Toyota replacement cv boots
Has anyone tried or found the "Toyota Split CV Boot" replacements in the USA. I found them on the Australian Toyota Parts site. They are a Genuine Toyota Part and do not require removing the axle to replace damaged cv boots, I have not found the here in the US. https://toyota.com.au/owners/parts/brakes-suspension-steering/split-boot-kits
The last boot I did was using an axle kit from Raxles and it worked fine for around a decade when I finally sold that van.
If you do the boot, you'll have to completely clean and inspect the CV joint prior to installation if you want to do the job right. If you're strapped for cash, then yeah, you can just slap on a split-boot, but think of it as a "patch" for the time being.
Not a bad solution if you're doing your own work.
There are other companies that make these kits--just nothing I can see from Toyota.
Changing that boot is a filthy, nasty job and who knows what the condition of the CV joint is.
I put a split boot on an old Volkswagen once. It had about a dozen little nuts and bolts and I had to lay on my back for an hour. I guess it worked out OK but I sold the car shortly thereafter.
