convenience" mostly.
bill
I do recommend turning off your CAPS LOCK. People tend to ignore messages typed in ALL CAPS.
How is your suspension?Do you guys have a good ride with your suspension?Because mine is really rough ever since i bought the car even after i place a new shocks in it is still the same.I mean everytime i ran into a bumpy road everything inside the car is bouncing my whole body is shaking,its really bad.Do i have a bad suspension or it just how the car build?
I think i'll try calling Isuzu directly and see if i can get any information from them.
However ... they call my minivan engine an interference one, and everything I've seen says it's not. :shades:
Here's a good reason to change it anyway:
marku1, "Nissan Quest/Mercury Villager problems" #2276, 8 Feb 2006 7:19 am
I was looking to add clear corner and taillights cant find them online does anyone know of a site i can hit to get this done
Thanks in advance for any and all help.
:shades:
,to the every day driver around town and so on the regular setting is just fine the power button comes into play when your towing or somthing where you need the longer shifts
and max power from your powertrain if you notice just drive it ,say from a traffic light then at the next light
apply the same pressure but turn the power option it really is a big difference ,just remember with the cost of fuel dont do it too much (alos try the winter option it wont let you spin the tires and once you get to speed it auto shuts off................
