I've got ~2200miles so far, and milage has consistantly been in the high 15's for city driving.
Last year, one of the local news stations had a Lowest Gas Price board on their web site, but I haven't seen it start up again yet.
Every now and then I'll run a tank of the Sunoco-Ultra, very peppy!
I am working with a dealer to get a LE 4x4 with rear LSD. He said that he cannot find this in Texas. He is telling me that the All-Mode LE's, when put into 4x4-Lo lock all diffs. Is it true that this locks both the center AND rear diff? Or does it just lock the center diff?
I do plan on doing occasional (but sometimes fairly trying) 4x4 in this vehicle and LSD seems like an option I should NOT compromise on. If the diffs do indeed lock in 4x4-Lo, I will consider it, if they do not. I think I will hold out.
What are your opinions on this? Is the dealer lying to me (*gasp* heaven forbid) about the locking diffs? He is trying to pressure me into this vehicle saying it is the only one in Texas with the rest of the features and the color that I want. LE - Sierra Silver - 4x4 - Rear LSD - Sunroof Deflector - Leather - Tow Hitch. We have also looked at ones w/o Tow Hitch w/ consideration he may install one after-market. Still no dice. I called another dealer and they confirmed that this model is indeed hard to come by in the entire state of Texas.
I do not need the vehicle NOW. I can wait a month or even two. I just want to make sure that what I get is what I want.
Any opinions? Thanks - Mike-
jc109: nismofreak was referring to mixing 89 & 93 (there was a thread on this a while back that I was in)...if you mix 89 & 93 octane (in equal amounts, of course) you get 91 octane...which is what the PF requires (minimum)unless you're at higher elevations. Where I buy gas, it's only a 5 cent diff between 89 and 93 so I would only save 90 cents on a fill-up...not worth the bother IMO.
Tom
Where are you located (Dallas? Houston?)? I've had good luck at Courtesy Nissan in Dallas on Hwy 75, I think, (service only) and Robbins Nissan/Chevy/Olds in Humble (NE of Houston on 59). If you go to Robbins, ask for Dewey (I can't remember his last name...he's a small, older gentleman). Tell Dewey that Jamey's son, Matt, sent you because you were looking for a straight shooter. We've purchased 3 Nissans from him (2 Altimas and a Maxima in '94 and '95). I talked to him there in '99, so I'm pretty sure he's still there. I would have purchased my Pathy from him, but it was on the move to Wisconsin that the JGC it replaced crapped out.
Anyway, putting the transfer case in 4Lo only locks the center diff (as does putting the 'case in 4Hi). The Pathfinder doesn't offer a locking rear diff. I'd definitely hold out to get LSD. I didn't hold out and now I'm looking for a way to get it.
Good luck!
I know where it occurred, at my health club, which has a large number of elderly members, who don't seem to know what "parking between the yellow line" means. Now, even if I have to walk 3 blocks, I don't park in the lot anymore. I hope at least, your insurance is covering it. Me, I'm just gonna suck it up & pay for the job myself. :-(
Needless to say, I ended up with a busted rear wiper and a couple of really nice scratches along the top of the car. :-( Luckily I'm the only one who knows they're up there.
www.cogasprices.com/
www.koaa.com/community/reference/gas_central/GasTracker.asp?state=Colorado
I paid $1.99 last weekend for premium down south off Lincoln Ave.
What kills me is that gas is anywhere between $.05-$.15 cheaper near where I work (Lakewood), than where I live (Highlands Ranch). Hmmmm...same gas, different demographics = gouging?
I think so
The LSD option for the rear diff enhances vehicle stability and traction in any 4wd position, including 2wd. It essentially allows engine power from the rear propeller shaft (drive shaft) to be transferred to the tire that has more traction, up to a limited amount of slippage, hence "limited-slip differential".
This is advantageous if one rear wheel is in mud or ice, and the other wheel is on pavement, for example. Without the LSD, the wheel on ice will spin and the wheel on pavement won't move at all. With the LSD, some engine power gets transferred to the wheel on pavement, so you won't be stuck.
Note: even in 4wd-lo, if one rear tire and one front tire don't have sufficient traction, it's possible to get stuck without the LSD.
See this link for a movie clip illustrating an extreme example of low traction in 4wd. This vehicle HAS a limited slip rear diff, but one rear tire is completely off the ground. With an open diff, no forward progress would have been possible.
http://members.telocity.com/deanandconnie/hh0301/dean_wheelspin.mov
When someone goes to a McDonalds isn't the price usually the same at the locations around the same area? At least around here it is so this leads me to wonder why the same gas station chains will sell at different prices? I understand that each station is probably independently owned, but aren't most McDonalds independently owned as well? Just something to consider.
Dano
Does anyone else have this problem and any recommendations. Thanks.
Anyone experienced the same? I will check the batteries when I come home but I think it has something to do with her leaving the door opened. Thanks.
Have you tried the Costco station in HR? $1.89 for premium last Monday...
Woody
-nismo
In 4wd, do both front tires drive together, just one, or is it limited slip like the rear?
I never see anything written about the front diff, just the rear.
Sorry if this is one of those basics everyone already knows.
Then last week my wife (she drives the pf) calls me w/ a flat tire. I took it in to have it patched and was told the tire had already been plugged (a temporary fix) and that was the cause of the leak.
I'm growing very concerned about the condition of this "new" vehicle. Am I just being picky or does anyone else agree that my dealership owes me some explanations and a full inspection of the vehicle so that I don't run into any more "surprises"? Nothing pisses me off more that my wife being stranded w/ a 1 1/2 month "old" vehicle.
I'm just concerned about finding more problems.
The front differential is an "open" differential. This means that engine torque is split evenly to both wheels as long as they both have equal traction. If one wheel loses traction, then it becomes much easier to turn than the other wheel, and nearly all engine torque is applied to that loose wheel. There usually isn't an option for having a limited-slip FRONT differential because it makes steering a lot more difficult in 4wd.
(BTW, a differential merely enables 2 wheels on one axle to rotate at different speeds during turns)
See this link for more info:
http://www.howstuffworks.com/differential.htm
to have above average LSD. These clutches are the reason that special LSD oil is required. The front diff is a regular non LSD. Might be idea during the summer months to shift into 4wd just to lubercate the bearings and gears.
Does anyone discourage introduction of 100% synthetic engine oil at 4000 miles (6400 km) on the odometer?
TIA
me that just as long the oil consumption was nil it wasn't an issue. Using Valvoline
syn 5w-30 and very pleased. Works good in the lawn mower too!! I will start using
Amsoil filter because of the oil filter confusion. Can't find the new Purolator L14610.
Back seats; it depends on the size of passengers in the front seat. Not a real problem.
BELIEVE IT. SECONDLY, ANYONE KNOW WHEN THE 2002 PF'S ARE DUE IN DEALERS. MY CURRENT LEASE IS UP IN SEPT. SHOULD I WAIT AND ORDER A 2002.ONE DEALER TOLD ME THEY WILL BE TAKING ORDERS IN AUGUST. THIRD, I HAVE DRIVEN BOTH MY MISTAKE WAS DRIVING THE PF AFTER ALMOST SETTLING ON THE 4RUNNER. THE PF SEEMS MUCH TIGHTER WITH LESS ROOM THAN THE 4R. THE 4R RIDES ROUGHER AND HAS MUCH MORE WIND NOISE BUT THE RESIDUAl IS UNBEATABLE = LOWER LEASE PAYMENTS.
ANYONE HAVE SOME ADVICE. MY WIFE WANTS A TAHOE BUT I CAN'T JUSTIFY 35000.
THANKS
Case in point: The DSM AWD car have 3 diffs: Front, centre and rear. The centre and rear are LSD so if both rear and one front don't have traction, then you are stuck.
Seriously confused about the front diff on the Pathy. What Meca said made sense to me: Two diffs (centre and rear). Why else would the front end "hop" with 4 Hi (or Lo) engaged?
wcroland??
Here's what I want:
2001 Pathfinder 4x4 LE
Sierra Silver - Leather Package - Rear LSD - Tow Hitch - Sunroof deflector
The best quote I have from a dealer so far is $32,000. I have asked around and they say that since demand is so high in Texas, they will not go lower. I have asked a few dealers. I even showed them posts from here saying people are paying nearly $1000 less than that around the country and they will not budge. Am I getting jacked?
Any experience with ordering? My dealer says that he cannot find the model with options I am looking for so he may have to order. He says that if I order now it will take 90 days, but the good thing is it will be a 2002 model. Only bad thing is that the 3.9% is going on now and they said that I will get whatever rate is going on when the vehicle arrives. Does anyone know historically how long Nissan carries APR deals on for? With the economy as it is, I'm hoping I will still have that rate in 3 months.
Any opinions?
-Mike-
We paid about 34,000 for the same options you have requested, but also included the entertainment center. I live in N.CA where they were also (at the time in Feb) offering cash back incentives as well which brought it down to around 32,000. It does seem like you could get a better deal, but most of those deals seem to be coming out of Canada...I could be wrong though. Good luck on your search for the best deal.
In a straight line, all tires rotate at the same speed. Around a turn, each tire travels a different path, so each tire rotates at a different speed. The outer tire always rotates faster than the inner tire on each axle, and since the front tires travel a wider arc than the rear, then the front driveshaft rotates faster than the rear driveshaft.
This is why there must be 3 differentials on AWD vehicles. However, a part-time 4WD vehicle (with only 4hi and 4lo, not auto-mode,etc) does not have a center differential, and both the front and rear driveshafts MUST rotate at the same speed.
On the new Pathfinder auto-mode 4wd system, 4Hi and 4Lo modes lock the center differential. Otherwise it's unlocked, allowing each driveshaft to rotate at different speeds.
So in 4hi/4lo on high-traction surfaces, the front driveshaft can't [easily] rotate faster than the rear, causing a buildup of tension in the driveline components. This tension is released by either wheel slippage/wheel-hop or driveline breakage.
I hope that makes sense.
Do you think those orange Fram oil filters in Walmart are any good?
I put a K&N air filter in since Day 1 ... all good so far!
TIA
a poor quality paper filter. It would be interesting to use a K&N
filter for an oil change and have the oil tested for silica and then
use a foam for an oil change and have the oil tested then paper??
I just checked CarsDirect.com for a 2001 LE AWD with your listed options (Leather, Tow package, LSD, and Sun Roof Deflector) and they list the price at $31397.
Hope this helps.
SKG
